EBC mod - Writeup
EBC mod - Writeup
Components needed:
(1) MOSFET IRLZ44 (IRLZ44NPBF-ND)
(1) 100ohm resistor
(1) 10k resistor
(1) diode 1N4002 (1N4002DICT-ND)
(1) Fast activing 3-Port valve (boost solenoid) gmpartsdirect.com part #1997152
MegaSquirt MB side:
Gate (pin1) goes to JS2. Installed with the 100ohm resistor inline.
Drain (pin2) goes to IAC2A which goes to pin 29 on the DB37 connector. From there you'll wire out of the DB37 connector to a wire on the solenoid.
Source (pin3) goes to the ground. I used the ground of the proto area.
Install the 10k resistor between Pin 1 and Ground.
Mount the FET to the case somewhere and use some heatsink compound to keep it cool. I used a heatsink and used the proto area.
Pictures:
Solenoid side:
I haven't gotten this far. But what you'll do is wire the diode between the DB37 source wire and +12v wires of the solenoid. This is suggested to filter out voltage spikes.
The Cathode (or silverbar) goes to the positive wire.
MS software side:
Set Closed Loop kPa to 0, this uses the duty cycle targets to control boost, the kPa targets have been known to not work as well. The higher the % in the row, the higher the boost.
(1) 100ohm resistor
(1) 10k resistor
MegaSquirt MB side:
Pictures:
Solenoid side:
MS software side:
I already have the FM solenoid so i didn't add that, but yes...as seen here:
http://forums.turbobricks.com/showthread.php?t=80599
This is the solenoid duty cycle table you asked me about.
Remember, this is set for my falling boost. If you use my settings, you'll break your ****. I've also included the boost control parameters menu.
Cautiously implemented, this table *should* be applicable to other greddy cars wanting to run 14 psi.
Using a GM Typhoon 3 port solenoid, but any should work.
damn you're right...i used the wrong reisitor....good catch....it's fixed...I had to flip the FET around and bend the pins 90* so the heatsink could fit under the case anyways....it was about 1mm too tall, so no worries.
another note....for the duty cycle target....since I'm not using a TPS, I'd basically only need a 0% and 100% rows correct?
Am I correct in thinking that when boost control in enabled, "output 1/boost" should be green, much like "Fuel Pump on" and "FIdle/spark" are on the MT main page? Or, will "output 1/boost" turn green when conditions for boost control are met, like pressure going above ambient?
I've triple checked everything and cannot get the soleniod to cycle.
Does anyone know of a supplier similar to GMParts in the UK? GMParts wont ship outside of America :(
Also where does the solenoid get plumbed in? If someone could show me on a diagram similar to this (http://home.comcast.net/~phantoms/va...rbo_system.jpg) I'd appreciate it.
You replace the MBC...so between the boost source and wastegate.
FWIW, I'm not using the GM solenoid...I'm using a Flyin' Miata one...
It's ARO brand, very similar to this: http://airinc.thomasnet.com/viewitem...ies?&forward=1
and this to be specific: http://flyinmiata.com/index.php?dept...7;20%201990-97
ok I lied, best price I could find was $27 here: http://www.grainger.com
part#6jj52 however they have the exhaust port "muffler" spongy thing, which I'm thinking about ordering if the vavle is loud at all.
FWIW, I used a new GM solenoid and it failed on me after about 2 months of use...dunno why.
