Manifold to turbo bolts coming loose?? WTF?
Old Feb 6, 2008 | 01:04 PM
Doppelgänger's Avatar
Total Cats: 71
Default Manifold to turbo bolts coming loose?? WTF?
So i developed a small exhaust leak last week and found it to be the 2 bolts on the right, top and bottom (if facing the turbo/mani) were loose. No problem, just fight with the FM heat shield like there was no tomorrow and tighten. Then fight with the FM heat shield again to get it back on. Done.
Well i just came back from lunch and opened the hood to hear the same leak AGAIN! Is there a way to combat this? Safety wire? Suggestions?
Old Feb 6, 2008 | 01:06 PM
spike's Avatar
Call up FM and order up some stover nuts and nord-lock washers.This combo with never come loose.
If you wanna go extreme you could go with stage8 fasteners.
Old Feb 6, 2008 | 01:07 PM
Nordlock washers. I was able to get mine by mailing the Nordlock directly and asking for a sample. Or you can buy them from FM.
Old Feb 6, 2008 | 01:11 PM
spike's Avatar
I think I'm gonna try that next time I need some.
Thanks for the tip Jay.
Old Feb 6, 2008 | 01:23 PM
Total Cats: 71
yah... on i'll call FM and hope they send me the right stuff. Who knows, maybe they'll goof my order and send me a turbo kit instead lol.
Old Feb 6, 2008 | 01:26 PM
BenR's Avatar
http://www.aircraftspruce.com/catalo...ywirekits1.php
Old Feb 6, 2008 | 01:30 PM
Total Cats: 327
Don't buy that **** from FM. They charge some retarded amount of money. Get them at Fastenal: http://maps.google.com/maps?hl=en&um...e-results&cd=1
Old Feb 6, 2008 | 01:31 PM
Newbsauce's Avatar
I call bullshit on the FM washers. I've had crazy problems with fasteners on mine rattling loose. On my previous setup I was rocking FM washers (thanks SamNavy) with the threaded nuts. They held for longer then the regular nuts and locking washers, but last week I realized one was missing and had managed to backthread off completely! I eventually will need to move to the wire locking setup or just start nitching my threads lol.
Old Feb 6, 2008 | 01:42 PM
They worked well on my Greddy kit, with 3/8" exhaust manifold studs.
How much are they from Fastenal?
Old Feb 6, 2008 | 01:53 PM
sv650_ck's Avatar
If these are the same, they're pretty inexpensive
McMaster-Carr Part No. 93795A240
Class 8 Zinc-Plated Steel Conical-Top Locknut Hex, M10 Screw Sz, 1.5mm Pitch, 17mm Width, 10mm H
In stock at $4.52 per Pack
This product is sold in Packs of 25
Old Feb 6, 2008 | 02:22 PM
DEI liberal femininity
Total Cats: 574
weird. I use the 80,000 mile stock exhaust nuts with no problems.
Old Feb 6, 2008 | 02:34 PM
That be the nut, not the washer.
Old Feb 6, 2008 | 03:05 PM
bryantaylor's Avatar
i just use plain ole lock washers
Old Feb 6, 2008 | 03:47 PM
gtx510's Avatar
Don't most 10mm nuts/bolts have 14mm heads? Is it tough to tighten those Mcmaster nuts since the head is 17mm? On my GTX I had to grind down a closed-end wrench to get to one of the turbo nuts.
Anyone tried SS nuts like Corky suggests?
Old Feb 6, 2008 | 04:21 PM
barryb's Avatar
Safety wire. There's a reason high-reliability systems use it (look at any airplane or helicopter).
I used safety wire on my current BEGI system and after 3 1/2 years and >60,000 miles I KNOW the studs and nuts haven't loosened.
Stover nuts or equivalent on the studs works great until the studs back out...happened to me on my last setup and I ended up ruining an exhaust manifold. Yes, I realize that if the studs are torqued properly the studs should not back out. If the nuts are torqued properly they should not back off. Coulda, shoulda, woulda. $500 for a manifold...safety wire and drill bits are a heck of a lot cheaper.
Just do it. It only takes an extra half-hour.
Barry
Old Feb 6, 2008 | 06:10 PM
Total Cats: 327
^I'll buy that, nice first post.
This is another good thread I started... check out Post#32. I had enough leftover that I even mailed a couple sets out to dudes for free after that.
https://www.miataturbo.net/forum/sho...light=nordlock
Old Feb 6, 2008 | 06:57 PM
AbeFM's Avatar
Total Cats: 13
Barry
Oh, ah, so the stud and the nut are wired?
Wow that sounds like a good idea. I really loved my nord locks, for a while... In theory they would hold the stud in too. :-) But after a couple uses they don't always hold - there are two kinds and I think I have the cheap ones. Fm sells the "good ones" for a whole lot more, I doubt it's justified, but I will admit mine are worn a bit flat.
Old Feb 6, 2008 | 08:21 PM
crashnscar's Avatar
Total Cats: 9
8mm studs dont even stay in the manifold, and if they don't back out they crack.
Get 10mm studs and be done.
Old Feb 6, 2008 | 08:52 PM
AbeFM's Avatar
Total Cats: 13
If I ran the universe there woudln't be studs, there would be nuts and bolts. Those always work fine, and gives you a lot of options for locking
