Will this turbo work ok?
Old May 1, 2009 | 12:58 PM
saitrix's Avatar
Default Will this turbo work ok?
Hi,
I was thinking about using a T25 for my turbo on my 1.8 and I just thought of a cheap car to take it off. In the UK you get the Rover 220, 420, 620 and 820 all with the same 2.0 turbo engine, with the turbo being a T25. I have had a search and couldn't find any info on here, but I have found the specs for the wheels on a parts website. I don't know how to interpret the numbers though so if possible is anyone be able to tell me whether it has suitable specs?
Compressor Wheel, Garrett - TB2555
Many thanks.
Edit - Trying to find turbine wheel as we speak, also found out the A/R which is 0.49.
Old May 1, 2009 | 01:04 PM
gospeed81's Avatar
Total Cats: 26
If you really want to know...find and plot a compressor flow map.
Find the map, calculate what your flow rates are for 3000rpm and 7000rpm for a given pressure ratio(whatever you plan on running) and draw a straight line connecting those two points. If this line "goes through the center of the island" you're fine as long as the upper rpm point isn't against a surge line, in some really low efficiency, or a really high compressor wheel speed.
Old May 1, 2009 | 01:05 PM
turbomclovin's Avatar
you shouold be fine and that should spool on your car.
Old May 1, 2009 | 01:06 PM
gospeed81's Avatar
Total Cats: 26
start here if you really want to learn:
Compressor Flow Maps and Calculations
Old May 1, 2009 | 01:16 PM
saitrix's Avatar
gospeed81,
Thanks , seem to be struggling to find anymore info though. :( Will carry on looking.
Old May 1, 2009 | 01:18 PM
gospeed81's Avatar
Total Cats: 26
Yeah, I did a quick look, didn't find a whole lot.
If you can't find it, find something with the same trim numbers and turbine in a T25 (should be damn easy) and work off of that.
Old May 1, 2009 | 01:22 PM
saitrix's Avatar
Yeah, also what parts are the important bits to measure? I may know someone who has as broken one.
Old May 1, 2009 | 01:33 PM
gospeed81's Avatar
Total Cats: 26
It almost looks like a T2 in size...kinda small, but some of us still go fast with small turbos ;P
You would also want to measure the turbine wheel inducer and exducer.
Then look for a map with those wheel sizes in a T25 housing. Here's a start:
Turbo Size Comparison
Old May 1, 2009 | 01:59 PM
sixshooter's Avatar
Moderator
Total Cats: 3,591
Come with me if you want to live.
Turbo Size, A/R and Trim
Post #1 and post #8 have good info and good links.
Old May 1, 2009 | 02:13 PM
Rafa's Avatar
Damn Shooter; as usual, you not only post good pics but good info!
BTW, I owe you big time with the coolant reroute info!
Old May 1, 2009 | 02:17 PM
saitrix's Avatar
Awesome, thanks for that!
Old May 1, 2009 | 03:32 PM
gospeed81's Avatar
Total Cats: 26
holy ****...finally found it
http://www.not2fast.com/turbo/maps/t25_55_saab.gif
Now follow sixshooters instructions and get some PR plots on there, see what you can run, and if it breaths all the way to redline.
Old May 2, 2009 | 04:41 AM
saitrix's Avatar
Woah did not expect to find that. Is the T025 = TB25? Sorry I am not brilliant with the code numbers. I will do that later today and see how it is.
Old May 5, 2009 | 08:14 PM
saitrix's Avatar
Looks like it cannot flow enough for my engine that turbo. Was worth a try.
satisfied
144
Nov 5, 2018 04:05 PM
FAB
Prefabbed Turbo Kits
216
Mar 22, 2017 04:00 PM
elesjuan
Nov 3, 2015 01:51 PM
nelson8708
11
Sep 6, 2015 09:49 AM
