225/45/15 & 245/40/15 Maxxis RC-1
Old Dec 23, 2014 | 01:19 PM
  #101
mx5-kiwi's Avatar
Total Cats: 57
Thanks for the input much appreciated.
Old Dec 23, 2014 | 01:31 PM
  #102
k1l4m's Avatar
Originally Posted by OGRacing
correct me if i'm wrong but the speed chart goes in this order.
fastest
to
slowest
Hoosier
toyo rr - hankook z214 c71(soft)
toyo ra1 - hankook z214 c51 (hard)
toyo r888- maxxis rc1 - nitto nto1
hankook rs3- Bfg rival- toyo r1r
feel free to change this.. i think this is accurate.. maybe
https://www.miataturbo.net/race-prep...hy-chat-76811/
Old Dec 23, 2014 | 02:51 PM
  #103
OGRacing's Avatar
Total Cats: 33
thanks.
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Originally Posted by Mobius
Old Dec 23, 2014 | 08:31 PM
  #104
fastest
to
slowest
Hoosier
Not correct, look at the Tire Hierarchy thread.
Old Dec 28, 2014 | 01:43 AM
  #105
RHD_Tarzan's Avatar
Emelio how do you think the 245 will do on a 9.5 wheel?
Old Dec 28, 2014 | 07:38 AM
  #106
Total Cats: 3,573
You spelled his name wrong.
It will probably work like somewhere between a 9 inch wheel and a 10 inch wheel. The tire works on both. It is just slightly better for lap times on a 10 inch wheel with a good driver.
Old Dec 30, 2014 | 01:44 AM
  #107
1999NB's Avatar
Total Cats: -4
Do we know if the 245 rc1 on the 10" +25 fits the NB with track camber (3* front / 3.5* rear) without flares? I know they fit without much on the 9", but the 10" will make a bit more interference...hence why it's better/faster.
Old Dec 30, 2014 | 11:43 AM
  #108
Total Cats: 2,620
No flares in this pic. Flat rolled fronts, rolled rears. No pull. Most folks assume our 15x10 was optimized for 275/35 Hoosiers. Our 10's were designed around the 245 RC-1 which was still two years away. Everything just fits.
https://www.miataturbo.net/wheels-ti...3/#post1184755
.33 SNR
Old Dec 30, 2014 | 12:09 PM
  #109
tomiboy's Avatar
I have never understood offsets very well. Can I assume a 10", with a +10 offset will not hit my sways and TSE brake ducts, if my 9" 6ULS don't?
Thanks E!!
Old Dec 30, 2014 | 12:32 PM
  #110
1999NB's Avatar
Total Cats: -4
Excellent - then I'll have them mounted up on the 10" ULs for an event at Laguna this weekend with fresh RC1s. I see you stated this earlier in this thread as well; sorry for the repeat. :(
Did you end up liking 36psi HOT the most? I've read "34-38psi" target pressures.
Thanks E!!
Your 9" 6ULs are a +36 offset; you're comparing them to a 10" +10 offset. The outer part of your 10 will sit 38mm more OUT (towards the fender) than the 9" 6UL (fender flare?). You asked about the inside though; you will have 14mm of additional INNER clearance with the 10" +10 vs the 9" +36. You've basically moved the centerline by 26mm, then added 12.5mm on each side due to the 1" larger wheel.
Old Dec 30, 2014 | 02:10 PM
  #111
tomiboy's Avatar
Thanks!! That is what I was hoping!
Old Dec 30, 2014 | 03:31 PM
  #112
Total Cats: 2,620
Thanks E!!
1010TIRES.COM - Wheel Offset Calculator
I use a pyrometer to dial in pressures.
.33 SNR
Old Jan 7, 2015 | 01:01 AM
  #113
Mobius's Avatar
Total Cats: 365
I've been trying to find the answer to this question - are the RC-1's directional? If they are not, I can rotate them any old way, and get lots of life, and that's glorious. My two tracks pound the Left Front. Toyo RR's are directional, and must be rotated diagonally on a RWD car, which resulted in the LF/RR pair cording at the end of the season while the other pair still had a couple of events at least in them.
Old Jan 7, 2015 | 01:29 AM
  #114
Total Cats: 2,620
RC-1's not directional and not subject to tread splice weakness like the RR, Rival et.al
.33 SNR
Old Jan 7, 2015 | 05:34 AM
  #115
ThePass's Avatar
Total Cats: 1,237
Aaaaah I can't wait!
Mounted pics soon hopefully
Attached Thumbnails 225/45/15 & 245/40/15 Maxxis RC-1-img_1750_zps05f63bb7.jpg
Ryan Passey
Old Jan 7, 2015 | 08:12 AM
  #116
hornetball's Avatar
Total Cats: 697
That said, the grooves are not symmetrical, so the tires do have an outside and an inside. Can't flip them on the rim.
+1 on tread splices. Been pounding on mine, no visible splices whatsoever. I can usually get rivals to show splices in a session or two.
Old Jan 7, 2015 | 09:27 AM
  #117
Seefo's Avatar
Total Cats: 48
I don't see why it matters which way you mount them. care to enlighten? Unless maybe you use one side of your tires more than the other...which will be camber dependent.
Old Jan 7, 2015 | 10:17 AM
  #118
hornetball's Avatar
Total Cats: 697
The outside of the tire has a larger slick area. Tire sidewall is prominently marked "outside." My "theory" is that this was a design choice by Maxxis to try to provide the largest, slickest profile possible on the outside of the tire where most cornering loads are carried. Helps to make up for the hard compound that they use.
I wear the outside of my tires more than the inside regardless of camber. Obviously, aggressive camber helps to reduce the difference. I've got as much front camber as I can get on the car without going to offset bushings/adjustable length control arms/etc.
Old Jan 7, 2015 | 11:57 AM
  #119
DeerHunter's Avatar
Total Cats: 2,329
If you wear the outside significantly faster than the inside, wouldn't you extend the life of the tire by flipping them inside-out? I've done this with my NT-01s (and RA-1s before that). I understand that it might not be optimal, but the tread will be semi-slick across the surface by then anyway.
Old Jan 7, 2015 | 12:00 PM
  #120
ozbrock's Avatar
Total Cats: 40
I decided to paint the letters on mine while I'm waiting for my RS3's to completely wear out. Probably going to do 2-3 more autocross events on the RS3's before I mount the 245's
