First Start (help me)
Old Jul 22, 2006 | 01:48 AM
Loki047's Avatar
Total Cats: -5
Default First Start (help me)
So everythings hooked up. I tried starting the motor but Im getting no oil pressure (nothing out of the oil feed line either). There is oil in the motor, and the motor wont stay on by itself (can be kept on with throttle) any ideas?
Old Jul 22, 2006 | 02:04 AM
F20turbo's Avatar
you should first prime the engine before starting. I had to crank mine for about 45 seconds to get pressure to the head. If you have an oil pressure gauge wait until you see a blip from it so you know you have pressure. Then start it.
Old Jul 22, 2006 | 02:19 AM
Loki047's Avatar
Total Cats: -5
Well we cranked it a few times but not for 45 seconds, ill try that tomorrow, thanks Mr. Floyd. Any other tips?
Old Jul 22, 2006 | 01:07 PM
Loki047's Avatar
Total Cats: -5
Alright I cranked it for 45 seconds but still nothing, again the motor will come to life and die right away (without oil pressure)
Old Jul 22, 2006 | 01:16 PM
Philip's Avatar
Total Cats: -4
vac leak on the motor.
can't say on the OP.
Old Jul 22, 2006 | 01:20 PM
CRX's Avatar
CRX
Disconnect the coil pack so you won't get spark. Put in a autozone mechanical oil pressure gauge, so you know that it's not your stock opg messing up. Then crank till you have oil pressue, if you don't get oil pressure, bigger things going on.
You DO have oil in the motor, right? :gay:
CRX's Avatar
CRX
ANd the afm is hooked up, right?
Loki047's Avatar
Total Cats: -5
Well dying motor i can deal with, dead no OIL pressure is osmehitng I cant.
Old Jul 22, 2006 | 01:22 PM
Philip's Avatar
Total Cats: -4
this is the first start after what? A turbo install or an engine swap?
i'd tend to think you forgot to plug in the pressure sending unit.
Old Jul 22, 2006 | 01:52 PM
Loki047's Avatar
Total Cats: -5
no we check its plugged in (turbo) and no oil from feed line
Old Jul 22, 2006 | 01:55 PM
Loki047's Avatar
Total Cats: -5
Alright I know what im doing today (yes theres oil)
Old Jul 22, 2006 | 01:58 PM
brgracer's Avatar
You didn't happen to knick the oil pickup line when tapping the pan (if you tapped the pan that is)?
Old Jul 22, 2006 | 02:28 PM
Loki047's Avatar
Total Cats: -5
I did tap the pan I dont think i did, i was extremely careful not too. I can take the tap out and check.
Old Jul 22, 2006 | 02:41 PM
Loki047's Avatar
Total Cats: -5
**** ME!! I dont know how I did that. Salvagble? What do i do now?
Attached Thumbnails First Start (help me)-img_0015-medium-.jpg   First Start (help me)-img_0016-medium-.jpg   First Start (help me)-img_0017-medium-.jpg
Old Jul 22, 2006 | 02:50 PM
Loki047's Avatar
Total Cats: -5
what material is that can i just throw a bead on it?
Old Jul 22, 2006 | 03:33 PM
F20turbo's Avatar
damn that sucks, I dont know what it is. I want to say brass, but i think thats just because of the color of it since its oil stained.
Old Jul 22, 2006 | 03:48 PM
spike's Avatar
HOLY ****!!! if you hit what I think you hit while drilling,your in for a shitload of work to replace the oil pick up tube.
Old Jul 22, 2006 | 04:41 PM
Philip's Avatar
Total Cats: -4
nah, rough it up and JB weld it. She'll hold.
Old Jul 22, 2006 | 04:58 PM
olderguy's Avatar
AFM Crusader
Total Cats: 364
I'd try that before pulling the engine
Loki047's Avatar
Total Cats: -5
thats what im thinking
