Tach Output Pin
Old Jun 30, 2007 | 02:11 AM
grippgoat's Avatar
Default Tach Output Pin
So, I built the circuit described here:
http://megasquirt.sourceforge.net/extra/tachopin.html
But it didn't make my tach work. I have 94 wiring and dash.
I played with it on my little proto board (the kind where you have two power and ground rails, and it just has a bunch of holes you can stick components into to test circuits), and with 12v connected to pin 3 via a 1k resistor, and pin 1 connected to ground, there was only 9v across pins one and 3. When I put +5 to pin 2 via 1k resistor, voltage dropped basically to 0 across pins 1 and 3. So if I understand properly, this should be generating a 0 to 9v square wave at pin 3, which is what I connected to the tachometer wire that goes to the diagnostic connector, the tachometer, and would normally attach to the coil (but I have a 2000 coil).
Anyone know how to make this work?
-Mike
Old Jul 1, 2007 | 02:36 PM
mazdasly75's Avatar
You know your tach need to be fed by a negative coil signal to work properly. If you have multi coil (coilpack), you need to build this:
Old Jul 2, 2007 | 01:01 AM
grippgoat's Avatar
Nah, I figured out the problem today. I messed up the circuit. I connected the DB37 to the wrong side of the resistor on the 12v side of the 2n2222. So basically, I was just always sending the tach 12v. Once I switched the output wire to the correct end of the resistor, the tach worked fine.
-Mike
Old Jul 2, 2007 | 01:05 AM
sly75
thanks for the diagram; that makes so much sense.
COPS are in my future.
Old Jul 7, 2007 | 04:54 PM
mazdasly75's Avatar
No problem dude, all diagrams are available through the different manual that msefi.com share
Zaphod
47
Oct 26, 2018 11:00 PM
slomiata
Oct 7, 2015 01:11 PM
viriiguy
General Miata Chat
Sep 28, 2015 07:39 PM
JacksonRacingEngines
10
Sep 10, 2015 09:52 AM
