Scirocco style radiator?
Old 09-01-2006, 10:23 AM
VRTSid's Avatar
Default Scirocco style radiator?
you guys think this radiator would be enough to cool a FI miata?
Ive been eyeballing it because it looks like I can mount it and have room to go between the rad and the top of the core support for IC pipe and still mount a smallish oil cooler there.
overall dimensions, 21.5x13.25x3
http://store.summitracing.com/partde...5&autoview=sku
VRTSid is offline
Old 09-01-2006, 11:11 AM
BrokeEnthusiast's Avatar
i thought i saw a member on here who had that rad. I think it was the guy with the twin turbos
BrokeEnthusiast is offline
Old 09-01-2006, 11:13 AM
RicanmiataRacer's Avatar
Is it smaller than the stock radiator?
RicanmiataRacer is offline
Old 09-01-2006, 11:33 AM
nevermind it wasnt the guy with the twins
https://www.miataturbo.net/forums/showthread.php?t=3721
I know I have seen it on here somewhere
Old 09-01-2006, 12:57 PM
TurboTim's Avatar
Total Cats: 399
Nope. I would love to do a smaller aluminum radiator at one point and redo some plumbing. I can never leave well-enough alone.
TurboTim is offline
Old 09-01-2006, 04:35 PM
VRTSid's Avatar
well do you think its enough radiator for a fi miata? my goal is 14psi when Im done but I only want one radiator.
VRTSid is offline
Old 09-01-2006, 04:57 PM
It looks as though the core size is smaller than the Miata, which isn't what you want. But it does have some other things going for it- It's a crossflow which is more efficient than a down flow, and it looks as though it's a double pass (in/out on same side/tank) which puts the coolant through the core twice. If it's a single core, the rows are probably thicker/larger than OE too. You have other options outside of summit. That's a typical circle track rad, and they come in other sizes.
Here's what I did. - rob
Old 09-02-2006, 12:56 PM
MiataNuTca's Avatar
Total Cats: -2
I upgraded to a dual core, but it's not aluminum from radiatorbarn.com. Didn't cost much and it's able to cool my car with the AC on and I'm running 10psi. I haven't track tested it though. I believe others have used this with success as well.
MiataNuTca is offline
Old 09-02-2006, 07:34 PM
VRTSid's Avatar
Ive got a dual core miata rad, but I want to run my piping differently either over the top of a shorter radiator or around the sides of a narrower radiator... I'd also like it to live under the coresupport instead of behind it.
This radiator is dual core, cross flow and about an inch thicker than my current one. I dont know for certain but I think the coolant volume will be about the same.
VRTSid is offline
Old 09-02-2006, 11:02 PM
If it's an inch thicker, I bet it's got an extra row over your current rad. That'll help. And I bet that summit piece is a double pass- I dont' see how the inlet and outlet could be on the same side otherwise. That'll add more temp drop. If you were to go with the shorter rad (as pic'd) you could def run the pipes right over the top providing you don't have a condenser. Though I think what you'll be missing out on is the additonal vertical space that's available on the Miata below the existing rad. Even the stock mouth piece/belly pan doesn't flush up against the bottom end tank. It all depends on how much cooling you need. What makes this summit piece unique is it's narrow and short. I wouldn't think you'd need to give up both the height and width. - rob
Old 09-03-2006, 03:13 AM
VRTSid's Avatar
Right now I have the Automatic miata radiator, 2 row all metal. this one says its 2 row on the summit page so I guess they are just significantly bigger?
I meant double pass not crossflow. I was looking at two when I wrote that
I pulled my ac a year ago
Im reluctant to go lower than the oem one, I have a ground clearance problem as is I would like to either go narrower or shorter, but this so far has been the best Ive found, price v. size v. design... Im still shopping though.
VRTSid is offline
Quinn
Cars for sale/trade
6
10-23-2016 07:58 AM
90 Turbo
19
10-19-2015 03:23 PM
10-03-2015 11:04 AM
shooterschmidty
8
09-30-2015 10:28 PM
Quick Reply: Scirocco style radiator?
