manual boost controller question????
ok i bought this manual boost controller from ebay
http://cgi.ebay.com/ebaymotors/ws/eB...m=280119453721
i cant figure out how to install it. so i installed the t into the line from turbo to actuator. the off the third nipple i have a line running to the controller unit. as i open it it raises the boost but there is an open nipple. it just doesnt seem correct. please help me out. also as i take the control unit and try to blow threw one end i can easily blow threw it with it set at max boost when the boost is set at lowest boost i cant blow threw it at all.
my boost is turned up to 8-9 but only peaks there then drops to like 7 would that be normal ore is it maybe the boost controller?
that was adobe illustrator....(using laptop with no mouse :( )
its a basic bleed type MBC....the tee restricts the airflow and probably is a one was check valve on the blue port (that way it doesn't cause vacuum leak at idle) then when boost enters the wastegate so of the air gets bleed out of the line before it reaches the wastegate so the boost goes higher.
