Throttle Position Sensor for 1.6
Old 03-16-2006, 10:24 PM
ryry's Avatar
Total Cats: -1
Default Throttle Position Sensor for 1.6
I have just ordered my MS and I am trying to get everything together that I need to make a (hopefully) smooth install. From what I have read, my car does not have a variable TPS, but the automatic cars do.
Will a later year throttle body off an auotmatic 1.8 car fit the 1.6 or would I have to stay with the 1.6 size?
I saw someone used a GM TPS. Is that an easy install or is it kind of mickey mouse?
It is very comforting to see a MS forum here. I think I will be visiting often!
ryry is offline
Old 03-16-2006, 10:34 PM
Aussie Driver's Avatar
You don't need to have the tps connected at all unless you have to run a hybrid alpha-N fuelling algorithm. The rpm based acceleration is excellent and it doesn't need the tps.
Aussie Driver is offline
Old 03-17-2006, 05:49 AM
iWeasel410's Avatar
If you do want to run a TPS, you can use any variable TPS and just calibrate it in MegaTune.
iWeasel410 is offline
Old 03-17-2006, 08:26 AM
ecugrad's Avatar
Damn that just saved me $100 for a 1.6 automatic TB!
Miata 1.8 TB's are not compatable with 1.6's Intake Manifolds
Here is where I got my info from
http://members.aol.com/solomiata/Fuel-elec.html
ecugrad is offline
Old 03-17-2006, 03:52 PM
ryry's Avatar
Total Cats: -1
Thanks for the replies!
ryry is offline
Old 03-17-2006, 04:22 PM
iWeasel410's Avatar
Yes, keep in mind that MSnSE can do:
1) Alpha N
2) Speed Density
3) Hybrid Alpha N
4) MAF
Old 04-05-2006, 09:38 PM
kingofl337's Avatar
I purchased a 90 Protege Automatic throttle body as I got a slight bog using MAPDOT on the 26 code. Sounds like they have gotten better. But it was only $20.00
kingofl337 is offline
09-30-2018 01:09 PM
10-03-2015 11:04 AM
Trent
10-01-2015 12:15 PM
The Gleas
10-01-2015 09:30 AM
Quick Reply: Throttle Position Sensor for 1.6
