ACL race bearings alternative
Old Jul 16, 2013 | 10:52 PM
Impuls's Avatar
Total Cats: 19
Ahh now I must stop myself from buying more stuff from sav. ><
I'd use clevite. The wait for ACL is very long.
My opinion - ACL > Clevite 77 > King.
From me lurking and reading around about the subject.
Someone is putting nice bearings, usually with nice internals I'm sure, doesn't change their oil or even use **** oil? Come on now. :P
Old Jul 17, 2013 | 01:20 AM
RyanRaduechel's Avatar
Total Cats: 149
Clevite bearings in mine. I also have them in my 8000 rpm small block Mopar. I have never had a bearing failure. Although both cars do run oil coolers and the Miata uses a Moroso remote oil filter with a big *** GM filter on it. To each there own.
Old Jul 17, 2013 | 12:47 PM
joyrider's Avatar
If the big guys in Cali do it for their car, I'll do the same and don't worry about it....
Now please find me main STD bearings and I'll pay the beer + parts !
Old Jul 17, 2013 | 02:04 PM
soviet's Avatar
Total Cats: 269
Finally got around to this. It'll be on our new website once that's up and running, but just PM me for now.
Sav,
Would you keep or get rid of the stock water oil cooler when installing this?
Old Jul 17, 2013 | 03:05 PM
joyrider's Avatar
There's no one "correct" place to put the cooler, so the best solution is to just send you a bunch of line and fittings and have you decide exactly where to mount the cooler. N/A cars should put it in direct airflow in front of the radiator. Turbo cars should put it above the intercooler. Turbo cars with A/C should get creative.
Parts list:
  • Mocal sandwich plate with 180* T-stat, 1/2"BSP to -10AN adapters, and proper Dowty seals
  • 10ft of Setrab -10AN line
  • two Setrab -10AN male 90deg hose ends (sandwich plate side)
  • two Setrab -10AN M22 male 90deg hose ends (cooler side)
  • Setrab 6-series cooler with proper Setrab-specific rubber isolated mounting bracket
Three options for cooler size:
10-row for N/A cars in direct airflow (or ducted). $400
16-row for turbo cars in direct/ducted airflow. $430
25-row for those individuals with questionable judgement. $475
10 row in front, 25 in back
I do have a LONG brand oil cooler, seems to work well with spal fan, oil when turbo wasn't too hot. Didn't like the need of Spal fan for it thought.
Here's what I have : IMG_20130717_090207.jpg?t=1374087501
How I do plan the future install :
Sanstitre.png?t=1374087543
But I do need an engine and for that ACL race main bearings... find me one please !!!!! Going back to call different shop and Miata teams...
Old Jul 17, 2013 | 04:45 PM
bigben's Avatar
If you find 2 engines let me know...
Old Jul 17, 2013 | 06:40 PM
Sorry, there's no comparison between the tube/plate style that you have and the Setrab style. I've used both and you can get away with a Setrab that's 1/3 the size of a tube/plate cooler to get the same amount of cooling done.
OEMs use Setrabs for a reason.
Old Jul 17, 2013 | 08:00 PM
joyrider's Avatar
I do have the one I just I bought but I need to open it to know what happened at Tremblant, rod gone or wrist pin and check if there's damage...
Sav, I know it should be more efficient then what I got, on the wish list for this winter... great product development, thank you guys.
Mahle is the owner of ACL and Clevite from I read... clevite 77 tri metal are not available for miata... bummer
Old Jul 17, 2013 | 08:22 PM
Total Cats: 2,621
this
.33 SNR
Old Jul 18, 2013 | 10:26 AM
joyrider's Avatar
Well nothing in Canada or USA for main bearing... King or clevite ?!?
Emilio, do you know when my order will ship ? (17321)
Old Jul 18, 2013 | 10:54 AM
Oscar's Avatar
Total Cats: 120
Contrary to the bulk of my parts, the ACL bearings showed up in 2 days
Old Jul 18, 2013 | 08:07 PM
joyrider's Avatar
The thing is ACL from Australia is for sale...
BUT Clevite do some tri metal since last year for Mazda BP
http://www.mahle-aftermarket.com/C12...24_8-17-12.pdf
Rod Bearings
CB-1453H
Main Bearing Set
MS-1802H
Thrust Washer
TW-472S
So I did order everything.
Old Jul 23, 2013 | 10:36 PM
Total Cats: 2,621
Default ACL Race @ 949 Racing
We are now a stocking dealer, everything they make for the B6 and BP.
ACL Main Bearing Miata
ACL Rod Bearing Miata
ACL Thrust Washer Miata
.33 SNR
Old Jul 24, 2013 | 06:24 PM
joyrider's Avatar
I order everything from you except these, good news as I will probably need some when I rebuild the other scrap yard engine that blow after 2 track days :(
Old Aug 24, 2015 | 02:08 AM
Hot_Wheels's Avatar
Total Cats: -34
Is there still a shortage on these or did acl finally re stock?
Old Aug 24, 2015 | 11:44 AM
They restocked and then went on backorder again.
emilio700
Wheels and Tires
151
Jun 2, 2017 02:36 PM
ihiryu
Sep 28, 2015 10:22 AM
