FS: Fully PnP Megasquirt N Spark Extra V2.2 ECU for 96-97
Old 03-29-2007, 12:38 AM
iWeasel410's Avatar
Default FS: Fully PnP Megasquirt N Spark Extra V2.2 ECU for 96-97
I unfortunately will not be able to pay rent for next month, so my goodies have to go. Up for sale is a MSnSe V2.2 as a full plug-n-play setup for 96-97. Included is the ECU with all of the settings and maps currently running 029v, I will also supply the MSQ file. EasyTherm has already been set to use the Mazda CLT and a Ford IAT. An approximately 2ft wiring harness to install the MS right next to your stock ECU, and an extension harness for the OEM ECU where all you do is plug in the MS ECU harness. It is set up to run the OEM CLT sensor, and the appropriate bias resistor mod was done. The coil input and output mods were done following the DIYAutoTune website tutorial. A TIP120 was installed so that the Mazda idle valve can be used as well. I can also supply my wiring diagram for a 97 miata with appropriate pin colors and locations. Both the MS harness wires as well as the ECU extension harness wires are labeled. Here are pics:
So in summary, you'll be getting a MSnSe V2.2 ECU running 029v, the MS Harness all set up, and an OEM ECU extension harness, all set up. The mods are the input and output (ala diyautotune) for the 1.8l coils (spark settings have also been set as per NathanM-Ed's settings), TIP120 pwm mod, and OEM CLT bias resistor mod.
It'll take longer to put together a mounting setup next to the OEM ecu than it will to install the MS, ask me how I know The entire system can be swapped from MS to OEM in a few minutes by just disconnecting and reconnected the insulated bullet terminals.
I'm asking 550 obo + shipping which should be around 10$ within the US via USPS Priority Mail. I'm in Los Angeles so local pickup is also available. I can take PayPal, but prefer not to because of their lame fees, personal checks will take a week to clear, and money orders or cash are always great.
iWeasel410 is offline
Old 03-29-2007, 12:39 AM
iWeasel410's Avatar
Also note the long purple wire on the MS harness is for your IAT since it'll be put under your hood.
Old 03-29-2007, 12:46 AM
iWeasel410's Avatar
Here's how I had it installed in my car before I connected the wiring:
Old 03-30-2007, 09:05 PM
iWeasel410's Avatar
Bump it up, taking offers as well.
Old 04-01-2007, 08:24 AM
petersdd's Avatar
please call me 541-663-6119
I cant send pm's yet...not enough posts
david
petersdd is offline
Old 04-01-2007, 08:40 PM
iWeasel410's Avatar
I'll take off 50$ if you don't want the 96-97 harness. I'll also take best offers.
Old 04-03-2007, 02:36 AM
iWeasel410's Avatar
How bout 500 for everything or 450 for the MS and MS wiring harness?
Old 04-05-2007, 03:49 AM
iWeasel410's Avatar
Bump, I need to sell this soon before my rent bill comes. I've had a lot of inquiries but no one has come through yet.
Old 04-05-2007, 06:24 PM
grp44's Avatar
have you had this running in your car? Any problems? I may be interested.
grp44 is offline
Old 04-05-2007, 06:43 PM
grp44's Avatar
I cant PM you, Call Me.
Mike 813-389-1340. If we can make a deal, I can wire you the cash.
Thanks Mike
grp44 is offline
Old 04-07-2007, 03:09 AM
iWeasel410's Avatar
bump
Old 04-10-2007, 09:21 PM
iWeasel410's Avatar
Bump, I can sell the MS unit by itself for a reasonable price, give me an offer.
Old 04-10-2007, 09:48 PM
supra441979's Avatar
how hard is it to change this to work with 90-93?
supra441979 is offline
Old 04-10-2007, 11:31 PM
iWeasel410's Avatar
You'll just need to wire it in parallel with your stock ECU, I can take care of most of the megasquirt settings.
Old 04-12-2007, 01:30 AM
iWeasel410's Avatar
still available
Old 04-12-2007, 01:34 AM
Pitlab77's Avatar
bump for a good deal
Pitlab77 is offline
Old 04-15-2007, 05:03 PM
iWeasel410's Avatar
My MS has been sold! Thanks!
bigmackloud
01-08-2021 11:24 AM
The Gleas
10-01-2015 09:30 AM
Big_gumby
09-30-2015 03:34 PM
Goldwar
09-29-2015 09:20 AM
Quick Reply: FS: Fully PnP Megasquirt N Spark Extra V2.2 ECU for 96-97
