Something more Imaginative?
Old Mar 3, 2014 | 02:55 PM
  #141
Jeffbucc's Avatar
Total Cats: 951
As to the bushings, I didn't think my Miata rode roughly at all and it has every single bushing replaced with poly. As long as you do Zerk fittings when you do them it takes the maintenance pain/anguish issue out of the equation.
Then again I may be slightly spoiled with the "Mythical unicorn tear SD Bilsteins". The car rode better than my Jetta in some cases.
Old Mar 3, 2014 | 03:12 PM
  #142
thasac's Avatar
Total Cats: 44
I've got 10-12kg monoflex (depending on which springs I end up running) ... NHV is not a concern.
I'm more concerned about missing out on significant handling improvements.
-Zach
Old Mar 3, 2014 | 03:29 PM
  #143
hornetball's Avatar
Total Cats: 697
Originally Posted by thasac
B) Is the non-AFM base map for the MSPNP-1 safe to run with an OPEN wastegate? DIY states the map is scaled for boost so I suspect I will be safe. I should note that I would simply be peg legging to car to my personal garage on the base map.
Should be, just take it easy. It's where a lot of us started.
C) Is there an MT approved install for the LC-1 on a 1.6 miata? I've searched the **** out of this subject and I've read mixed suggestions. My current working assumption is to ground at the OEM point under the brake booster, es bueno?
I'd ground to where the OEM ECU grounds. That would be on a bolt near the back, passenger side of the engine. Should be a 10mm bolt there with a bunch of grounds going to it.
Watch out for Error 8. Current LC-1 software will kick this error even if nothing is wrong. Read this: https://www.miataturbo.net/megasquir...-lc-1-a-58873/
D) Poly bushings - worth it? I'm a week away from painting and installing all my front end suspension bits and now would be the perfect time to install poly bushings. This said, my OEM bushings still look good and I'd rather put the money towards a Kirkey seat or door bars or beer . So, for a street/non-competitive track car -is it worth it?
It will give you that last ounce of performance at the expense of added maintenance.
On my rides, Silver has rubber, Red is getting poly. Different missions (Silver has a radio too).
Old Mar 3, 2014 | 05:50 PM
  #144
thasac's Avatar
Total Cats: 44
The LC-1, based on everything which I've read including your own posts, is a huge concern of mine. The good news is I had Abe weld two bungs onto my DP, which allows me to input the LC-1 to the MSPNP and run an AEM sensor/gauge (which should be very accurate). If they don't jive, then I at least know something is 'off'.
I'm also generally paranoid about reassembly now that my father has sold his '90 1.6 (which sat conveniently next to my project) ... it was my assembly reference. Having it there also caused me to get a bit lazy about documentation since he quote, "would never sell the '90". Well, he sold it.
-Zach
Old Mar 3, 2014 | 06:14 PM
  #145
hornetball's Avatar
Total Cats: 697
Well, just give a shout-out when you need reference pictures.
Old Mar 27, 2014 | 01:53 PM
  #146
thasac's Avatar
Total Cats: 44
A minor, and rather uninteresting, update.
Finished assembling the breather tank/BOV lines. I ended up using Summit fittings for non-critical lines since their cheap and I has Summit bucks to burn. I'll use Goodridge PTFE for fuel/oil. Assembly was simple enough (far easier than older Earl's lines).
In other news, it occurred to me that I tossed my OEM washer tank (along with the pump) years ago. Being older, lazier and burdened by additional bureaucracy, I wished to have a car which can easily acquire an inspection sticker ... this meant I needed a washer tank (which I'll likely never use).
So, after realizing I mounted my coolant tank to the OEM washer tank mounting point, I began seeking a plan B. Cappucino and BEGI tanks were too $$$ and held far more fluid then I'd ever need or want on a weekend toy.
I ended up finding some small tanks which worked @ U.S. Plastic Corp (The McMaster of plastic containers, with a shittier interface and a heaping of Jesus). Bought an OEM pump through RockAuto which came with a new rubber seal. 5 minutes with a dremel and boom ... leak-free vented washer tank with a new pump for <$25.
Bottle link, if interested: .50 Quart 3.8H X 5.5313W X 3D | U.S. Plastic Corp.
I plan on mounting it to the back side off the firewall behind the booster. I didn't want to add additional holes to my already holey firewall so I picked up some SS elevator bolts off McMaster-Carr which I'll epoxy to the wall with some 3m dp-420 epoxy (metal epoxy with super high shear strength). I'll post picks once completed.
...and the local welder said the tank is ready to go, so I'll be picking that up today and slapping it on. Pics to come.
Audi5k - Zach
Attached Thumbnails Something more Imaginative?-wzhyo4u.jpg   Something more Imaginative?-iknq6dj.jpg   Something more Imaginative?-trixhfp.jpg
Old Mar 27, 2014 | 01:56 PM
  #147
OMG I rub ru wong time for that plastics place. I needed a new coolant reservoir and a catch tank for my new air oil seperator, I just found the place, no more crystal geezer water bottles.
Now to find a tank with a top entry that goes to the bottom for proper use as a coolant overflow.
Old Mar 27, 2014 | 02:12 PM
  #148
thasac's Avatar
Total Cats: 44
Be prepared to receive a prayer pamphlet with your order
How a huge company catering to lab sciences remains overtly anti-secular in 2014 is beyond me.
-Zach
Old Mar 27, 2014 | 02:14 PM
  #149
I blame the south.
Old Mar 28, 2014 | 08:47 AM
  #150
thasac's Avatar
Total Cats: 44
Alright, here's some low-light, high noise, poorly composed pictures of the breather tank.
I need to tweak the lines some and fixture the BOV line; however, I'll worry about that once it's running. I'm thinking about powder coating the breather tank wrinkle black to match the cam cover, but again, I'll worry about that later.
-Zach
Attached Thumbnails Something more Imaginative?-cv43441.jpg   Something more Imaginative?-8fsgnpm.jpg
Old Mar 28, 2014 | 10:36 AM
  #151
Jeffbucc's Avatar
Total Cats: 951
-Zach
Maybe I missed it but how the hell did you hide your wiring so well?
Looks good! I'd leave the catch can raw like that. Really pops as is.
Old Mar 28, 2014 | 10:51 AM
  #152
hornetball's Avatar
Total Cats: 697
Holy Cow!! Are you planning to run without piston rings? LOL.
Looks great though.
Old Mar 28, 2014 | 10:54 AM
  #153
thasac's Avatar
Total Cats: 44
I didn't ... the harness resides in the oversprayed grocery bags currently draped over the firewall.
Once I add the remaining fuel/oil lines and wiring harness, the car will no longer be CR friendly (gotta tuck it, bro). I thought about doing a 'tuck' but then I reminded myself that function>form on this project.
-Zach
Old Mar 28, 2014 | 10:55 AM
  #154
Wire tucks are stupid/impossible on miata's anyways, at least traditional ones that put the wire in the fenderwell are.
Old Mar 28, 2014 | 10:56 AM
  #155
thasac's Avatar
Total Cats: 44
Looks great though.
I know ... it looks huge in the pics. It's not that big in reality, at least volumetrically, due to the internal baffles/filter. Perhaps I should powdercoat it with slimming vertical stripes.
-Zach
Old Mar 28, 2014 | 10:59 AM
  #156
thasac's Avatar
Total Cats: 44
Agreed. I'm just going to mount the bulk of the harness under the chassis fender mounting flange and call it "done".
-Zach
Old Mar 28, 2014 | 11:10 AM
  #157
The worse part is the cluster **** behind the intake manifold. Its not noticeable from the front of the car, but when you're working on the car its just terrible.
Old Mar 28, 2014 | 11:32 AM
  #158
Jeffbucc's Avatar
Total Cats: 951
Everytime I consider pulling apart the electrical tape and redoing it I pull a Homer. There is just no easy way of making it look like someone didn't vomit wires into that spot.
Old Mar 28, 2014 | 11:35 AM
  #159
There is, but it requires re-doing the entire engine bay harness, and If I'm going to do that I'm switching the car to having a seperate engine harness with 3-4 points of disconnection (one for low power, one for high power, two grounds. Using Milspec/motosports connectors. To do it right (my way) is like a $500 project.
Old Mar 28, 2014 | 11:55 AM
  #160
hornetball's Avatar
Total Cats: 697
I'd also add the cluster**** behind the IM is where all the reliability problems are with our harnesses. I've seen rub-throughs there on almost every older harness I've seen.
