china 2854
Old Jan 29, 2012 | 11:18 AM
flounder's Avatar
Total Cats: 31
Default china 2854
Quick question for those in the know.
I have a build thread going in the media section(99, 1.8L) and I was wondering if 250whp is doable on a 2854? Before I install the engine, I may upgrade to a larger turbo if I will have difficulty hitting that #.
Assume that I will have adequate fueling and timing control and at least a full 2.5in exhaust.
Thanks!
Old Jan 29, 2012 | 11:33 AM
dustinb's Avatar
That number shouldn't be a problem at all assuming you don't have a restrictive exhaust.
buffon01's Avatar
Total Cats: 13
I saw a 1.6 do about 220whp with said turbo. You can look up Tyson87 (I think) older set up and dyno runs. However, I saw a 2870 do +250whp. This was the older set up of Levnubhin. Both these number were obtained in a Mustang dyno and were not corrected IIRC.
I haven't dyno my set up which is a 99 stock motor with a 2870 at 15psi, but I should be in the neighborhood of your power goal. If you're a happy with seeing full song after 3.5 - 4k rpm the 2870 is a good option with good head room if you're motor is built.
Old Jan 29, 2012 | 01:43 PM
flounder's Avatar
Total Cats: 31
I was hoping to see 250whp by 15 psi on the 2854. I know that the power increase going from 8 psi to 11 psi was impressive, I'm wondering where peak efficiency is on this guy?
Old Jan 29, 2012 | 02:01 PM
I'd say even if you did hit 250, it would be completely tapped out at that point.
So I'd definitely go bigger.
Chooofoojoo
Sep 13, 2015 10:01 AM
SuperSneakySecretSquirrel
Meet and Greet
Sep 6, 2015 08:30 PM
levnubhin
Feb 27, 2010 07:54 PM
tyson87
Jul 12, 2009 04:51 PM
