Put the PCV back in....
So the BEGI intake manifold didnt have a spot for a pcv valve so I have been running it with a breather on both sides of the valve cover. I found that by doing this I am leaking oil from the cam cover and have also seen lower oil pressure as well. This to me is unaccpetable so I decided to drill and tap a hole for the PCV valve. I also decided to run a T fitting off that same port so that the valve cover vent on the driver side is also incorporated into the flow. This should provide better oil vapor evacuation. I got it all back on but realized that I have a leak at my throttle body because the threads in the BEGI manifold for the TB got all effed up somehow. I didnt feel like messing with it anymore today but I will be running helicoils in there when I get the chance. Ill let you guys know the results when I get it all done.
I didnt honestly think missing a PCV would matter but I think it really makes a large difference. Turbo cars see a lot of blowby so we need to have a PCV in the system to catch it all.
I'm very anti PCV system within a turbo system. Where it would normally be open and breathing on a NA car... it'll be close on a turbo car.
Its something many honda people overlook and get increased crank pressure and have problems from that.
Picture this... PCV system closes under boost... blowby and crank movement build pressure inside the motor... where does it go? Last time my lines got clogged (frozen stuff in lines to small)... my turbo became my PVC valve. I turned into Spy Hunter with the smoke screen upgrade.
Open PCV system for me... or ideally... slashcut or vacuum pumped.
well you get the vacuum draw as soon as you let off the gas, right?
by the way, there's a PCV that goes to the intake manifold from the pax side and then the hose on the driver's side that goes to the intake tube.
what is the latter and why do they go different places?
When the engine load is low (the majority of the time) pressure in the intake is also very low (below atmospheric). Crankcase fumes are pulled through the PCV into the intake, and fresh air enters into the crankcase through the drivers side vent.
The valve is needed because it forces a one-way flow of gases through the crankcase during low-load engine operation. Without a one-way valve, moisture and acids from combustion will accumulate in the engine.
No, "fresh air" would never enter the driver's side vent, as it is intended to be connected to a source of constant vacuum (you can see this on any stock car, including the Miata).
Why would you want said "fresh air" to enter the crankcase anyway? You want to pull a vacuum in the crankcase, hence the term Positive Crankcase Ventilation...we're trying to vent/get rid of the positive crankcase pressure, as it's not good for anything.
he said it flows through... the point of the pcv is to remove pressure and, I believe, corrosive gases from the revaporization of condensation during cold startup.
I guess the flow doesn't matter as long as it's mostly OUT and never net IN.
Matt
Matt
The driver side vent is connected to vacuum? How so? On an AFM car, I guess the crossover tube may be a few kPa lower than atomospheric, but nothing close to a vacuum. On a MAF car, I doubt you could even measure it.
You need fresh air in the crankcase to replace the fumes you are removing via the PCV.
Wikipedia to the rescue: http://en.wikipedia.org/wiki/PCV_valve
Why would you want to re-introduce "fresh air"/pressure back into the system from which you're trying to remove pressure?
The whole point of the valve is to relieve pressure form the crankcase. You'll never "add" fresh air in. The pcv closes as your throttle increases, so no air enters the through the valve...on the flip side, the breather line is under a constant source of vacuum.
but it's there to keep whatever small amount of gases coming OUT of the drivers side vent going back into the motor.
So my problem is that I have my filter mounted directly onto my turbo.
no nipple.
Total Cats: 57
I have my pass side PCV hooked up normally with the miata valve, and the drivers side has a hose that connects to my intake. It works fine. I kind of want to get a catch can hooked up, as my turbo is now getting some oil in it.
-Michael-
-Michael-
