front bumper removal
Old 10-20-2007, 05:48 PM
Dow.tom's Avatar
Default front bumper removal
Okay i cant get it out... I've taken so many nuts bolts off it's unbelieveable. Where are the hidden nuts. I've taken 1 under each headlight off, is there another? It seems to pull free in the middle and the bottoms sides, but the top corners wont budge
Dow.tom is offline
Old 10-20-2007, 06:56 PM
paul's Avatar
i've had mine off 3 times in the last 2 mos and trying to remember.
8 14mm bolts hold it on to the bumper support.
6 10mm bolts that hold the metal frame to the "Radiator support" section
2 10mm nuts(1 on each side) that are way out to the ends of the bumper under the headlights in a horizontal front/back orientation
4 10mm nuts (2 per side) inside fenders that attach to front bumper. remove wheel well liners to get to them
2 10mm bolts (1 per side) holding those bars that attach the lower bumper to the frame so it doesn't flex
that should be it
paul is offline
Old 10-20-2007, 08:05 PM
Total Cats: 6,608
You got the two nuts on each side that are accessible only after you remove the fender liners? Sounds like those are the ones. First time I forgot them and had the same problem as you.
Joe Perez is offline
Old 10-21-2007, 07:12 AM
Dow.tom's Avatar
yeah my liner is still in, i only took off the one covering the washer fluid. so i'll try that
Dow.tom is offline
Old 10-21-2007, 07:26 AM
WhiteNA6's Avatar
Hahah I just finished going through this a few days ago installing a new driverside fender. Oh man taking off those little nuts that hold the bumper inbetween the headlight and frame is ridiculous. I just left them off, but assembled everything else back on.
WhiteNA6 is offline
Old 10-21-2007, 09:15 AM
Dow.tom's Avatar
there's only one of those on each side right?
Dow.tom is offline
Old 10-21-2007, 10:09 AM
reddroptop's Avatar
Behind the liners? No, there is 2 on each side.
It is not hard. I had it off in 30min with no instructions, doing it the first time.
Its not like they are "stealth" fasteners or some ****, you look what is holding it in, and you unbolt them.
reddroptop is offline
Old 10-21-2007, 11:08 AM
Dow.tom's Avatar
okay it's off... enough bolts just snapped heh. so i'll address that later.
Now that it's off which cross member does the intercooler normally mount to?
http://s93.photobucket.com/albums/l52/dow-tom/My%20Mx5/
Which is in these pictures?
Dow.tom is offline
Old 10-23-2007, 04:22 PM
Dow.tom's Avatar
buimp
Dow.tom is offline
Old 10-23-2007, 04:34 PM
Total Cats: 6,608
Everyone does it differently. I made a bracket for mine that mounts to where the A/C condenser would normally go: https://www.miataturbo.net/forums/sh...ht=intercooler. The best pictures are at the bottom of the thread in post # 36.
FM's website and instructions illustrate a different method, worth checking out.
Old 10-23-2007, 04:43 PM
SamS's Avatar
Mine had a bracket welded to the top of the IC which I bolted to the hood latch bracket. I also built 2 brackets for the bottom which riveted to the IC and bolted to the radiator.
Dunno if that helps with your setup or not.
SamS is offline
Old 10-23-2007, 11:30 PM
rappadan's Avatar
and the easiest way(or the drifters way) to put it on is say 4 of those 10mm bolts on the top. and 1 med. sized zip tie on the corners where it meets the fender. Easiest/quickest way for speedy removal/installation
rappadan is offline
Old 10-24-2007, 12:02 AM
Dow.tom's Avatar
well i test fit it in and no luck, so im gunna go to the dark side... WI
Dow.tom is offline
Old 10-24-2007, 12:09 AM
Giving up pretty easy. What makes it not fit. Just way to large or do it just bump into the A/C dryer?
bigmackloud
01-08-2021 11:24 AM
Quick Reply: front bumper removal
