turn the knob up to 15X11
Old May 24, 2014 | 12:34 AM
bbundy's Avatar
Total Cats: 146
Default turn the **** up to 15X11
I turned it up to 11. 15X11 with Ύ” offset Keizer Billets. Weigh ~14.2 LB. 275/35/15 Hoosier A6.
The rear pretty much fits as well as a 15X10” the front is a bit tight. 2.25” springs are needed I think and I offset the shock tops inboard by Ό” to cure too much interference between the spring and the rim when turning.
First test pretty much confirmed for me the 275’s like 11” wheels. The traction limit behavior is much improved. Same amazing feel I had with the 245’s mounted on 10” I crushed overall top time and top PAX at a couple regional autocross events with them now. Pressure can be run about 4 psi lower contact patch stays flatter and it’s just easier to transition to and drive at the limits of traction.
Attached Thumbnails turn the knob up to 15X11-20140416_213544-1200x900-.jpg   turn the knob up to 15X11-20140416_213035-1200x900-.jpg   turn the knob up to 15X11-20140416_213116-1200x900-.jpg   turn the knob up to 15X11-20140415_203312-1200x900-.jpg   turn the knob up to 15X11-20140418_191032-1200x900-.jpg
turn the knob up to 15X11-20140418_191128-1200x900-.jpg   turn the knob up to 15X11-20140518_134600-1200x900-.jpg   turn the knob up to 15X11-20140521_214731-1200x900-.jpg   turn the knob up to 15X11-20140521_214757-1200x900-.jpg   turn the knob up to 15X11-20140521_215029-1200x900-.jpg
Old May 24, 2014 | 01:52 AM
Lincoln Logs's Avatar
Total Cats: 64
That is simply amazing...is that a chicken in that one photo?
Old May 24, 2014 | 02:14 AM
bbundy's Avatar
Total Cats: 146
yea I let the chickens out to free range.
Old May 24, 2014 | 02:15 AM
that is a serious machine
i don't think I've seen too many pictures of your car/setup.
kinda surprised not to see a full roll cage or at least a roll bar on there.
Old May 24, 2014 | 02:29 AM
UrbanSoot's Avatar
Total Cats: 18
This is ****! How much did the wheels cost if you don't mind sharing?
Old May 24, 2014 | 09:25 AM
FrankL's Avatar
Total Cats: -2
Coming soon to 275s everywhere...
Old May 24, 2014 | 10:02 AM
thenuge26's Avatar
Total Cats: 239
Of course, it wouldn't be MiataTurbo without a picture of your **** out next to your Miata.
Old May 24, 2014 | 12:26 PM
Doppelgδnger's Avatar
Total Cats: 71
I wants to co-drive your car, Bob!!!
Old May 24, 2014 | 12:43 PM
bbundy's Avatar
Total Cats: 146
I have it convertible between Autocross and track setup. It’s got welded in landing plates for Hard core roll bar and door bars which help make install faster.
For autocross I have it within 10-20lbs of minimum class weight which is 2080lbs for me. For track I add about 150 lb's of stuff. Which takes 3 about hours.
1) Hard dog Hard Core
2) Harness bar
3) Door bars
4) Custom Front shock tower brace
5) Custom Rear subframe brace
6) Accusump
7) Rear Sway Bar
8) Rear wing swapped
9) Shorter Front Splitter/ undertray
For NASA TT2 time trials I run 245/40/15 to take advantage of the HP/weight advantage for 245 and under DOT tires. I also run lower boost to stay just within the HP/weight rule for TT2 class. I can make about 330 Hp or I have to add more weight. Car actually is more reliable on the track with lower boost which is nice. The car is kind of heavy with me in it in track trim compared to some of the other track beasts around the country but it seems to work well. Kind of odd for a Miata but against my current regional competition in time trials I have more HP/weight and lower grip than the BMW's and Porsches running in class on full on race slicks. I am the muscle car.
Old May 24, 2014 | 12:53 PM
bbundy's Avatar
Total Cats: 146
I have a Co-driver. I'm finding once I let people drive my car it works just like crack and I can extract all sorts of stuff like tires, entry fees, and gas.
Your up in this region of the world now. come to Packwood. Saturday June 28th is northwest region SCCA open practice. I don't plan on doing any of the Oregon region events there though just Northwest Region and the VCMC stuff in Canada. Between that a hand full off TTS and Laguna I have a full enough schedule.
Old May 24, 2014 | 01:06 PM
Total Cats: 71
I should be there. My car has been down since Jan and is about to be running again, so hopefully I'll be able to get back into events...if I can find the extra cash for a set of wheels/tires. Unfortunately Im still on the stock torsen, and as I found out chasing you around at the FM Summer Camp...I can reach its limits too easily :(
Old May 24, 2014 | 01:50 PM
2) Harness bar
3) Door bars
6) Accusump
7) Rear Sway Bar
Very very cool. Thanks for the break down.
Old May 24, 2014 | 03:26 PM
FrankL's Avatar
Total Cats: -2
By the way, car looks great! Any plans for nationals in Lincoln?
Old May 24, 2014 | 04:11 PM
So is it faster. Did you test back to back? Making the car 2 inches wider costs a good bit of time.
Old May 24, 2014 | 04:14 PM
FrankL's Avatar
Total Cats: -2
How do you know? Have you tested that?
Old May 24, 2014 | 04:15 PM
Math says it is.
Old May 24, 2014 | 04:19 PM
FrankL's Avatar
Total Cats: -2
Math says it is.
Do you run your 275s on 8s or 9s so your car is narrower?
Old May 24, 2014 | 04:20 PM
No because testing has shown that even though the car is wider its still faster. Hence why I asked if it was actually tested.
Old May 24, 2014 | 04:23 PM
FrankL's Avatar
Total Cats: -2
Old May 24, 2014 | 06:17 PM
bbundy's Avatar
Total Cats: 146
Its not 2" wider really same offset within a millimeter and tire width is the same as I was running with the 10" wheels.
Pictures with the tires stacked are comparing 10" vs 11" mounting.
