Log or ramhorn manifold for EFR6258
Old Jun 19, 2014 | 05:26 PM
Lloyd_D's Avatar
Total Cats: -10
lol no worries
I ran a GT2554 at 14 psi on an HKS log. It hit real hard but did struggle at the top end like a MP62 ;-)
I've been thinking there's so many factors going on.
Manifold volume
Pipe diameter
Number and bend radius of gas direction changes
Package space
Downpipe location, number of bends etc
Cost
Power goal
Its between an equal length ram horn or flow directed collected very short unequal length tubular
I have some 1.25" schedule 10 stainless 304L cast elbows that I'm going with. Quality is good and a machined manifold to head flange from these dudes: Exhaust Head Flange - Mazda - Mazda Miata 1.8 Exhaust Head Flange
Old Jun 19, 2014 | 05:29 PM
I wouldnt use sch10 stainless. I'd contact BMC race to get that same style manifold you linked but custom made as 304 stianless and to the pipe size you're using.
Old Jun 19, 2014 | 05:44 PM
99mx5's Avatar
Total Cats: 526
I have an Artech ramhorm manifold with my EFR 6258. I made 315WHP @ 12PSI and 323WHP @ 14PSI on a Mustang dyno in El Paso, TX (approx 4000' elevation). I also have a 3" exhaust and 2.75" intercooler pipes with a Precision 600 intercooler. This a a mild steel manifold, not SS.
315WHP and 251TQ at around 12PSI (179kPa)
323WHP / 262WTQ @ 14 PSI
There was a problem with my manual boost controller in the second dyno. I could have made more power. I'm now running EBC.
Moar pics of manifold
Old Jun 19, 2014 | 05:47 PM
Ok what in the world is up with the wildly different EFR numbers?
Old Jun 19, 2014 | 05:56 PM
Lloyd_D's Avatar
Total Cats: -10
Wo
That is some manifold. Nice welding on that.
Its almost like with the EFR6258 your forced to go top mount to keep the PS..
I'm hoping to retain it with a tight to head canted orientation similar to Soviet's
The problem is the BW turbo's are a mile long and to clear the body your forced to do unpleasant things
Old Jun 19, 2014 | 05:57 PM
Lloyd, I have power steering with the manifold I have. but my power steering pump is trunk mounted.
Old Jun 19, 2014 | 06:32 PM
HHammerly's Avatar
Total Cats: 63
B nice to see a data log on those numbers, I'm no ware near that HP/PSI ratio.
Old Jun 19, 2014 | 06:37 PM
Total Cats: 1,924
I got in touch with ARTech and ordered the same manifold & downpipe as Swimming108: https://www.miataturbo.net/build-thr...llo-efr-77075/. It looks very, very similar to what Mazdaspeeder is running.
These are Swimming108's pics, not mine:
According to Abe, nothing needs modification to fit this manifold. Its both PS and AC compatible, and should require no modification to the mixing manifold.
Interesting enough, I need to get in touch with Abe as I can't remember if I ordered mine in 1.25 or 1.5. Swimming's looks like 1.5?
Anyway, I honestly don't think it'll make that much difference with my 6258. I'm not shooting for SovietPower™ on the top end. Dem throttle response y0, et cetera...
Old Jun 20, 2014 | 09:07 AM
Mazdaspeeder's Avatar
Total Cats: 70
My manifold IIRC was built by Abe on the specs of 99MX5's manifold. Except I retained PS, pretty sure he did not.
I believe it is sch40 mild steel runners with both flanges being SS, with 1.25" runners.
pre-coat
post-coat
If you want more photos let me know. Here is a link for the coating: http://swaintech.com/race-coatings/r...aust-coatings/
Also just as a personal opinon, with the kind of power the EFR turbos make, you'll be hard pressed to notice a difference between a log or ramhorn maniflold, for most people anyway.
Attached Thumbnails Log or ramhorn manifold for EFR6258-5373d245-651e-4bd4-821b-01d611a68f7a-46599-00000ff96a1e36c8_zpsaffc814a.jpg   Log or ramhorn manifold for EFR6258-null_zpse429dc93.jpg   Log or ramhorn manifold for EFR6258-null_zps87d2fb24.jpg   Log or ramhorn manifold for EFR6258-null_zps1b61e286.jpg   Log or ramhorn manifold for EFR6258-b85a7704-f59b-4a53-9bca-cc9033ce2020-46599-00000ff97983da6e_zpsf6bfb4bf.jpg
Old Jun 20, 2014 | 09:35 AM
shlammed's Avatar
Total Cats: 51
I think you would notice.
I have used both types that I built. The results in this writeup feel accurate from what I had to do to the fuel map in my car.
http://www.full-race.com/articles/Bs...st_writeup.pdf
Old Jun 20, 2014 | 11:57 AM
Lloyd_D's Avatar
Total Cats: -10
That's a good link I read it
It's a compromise then between whether you want the power low or high in the rev range. Bit like the ar ratio on the turbine housing
Old Jun 20, 2014 | 11:59 AM
300rpms for 50fltbs? Seems like an easy choice. AND its not like the tubular setup was making less power than the log even though the tubular wasnt completely spooled because it was making the same power with less boost.
Old Jun 20, 2014 | 03:32 PM
Lloyd_D's Avatar
Total Cats: -10
Very true Leafy very true
Damn it! I've got to buy more elbows lol
Old Jun 20, 2014 | 04:28 PM
shlammed's Avatar
Total Cats: 51
if you order them from somewhere not local, get more than you need. one miss calculated cut and if you don't do a lot of these you might end up with an elbow less than you need.
just voice from someone who has done it.
Now I stock a bunch of them.
Old Jul 10, 2014 | 05:49 PM
Lloyd_D's Avatar
Total Cats: -10
Ok I made something... its a short unequal ramhorn
Volume is about 550cc. Wanted this as small as possible to keep spool good but not limit flow. Angle changes are kept to a minimum. Cylinders 2 & 3 have very little angle change. Cylinders 1 & 4 are as large radius as possible.
http://postimg.org/image/4b4qfhli5/
http://postimg.org/image/7xajs4rvh/
http://postimg.org/image/7cvipfyn1/
http://postimg.org/image/tarzj8dnh/
Stainless MIG welded, she isn't pretty I know
Old Jul 10, 2014 | 06:27 PM
Total Cats: 1,924
Good show, probably better than I could have done.
Time to bust out the dremel and kill some of those weld boogers, last thing you want to do is push those into the turbine. Also, lets get a shot of the inside of that collector.
Old Jul 10, 2014 | 06:39 PM
interesting design.
is that going to clear the steering shaft? looks like it will be super low
Old Jul 10, 2014 | 06:46 PM
Originally Posted by 18psi
interesting design.
Doesnt look that much lower than mine, if at all. I'm more worried about how far away from the engine it is and if its going to clear the frame rail. Like mine is this close to the frame rail.
And this close to the engine block
Holy hell margin rape WTF?
Old Jul 10, 2014 | 07:10 PM
Lloyd_D's Avatar
Total Cats: -10
Its RHD...
Compressor housing is about 40mm off the sub frame. I had to move alot of stuff. PS pipes (reservoir and pump feed), and get the water pump outlet modified. The frame rail lip was also cut back and re-welded.
http://postimg.org/image/m1b0e9ogt/
View image: P1010633
http://postimg.org/image/4pf96kkd9/
http://postimage.org/image/qd47h0krh/
View image: image
http://postimg.org/image/7nc809s0t/
Its been cleaned and smoothed internally as best I can with a long reach die grinder
Old Jul 10, 2014 | 08:14 PM
thats cool
you RHD guys have it so good not having the steering rod there, so much more room for downpipe
