I might have just figured out my oil leak
Old Aug 19, 2010 | 12:46 PM
Default I might have just figured out my oil leak
Ok anyone who went to the miata meet at steves knows i have an oil leak, the leak was anywhere from .6-1 quart per 100 miles, it only leaked at high speed/pressure, and got slung around everywhere under the hood from the crank pulley.
I thought it was the crank seal but upon disasembly all the usual **** that is slick and oily when that fails was dry and in great shape. Then i noticed a new hole in my BE oil pump i geuss they used a different housing etc.
anyway here is my 1.6 stock oil pump
and here is my new BE oilpump after i jb welded the extra bolt hole
I measured the depth of the hole and it goes damn near all the way through so I thought it was worth a shot. Once the jbweld has cured i will post an update. Thoughts etc. anyone else seen this problem?
Old Aug 19, 2010 | 12:48 PM
this has been discussed... that's your leak for sure.
Originally Posted by Savington
M8x1.25x45mm. Someone posted a video of their motor squirting a *stream* of oil out of that hole when revved.
Originally Posted by kotomile
Old Aug 19, 2010 | 12:53 PM
ahh i thought so but most of what i saw was the **** for the AC compressor bracket wich i have installed with all bolts etc. I looked for nubbins thread but i didnt find it thx scot.
Old Aug 19, 2010 | 12:59 PM
im the king of search.
Old Aug 19, 2010 | 01:01 PM
so should i take out the jb weld or do you think i will be ok?
Old Aug 20, 2010 | 12:06 AM
well wtf did no one have any insight? Like i said before this is in the same area but it is a bolt hole that my stock **** did not have and all the bolts that i ran on my stock **** are installed. So lumping me into the mess of people who just didnt put there **** back together with all the bolts they needed to get the job done is BS. Seriuslly why do i even ask questions if you guys wont take what the **** i post serius?
Old Aug 20, 2010 | 12:11 AM
Bryce's Avatar
Total Cats: 35
It appears that I'm almost 12 hours too late, but I would've gone and found a bolt of the appropriate length and put that in there. Non-AC equipped Miatas have a shorter bolt in that place.
You're effectively shorting yourself some clamping load (or at least uniformity) on the oil pump to engine block seal.
Old Aug 20, 2010 | 12:31 AM
AC equiped all the time and bolts properly installed and torqued. Little **** like this drives me crazy.
Old Aug 20, 2010 | 12:34 AM
Bryce's Avatar
Total Cats: 35
Ah, different hole than what I thought. Mine has a press-fit plug in that hole. JB-weld should be fine then. I was working on sealing up my oil pan and pump today on the bench but found out I didn't have the oil pump o-ring or the pickup tube gasket. FML.
Old Aug 20, 2010 | 12:41 AM
bryce ty so much that was all i wanted was for someone to actualy look at the problem. I am just as savvy as the next .net user but an extra set of eyes actualy looking at the situation helps a ton, it's not like i have 10 turbo miatas within a 50 mile radius that i eat lunch with every day.
Old Aug 20, 2010 | 01:06 AM
Total Cats: 7,549
Has that little crack always been there on the end of the crankshaft?
Old Aug 20, 2010 | 01:14 AM
MartinezA92's Avatar
Yup, I was losing about a quart every 1k miles through that same hole. Stuck the appropriate bolt in there and I'm leak free.
Old Aug 20, 2010 | 01:31 AM
there is a crack where? i didnt even notice one tell me where, and i will go back out to make sure it isnt a trick of the light. Or left over loctite etc
Old Aug 20, 2010 | 01:58 AM
Total Cats: 7,549
Just pulling your chain.
Old Aug 20, 2010 | 01:59 AM
Bryce's Avatar
Total Cats: 35
Joe made a funny! Hahahaha
Old Sep 4, 2010 | 08:10 PM
Ok so after predigous amounts of jbweld, locktite, and, time etc the car still leaks oil i verified that it is comming out from beneath the crank pulley so at this point im probly gonna be pulling the motor and redoing the pan. you gotta love this ****.
Old Sep 4, 2010 | 08:11 PM
ouch man. good luck. just have someone weld that ho up once and for all
Old Sep 4, 2010 | 09:17 PM
Bryce's Avatar
Total Cats: 35
I know that sucks! I ended up buying a 2.0 to fix my leak. You might as well reseal the oil pump while you have the pan off.
Old Sep 4, 2010 | 10:00 PM
Lord of the Gays.
Apr 21, 2016 03:00 PM
Aroundcorner
Oct 1, 2015 03:20 PM
mx592
1
Oct 1, 2015 12:45 AM
JesseTheNoob
Sep 30, 2015 02:44 PM
zephyrusaurai
Sep 28, 2015 10:59 PM
