Garrett GT2560R and accessories $500
Old 08-04-2015, 10:48 AM
TurboTim's Avatar
Total Cats: 399
Default Garrett GT2560R and accessories $500
My darling Garrett GT2560R. Save it from my attic. $500 + shipping.
Many highway miles. The tips of the turbine blades are slightly eroded so they are thinner/lighter so quicker spool than a new turbo. bwhahaha.
Radial and axial end play is barely measurable and well within Garrett spec. This thing probably has 10 years left on it, especially if you store it in your attic. The max boost I've ever run on this is 14psi. Most of the time it was 8psi on my old subaru.
Includes GM boost control solenoid and connector, fancy billet banjo coolant fittings, ATP restrictor -4AN oil supply fitting, -8AN oil drain fitting. Original wastegate actuator that's been bent and reworked countless times to fit the half dozen setups this turbo has been used on, and a brand new Garrett wastegate actuator.
I purchased this turbo from FM's supplier, Limit Engineering. Limit Eng. machined the compressor housing flanges to use standard slip fit hoses like we all are used to...2.5" inlet, 2" outlet. So no goofy adapter pieces required to attach your air filter and intercooler pipes.
Attached Thumbnails Garrett GT2560R and accessories 0-gt2560_1.jpg   Garrett GT2560R and accessories 0-gt2560_2.jpg   Garrett GT2560R and accessories 0-gt2560_3.jpg   Garrett GT2560R and accessories 0-gt2560_4.jpg   Garrett GT2560R and accessories 0-gt2560_6.jpg
Garrett GT2560R and accessories 0-gt2560_7.jpg   Garrett GT2560R and accessories 0-gt2560_8.jpg
TurboTim is offline
Old 08-04-2015, 02:25 PM
BrandonL's Avatar
Total Cats: -2
PMed
BrandonL is offline
08-30-2017 09:50 PM
jpreston
05-17-2016 12:51 AM
LucaCarMods
02-14-2016 06:13 AM
ihiryu
General Miata Chat
09-28-2015 10:22 AM
Quick Reply: Garrett GT2560R and accessories $500
