DIYPNP deleting 1.6L CAS
Old May 16, 2012 | 09:28 PM
mrpham's Avatar
Default DIYPNP deleting 1.6L CAS
Hey all.
Very new to this stuff so please bare with me.
I have a 1990 Miata but I'm using a NB 1.6L engine but currently with the NA6 CAS at the back of the head. Since I have a DIYPNP now, I would like to remove the old CAS and run the camshaft position sensor at the front of the valve cover and the crank position sensor at the front of the block instead. I have all the bits required.
Is this possible with my DIYPNP? If so, what settings do I need to run in TS?
I'm also using Toyota COPs using the IG1 IG2 ALED and WLED outputs.
Cheers
John
Old May 17, 2012 | 09:11 AM
All u need to do iis run those sensors in place of the cas inputs. Changee the ignition settings from rg6e to 99-0 miata and your done.
Old May 17, 2012 | 09:22 AM
mrpham's Avatar
Thanks Braineack!
Old May 17, 2012 | 12:01 PM
Total Cats: 7,560
Scott, did you type that message by mashing the keys on your phone with a stick from 10 feet away?
Old May 17, 2012 | 12:38 PM
Pretty much...on phone
bigmackloud
Jan 8, 2021 11:24 AM
The Gleas
Oct 1, 2015 09:30 AM
viriiguy
General Miata Chat
Sep 28, 2015 07:39 PM
