FS: NB engine stuff (including injectors!)
Old 06-18-2007, 11:08 AM
nester's Avatar
Default FS: NB engine stuff (including injectors!)
Have a complete engine out of a 2003 miata, I am keeping the block and crank, pretty much everything else is for sale.
I also have injectors out of a 2005, with 5000 miles. I'd like to get $50 for those.
Let me know if you need anything.
nester is offline
Old 06-18-2007, 11:27 AM
Good price on the injectors. Someone needs to jump on them. My NB injectors (currently in Atlanta93LE's car) are the ****.
What about the fuel rail itself? I need one.
Old 06-18-2007, 11:33 AM
nester's Avatar
I have the rail too, but it's returnless, so I don't think you want it..
nester is offline
Old 06-18-2007, 11:35 AM
Yup, actually I do, for a good price.
Old 06-18-2007, 11:51 AM
MazDilla's Avatar
How about the MBSP & Oil Pan? If those are up for grabs PM me.
MazDilla is offline
Old 06-18-2007, 12:12 PM
steelrat's Avatar
How much for the head? Or is it toast?
Dave,
steelrat is offline
Old 06-18-2007, 12:32 PM
Atlanta93LE's Avatar
Yup. Surprising how well they've been working at ~7psi.
Atlanta93LE is offline
Old 06-18-2007, 01:00 PM
Given that he over heated it would be a toss up on the head. From the look of the block it didn't look to horiible though you might get lucky.
Old 06-18-2007, 01:05 PM
Slidin'Miata916's Avatar
are overheating these motors this fragile? When I had my 5.0 it would over heat like crazy after sessions then be perfectly fine. Is there a specfic reason for this?
Slidin'Miata916 is offline
Old 06-18-2007, 01:13 PM
Aluminum head on our cars vs steel on the 5.0 most likely.
Old 06-18-2007, 01:14 PM
It's never a good idea to overheat your motor, no matter what it's made of. The miata engine is a steel block with an aluminum head. Because steel and aluminum expand and contract at different rates, it's likely to pop the HG or warp the head with an overheat.
Solution: Don't overheat
Old 06-18-2007, 01:24 PM
OHhhhhhhhhhhhhhhh ok. I didnt know our heads were aluminum.....that explains it then. Thanks
Old 06-18-2007, 02:26 PM
nester's Avatar
The head is slightly out. When you put a straight edge on it, you can almost get a feeler under it between #2 and #3. It's certainly rebuildable, and it may very well be just reusable with a light touch up from a machine shop. The valve seals do not appear to be leaving, and everything looks to be ok. Cams are still in it.
nester is offline
Old 06-18-2007, 02:27 PM
nester's Avatar
MBSP? is that the main support thing? I would want to keep that for use in a future build.
Oil pan is available.. it's the one off the 05.. I drilled a hole in it for a oil return but then decided to reuse my old one.
nester is offline
Old 06-18-2007, 04:27 PM
nester's Avatar
Also have a OEM clutch, PP, and flywheel.. 5k miles as well.
nester is offline
Old 06-18-2007, 04:29 PM
nester's Avatar
I have no idea what a fuel rail is worth, Make me an offer.. I am thinking $25 shipped?
nester is offline
Old 06-18-2007, 04:44 PM
$25 is fine with me. Please send me your paypal info. Thanks.
Old 06-18-2007, 11:40 PM
nester's Avatar
Paypal is sean@wewt.net
nester is offline
Old 06-19-2007, 12:48 AM
Flippy02's Avatar
what about the coils?
Flippy02 is offline
Old 06-19-2007, 10:38 PM
nester's Avatar
Coils are available. I know those are ~90 each new, so make me a reasonable offer.
nester is offline
Quick Reply: FS: NB engine stuff (including injectors!)
