Im Looking for some info?
Old 02-18-2007, 10:22 PM
RicanmiataRacer's Avatar
Total Cats: -1
Default Im Looking for some info?
Saab 9000 2.3 Garrett T25 T2 turbo , A/R is .48 and a turbine A/R of .49
I need to find some specs on this model for a friend , I've looked all over the damn place and I cant find anything, can you guys help point me in the right direction?
RicanmiataRacer is offline
Old 02-18-2007, 10:27 PM
samnavy's Avatar
Total Cats: 322
Whaddya mean "specs"? You just listed the specs. What exactly do you need. Do you want a flow chart or what? .48/.49 is the same specs as a 2G DSM T25. The CHRA's should be a direct swap.
samnavy is offline
Old 02-19-2007, 12:15 AM
MX_Eva's Avatar
the only other stuff you could really figure out is if it's water cooled or just oil, what kind of flanges, and ball bearing or not (which it's not). I guess you could also figure out what it's actuator holds to.
MX_Eva is offline
Old 02-19-2007, 05:52 PM
Total Cats: -1
I just needed info like stock set boost levels and max psi the turbo can handle, or even how much horse power this thing can flow.....Im not sure at all because I've found nothing useful in the saab forums, my friend is using it on his 1.8 sentra.....
mikeflys1
10-27-2018 02:19 PM
nick470
7
06-16-2017 01:53 PM
Squiblez
09-22-2015 10:17 AM
ndragun
09-20-2015 10:28 PM
Quick Reply: Im Looking for some info?
