TD04 Oil Drain Flange
I know some of you want this flange so you can do a nice oil return line.
http://store.function-7.com/catalog/...7db55a4990abed
Sometimes Function7 sells them cheaper on eBay:
http://cgi.ebay.com/ebaymotors/Funct...spagenameZWDVW
WOT, would this be the correct item for my greddy http://cgi.ebay.com/ebaymotors/Funct...QQcmdZViewItem
Is the gasket necessary (additional $3)?
It would make sense that the GT series flange would work, Function 7 lists that as on of the turbos their flange works with. The only issue will be the allen bolts, the TD04 take 6mm and the GT 8mm. I can source those myself
I'm going to try this flange and see if it works.
ATP-FLA-010 (flange)
GRT-GSK-008 (gasket)
I think the flange is tapped for 1/2 NPT
Jay
Jay
Total Cats: 6,593
I bought the version with the -10AN male thread from the same guy. Very nice piece of hardware. Felt like it was made out of solid stuff, not cast pot metal, and well machined.
Canadian Distributor
Function-7 has a Canadian distributor. The reason why shipping is so expensive is because of duty. While you can get around paying duty by "Gifting" an item, you'll be hard pressed to find companies that are willing to do that as part of thier standard business practice.
Visit the distributor's website at:
http://www.bepcanada.com
Thanks for the link,
Jay
Can someone edjumecate me on what exactly this part does? I'm a little confused. On the ebay link, it states "These flanges can also be installed on the oil pan, secured by nut and bolt so no welding is required!", but it sounds like you guys are talking about installing them on the turbo housing itself. Thanks.
