A/C bracket bolt question
Old 09-20-2007, 04:06 PM
greenday3437's Avatar
Default A/C bracket bolt question
So i removed my A/C, and i remembered seeing something in Splitime's buildup thread where Braineack pointed out he should put one of the bracket mount bolt back in or he will get a big mess..
My question is did you mean oil will leak out of that hole? because i lost that bolt
Anyone know the size and thread pitch of it so i can find another one so i dont loose all my oil?
here is the post im talking about, post #43 https://www.miataturbo.net/showthrea...t=10844&page=2
greenday3437 is offline
Old 09-20-2007, 04:11 PM
start the engine and see what i mean :gay:
if you look closely the bolt is actually onto the oil pump itself. it's pressurized behind it. I'd say a typical m8 or m10 will fit in there. dont you have a random bolts collection?
Old 09-20-2007, 04:15 PM
Total Cats: 6,608
When I removed my A/C compressor and bracket, I didn't re-install any of the bolts that came out. That was over a year ago, and there's no oil gushing out the side of my block.
Perhaps the 1.8 blocks are different?
Joe Perez is online now
Old 09-20-2007, 04:16 PM
maybe im wrong, but i was fairly certain the forward facing bolt on the oil pump is under pressure.
Old 09-20-2007, 04:18 PM
i dunno, ill find one and put it in there just in case
Old 09-20-2007, 04:36 PM
TonyC's Avatar
Total Cats: -4
is this 1 of the 4 long bolts attaching the a/c to the bracket, or the bracket to the block?
TonyC is offline
Old 09-20-2007, 04:40 PM
SamS's Avatar
I didn't replace any bolts either, no oil leaks here.
SamS is offline
Old 09-20-2007, 04:53 PM
Miotta FTW!
Splitime's Avatar
I just found a random bolt to be honest.... It's 1 of 4 or 5 I believe that hold the pump. You can possibly get away without it... but i put it in for safety sake.
Splitime is offline
Old 09-21-2007, 01:04 PM
Total Cats: 6,608
I am an utter moron. Disregard completely my last post on this thread.
I had previously interpreted this business of oil leaking if you don't replace the bolts to mean that oil was actually going to leak out of the bolt hole itself. I'd even gone so far as to run a cotton swab down into each bolt hole to check for the presence of oil and come up clean.
What I realized last night after looking at the pictures linked to here is that one of the bolts I'd removed when pulling the A/C bracket was also holding the oil pump housing onto the block. It's the one that goes into the front of the engine, not the ones that go into the side. I'd completely forgotten about that bolt.
I have marked up one of the images from the other thread below. When the bolt which is illustrated in green is not present, the mating surface between the oil pump and the block (roughly illustrated by a pink line) does not seal fully. And wouldn't you know it- there is in fact a tiny bit of oil seeping from that gap!
I did some measuring, and I believe that the correct bolt to use in this position is an M8-1.25 x 45mm. I'm going to pick one up at lunchtime, and I'll try installing it this evening.
Old 09-21-2007, 10:22 PM
bradh88's Avatar
so, how did it go, was it the right size bolt? i gotta get me one of those.
bradh88 is offline
Old 09-22-2007, 03:45 AM
Fergus's Avatar
I didn't put that bolt back in at all and I've no oil leaks since last April.....well, none so far anyways.
Fergus is offline
Old 09-22-2007, 05:08 AM
Total Cats: 2,100
Braineack is rarely wrong, but he is definitely wrong on this one. It is not "just some M8 bolt"; it MUST be a 45mm M8x1.25, just like Joe said. 40mm will strip the threads, and 50mm will bottom out before it is fully tight. I replaced that bolt with the aforementioned M8x1.25x45mm, and it has worked perfectly.
Savington is offline
Old 09-22-2007, 05:38 AM
akaryrye's Avatar
or a longer bolt + a couple washers. Worked for me.
akaryrye is offline
Old 09-22-2007, 08:39 AM
Total Cats: 6,608
The 45mm bolt fit perfectly. I cleaned up the trace of oil that was there, and we'll see how it goes.
Old 11-25-2012, 03:17 AM
hornetball's Avatar
Total Cats: 696
I'm raising this one from the dead.
I'm down for "heavy" maintenance, and the damned oil weep from this area was one of the items on my list to fix. I thought it would be a simple matter of installing a bolt.
As luck would have it, a strong light and inspection mirror reveal that this bolt has broken off even with the iron block (i.e., the break is about where Joe's pink line is drawn). I'm guessing some gorilla (not me for a change) put in a too-long bolt and torqued on it until it sheared.
Would really like to get this fixed. Any downside to drilling and trying an easy out? Pretty sure I'm clear of oil and water passages with this bolt. Any other suggestions?
hornetball is offline
Old 11-25-2012, 04:07 AM
Total Cats: 6,608
Only that you will then have half a broken bolt stuck in the block with half a broken EZ-out stuck in it.
I kid, though in all seriousness, I cannot recall ever actually succeeding at using a bolt extractor to extract a bolt.
Old 11-25-2012, 12:25 PM
hornetball's Avatar
Total Cats: 696
I've had the exact same experiences with easy outs. I think I got one to work once, which only fueled the frequency and vigor with which I've broken them since.
In a moment of clarity while drinking coffee this AM, I came upon the obvious solution. Drill it and tap it. M8 x 1.25. Duh. My radiator and condensor are out and I've got great clearance. 5 minute job.
/end
Old 11-26-2012, 08:34 AM
Leafy's Avatar
Total Cats: 104
Thanks for that illustration Joe. All this time I thought I've just been nursing a leaking front main.
Leafy is offline
Corky Bell
Prefabbed Turbo Kits
11-22-2016 09:01 PM
russian
10-08-2015 03:01 PM
patsmx5
10-01-2015 09:43 AM
ihiryu
General Miata Chat
09-28-2015 10:22 AM
Quick Reply: A/C bracket bolt question
