Miata GReddy Dyno
Miata GReddy Dyno
I finished my project yesterday...
GReddy manifold, turbo and downpipe.
RX-7 intercooler with custom piping
Vortech FPR
14 deg base timing
OBX dual SS exhaust
NAPA cat
Wastegate tightened as far as she'll go.
146.5 rwhp and 144.8 rwtq
Vortech FPR
14 deg base timing
OBX dual SS exhaust
NAPA cat
Originally Posted by JDMAflac
huge jump in TQ! what are you using to control your timing? bipes?
We couldn't make it ping until we were almost at 9psi. We had to shut her down at that point, but you could see by the graph that it was on it's way to about 15 more horses.
Originally Posted by MiataNuTca
Finally, another dyno to feast my eyes on....nice numbers for just screwin down the wastegate. She's a torque monster. Probably because your not reducing your timing and the OBX is probably pretty restrictive.
The best thing is that I can actually run my air conditioner without it feeling like I'm pulling a grand piano behind the car.
Regarding the OBX exhaust I think that it is pretty free flowing. I can definitly feel and hear and see on the boost gauge the turbo start to spool well before 3000 rpm. You can also see on the graph that it's making at least 12 more ft/lbs already at 3000 rpm.
Oh... And I definitly think the timing is a big factor. It was one of my goals... To not have to retard the base timing to some ridiculous number.
i was under the impression that it was not safe to run 14* timing with just the base kit. right now I just have the base kit and bigger exhaust, stock injectors, 6* timing, and no engine management. I was going to get my IC then engine management then up the boost and timing to about 8psi then get bigger injectors... Is it "safe" for me to just adjust my timing to 14*???
not unless you have an IC or timming control or WI, or, dont like your motor. He has an IC so he should be ok. i leave mine at 10 becouse it just feels better but that is just me one day i will see if a get more boosted power with more timming probably so but for now 10 degress is good for me. Not to shabby kid free up that exhaust and you should get some more hp.
Yeah... The low end on this car is absolutely fantastic. Who needs a supercharger when a GReddy can make 145 rwtq at 4500. What is amazing is that I picked up about 60 ft/lbs of torque on a car that only made about 86 ft/lbs to begin with N/A. That's about a 70% increase.
Its not fully spooled until about 4300 by the looks of the graph, thats pretty late. I used to see 12psi @ 3400rpm in 3rd gear. Also, I would retard the timing, but if you wanna risk it go right ahead, its dangerous though...
Originally Posted by braineack
That will probably help with your spike on your a/f. Adding a MBC will help increase spool as well for about $10.
Right now it's just stuck in between the passenger seat and the transmission tunnel until I decide where to mount it. I set it for the most agressive settings. When I first tried to crank the car after the wiring it would turn over but not start, and I'm thinking... "How did I blow it, I paid close attention to every wire." I went around to the other side of the car to have a look and then realized that I forgot to plug the harness back into the ECU. "What an Idiot!"
Anyway got that resolved and warmed her up and proceeded to flog the crap out of her for a few redline runs and absolutely, positively, no pinging this time at all. Too bad the Bipes can't remove timing and then put it back in later on in the power curve when the fuel richens up a bit.
I used vampire clamps for 4
Actually, the Bipes timing curve does add back some of the stock timing above 5000 RPM or so (it's been a while since I read the instructions, but they show the ignition retard curve).
The e-Mangle can retard timing as well, but these two can't add anything above the base timing as far as I know.
Please....to save a headache post later on........take off the vampire clamps and solder the wires properly! The vibrations from the car causes all kind of nightmares with those stupid things. Using these, and putting loctite on a grounding bolt are the worst electrical things you can do for your vehicle.....I've experienced this.
