more restrictive muffler = quicker spool?
Old 11-26-2006, 03:08 PM
Question more restrictive muffler = quicker spool?
I don't get it, but I swear my turbo is spooling quicker with a turbo style muffler now than it was with the flowmaster style (chambered) muffler. I was going to datalog a run to verify it, but my clutch failed before I got there. I swear I saw 15psi for instance where I would have had 13psi max. before. Explanations? - rob
Old 11-26-2006, 03:41 PM
UofACATS's Avatar
How is it determined that the new one is more restrictive? I thought the chambered style was more restrictive
UofACATS is offline
Old 11-26-2006, 03:49 PM
isn't a turbo style chambered also?
Old 11-26-2006, 03:58 PM
Well I use those terms losely. Think of a flowmaster vs. something like a dyno max super turbo. The turbo style usually runs through a series of tubes, changing the exhaust direction. The chambered keeps exhaust flow going straight through, just around various "walls".
chambered:
turbo:
Old 11-26-2006, 04:05 PM
Dange's Avatar
a flowmaster is more restrictive, esp, on a 4cyl, engine. the exhaust has to hit basically 3-4 "walls" before leaving the muffler, think of as if you put 3-4 u bends in the exhaust. and as you know exhaust doesnt like to change directions..
the turbo style is 2 perforated cores on each side of the muffler exhaust enters goes through the perforations through a "gap" and then back through the other tubes perforations. though the exhaust has less problems going through the perforations the soundwaves have a harder time thats how that works oddly enough having nothing to do with turbo..
the flowmaster is all designed around the pulsewaves bouncing them off eachother canceling out the higher frequencies and amplifying the bass.. they definately flow better than stock but its more show(sound) than go definately more backpressure than a "turbo" style muffler
go get a nice magnaflow/borla straight through muffler i think enthuzacar.com has the borlas for 109 each and you can find the magnaflows even cheaper than that.. route your exhaust as straight and short as possible and watch the near instant boost! turbos hate backpressure. the whole reason they work is high pressure on the engine side+ heat and low pressure on the exhaust side and is cooler. another benifit is with a good flowing exhaust you can see an addition of around 1-2 psi in some cases
EDIT: hmm you posted the graphics right as i was typing
Dange is offline
Old 11-26-2006, 04:08 PM
turbo muffler should be less restrictive. The one you posted isn't a traditional design. it usually has core travels throughout the entire space instead of straight through. but they still usually flow high CFM ranges +400 and the exhaust flow doesn't run into any obstructions.
what brand did you get?
Old 11-26-2006, 04:59 PM
Hah. Well that's good news to me. I've got a hooker turbo- though I HAD to get the offset/center setup because I've got the exhaust coming straight out the back. That's how most of the offset/center designs work. Add to that there's only 13-1/2" of space to shove it in and I'm limited to what will fit. Fortunately hooker makes their turbo mufflers 13" long instead of the standard 14". The idea to go straight out the back happened when my Miata was rear ended. The bumper skin was scraped up so I figured that was the time to try it. It was easy with a 2-1/4" exhaust, but now I'm stuck using a more restrictive muffler (that the turbo design above) to get it to fit.
My exahust is 3" from the wastegate housing exit to the tail pipe, with two bends- a 90 coming down from the turbo, and a 90 going back to the rear. I'm running a cat, resonator (glass pack) and this new turbo muffler. I'm still amazed that the flowmaster style muffler doesn't flow as well as a "turbo" style muffler. Maybe I've been watching to much SpikeTV? But the way the turbo spooled up, I'm a believer.
Old 11-26-2006, 05:08 PM
I bet it sounds better too. I put a $20 turbo muffler on my altima.
Old 11-26-2006, 05:15 PM
That "flowmaster" was WAY loud. My wife got in the car for a ride back when I was only running 8psi and that muffler (way quicker than anything she's rode in)- I got on it and the first thing she said, "Your car is LOUD". Never mentioned anything about the acceleration. I'm amazed at how much I can hear the turbo now too. I only got a taste of this quicker spool and my clutch fragged on me! At least that's what I think it is.
Old 11-26-2006, 06:18 PM
Yeah- straight through doesn't get any better. The two factors that sent me to this turbo muffler now is the 13" can length AND the $25 delivered price. You can't buy a 3" muffler for cheaper than that and it looks about the quality of a dynomax (yeah, I know that's not say much). - rob
Old 11-26-2006, 06:57 PM
TurboTim's Avatar
Total Cats: 399
My 40 series (2 chamber) flowmaster was never loud, and with the turbo it is very quiet. I really do not like loud exhausts at all. I have heard flowmasters are not good for turbo 4-cyl cars but it doesn't make much sense to me and I never saw any proof. Soon I will be redoing my exhaust and using a straight-thru style muffler due to space problems. If I get better spool, great! If it's louder or sounds like ***, it's for sale!
TurboTim is offline
Old 11-26-2006, 07:17 PM
boostinsteve's Avatar
I love the flowmaster that I have on there now, super 40 series, I am going to put a cat on it when I get the dp, and that should make it just a mild rumble. Flowmasters are some of the shittiest flowing mufflers as far as performance goes, but you pay for the sound. Although the magnaflows sound wicked as hell.
boostinsteve is offline
Old 11-26-2006, 07:23 PM
Kelly's Avatar
Magnaflow for the win.
Kelly is offline
Old 11-26-2006, 09:07 PM
Well I've got datalogs from the chambered muffler and WILL have datalogs after with this turbo muffler. Same map, the only thing changed is going from dino oil to syth. The only thing that might be different is ambient temp- but it was 70f here today and the car felt totally different. So I should be able to make a good comparison.
The chambered muffler that was on there sounded absolutely badass when I was on it- very throaty. BUT the rest of the time, under normal driving, it was just a loud droning, around town or on the interstate. I want something I can take a road trip in and still hear the radio.
Old 11-28-2006, 07:40 PM
Dange's Avatar
try unbolting your muffler and take a pass up and down the street and see how much faster that spools, if you like it go get a straight through, the reason the flowmaster was probably so loud is it resonates..ALOT... so you get metric but ton of noise inside
Dange is offline
Old 11-28-2006, 07:45 PM
I had a straight pipe and that was the loudest- but I never ran any boost when it was that way. I can datalog- that should the difference between the two mufflers since nothing else was changed.
Old 11-28-2006, 08:54 PM
RusMan's Avatar
I have full 3" exhaust with one aspec straight through muffler, it's amazingly not that loud, well at least in the car, outside its way loud, but I thought it would be much louder. It's maybe just a tad louder than my old 2.5" with cat, silencer, and a muffler.
RusMan is offline
Old 11-28-2006, 09:38 PM
Yeah- I don't know. I saw your exhaust pic and it's very similar to how mine is laid out. I had people saying that I'd only need a resonator if I was running a cat. It was so loud like that, two people couldn't talk to eachother. With the turbo muffler now it sounds quieter than most aftermarket Miata exhausts, which means it'll sound great in a year (or less). I also think one thing that makes it louder is having the hard top on. I think the resonance from that chambered muffler would come through the bulkhead and just bounce around interior. I think the fiberglass goes a long way towards reducing the interior resonance transmitted by the muffler. I know I don't care for as loud a Miata as most, so that's part of the issue. -rob
Old 11-28-2006, 09:50 PM
PaKMaN's Avatar
Straight piping FTW.
No cats, No resignators, No Mufflers
PaKMaN is offline
Old 11-28-2006, 10:06 PM
Kelly's Avatar
Yeah when you can hop in your G35(lucky bastid) whenever you wanna drive something that sounds nice you can afford to go that route.
Kelly is offline
Quick Reply: more restrictive muffler = quicker spool?
