GT2871 FS $725
mkturbo.com
Total Cats: 1,681
GT2871 FS $725
I have a Garrett GT2871 that is several years old, but I was told has zero miles on it. It was test fitted on a Protege then removed and put on a shelf. It has zero shaft play and the blades look amazing. The hot side housing does have some surface rust. When I got it the waste gate was welded shut, after cleaning the housing I noticed it was not welded well. After a little grinder action it went back to swinging open perfectly. It will need a internal wastegate actuator and arm if you want to run internal gate, or welded again if you want to run an external gate. It has a t2 flange. It is larger then what I want to run or else I would keep it and use it myself.
Measurements are not exact, it was hard holding a camera, the caliper, turbo, and taking the picture. They are about a mm off.
Official Garrett CHRA tag
Oil Inlet
Wastegate after I got rid of the welds.
I would like $725 shipped to the continental 48 states or best offer.
Oil Inlet
Trade for a professionally rebuilt and begi ported Garrett 2560? Already drilled for 10mm inconel as well. Is it safe to assume the wastegate flapper on yours seals and works well?
mkturbo.com
Total Cats: 1,681
I am assuming that the wastegate flapper still seals, but I don't have a real way to test. I honestly might shoot Garrett and email asking how to replace it to be on the safe side. If there was a built motor in the car this would be going in I would have no problem using it myself as is.
mkturbo.com
Total Cats: 1,681
Bump. I am open to reasonable offers. I am also looking for the following items for trading a Begi coolant reroute spacer, forged rods, rx8 injectors, 12x12 intercooler, and a ms3x. Or if you have other interesting miata go fast bits feel free to offer them up, the worst I can say is no.
mkturbo.com
Total Cats: 1,681
It is still around, sitting on a shelf waiting for my motor to get back from the machine shop. I picked up this turbo thinking it was a disco-potato, then found out it was a 2871, and I rather have my cash back, then have a spare just sitting here.
kronikker
10-06-2015 10:18 PM
jrmotorsports55
08-23-2014 08:44 PM
300zxrb26dett
02-26-2014 01:56 PM
