Idle valve Idea for JRSC m45 kits
Old Oct 6, 2014 | 12:20 PM
zacktrotter_uncc's Avatar
Total Cats: -156
Default Idle valve Idea for JRSC m45 kits
The long hose running from the IAC -> check valve -> intake elbow
also you think about the vaccum from the supercharger in the intake elbow were the iac valve line is tapped in
kind of a lot the Idle valve has to overcome
When we deccel we get a droop in idle, some of us almost to stall out
When i look at my data logs, the Duty cycle of the idle valve is "twitching" from open to close in idle.
Really not 100% if this is the soul reason why, but it could be possibly or at least contributing to it.
Either way, The long hose just plain gets on my nerves, its wedged in between my headlight housing and scrunched over my brake lines
My idea is to just delete the line, put a check valve directly on the Idle valve port and then a small filter
so it cant leak boost, or breath in dirty/contaminated air
Here is a stupid little picture I drew, you see the current set-up and then what I think i might try
Attached Thumbnails Idle valve Idea for JRSC m45 kits-untitled_zps87bc5b51.png
Old Oct 11, 2014 | 09:19 PM
lexintexan's Avatar
Total Cats: -9
Did this work / help with idle droop?
Old Oct 13, 2014 | 06:25 PM
Total Cats: -156
I never had a chance to try it.
But...i posted the same thread on miata.net and found that this would only slightly help the iac valve recover, compared to just doing a dual throttle set-up.
The reason the iac fails at hard deccel with an m45 is because the valve opens back up while there is still boost, which throws it off.
When you do a dual throttle mod or a mp62 remote mount iac, you get the iac to never see boost. Thats how you fix it. And the plan that i presented still does help, and free up a little bit of room/complexity
Old Oct 20, 2014 | 06:33 PM
Total Cats: -156
Old Dec 30, 2014 | 03:57 PM
DonPlatt's Avatar
Total Cats: -19
zack. I just picked up an m45 sc kit for a 96 miata. It seems complete except it is missing the IAC Check valve and the short hose end. Any idea how I locate these missing items?
Old Dec 31, 2014 | 09:17 AM
Total Cats: 4,370
an MS3 with a few minutes tuning the idle control would work better.
Old Dec 31, 2014 | 02:38 PM
DonPlatt's Avatar
Total Cats: -19
Default Idle check valve idea
I have no idea what an ms3 is....
Old Jan 3, 2015 | 07:45 AM
mx54life's Avatar
Total Cats: -1
Call TDR.
Old Jan 20, 2015 | 10:35 PM
Ted75zcar's Avatar
Tweaking Enginerd
Total Cats: 384
TDR sells them.
The dual throttle body solves the idle problems of the stock JRSC, and creates a bunch of new fun challenges.
The solution posted earlier here screws the air flow meter up.
Old Jan 21, 2015 | 04:25 AM
richyvrlimited's Avatar
Total Cats: 42
Only if you're running the stock ECU & a piggyback/bandaids.
Old Jan 21, 2015 | 08:19 AM
Ted75zcar's Avatar
Tweaking Enginerd
Total Cats: 384
True. Or more correctly, if you aren't running speed density or alpha-n.
Old Jan 23, 2015 | 01:43 AM
DonPlatt's Avatar
Total Cats: -19
I'm in the process of prepping my 1.8 for mounting the M45 supercharger. New timing belt & waterpump. I was thinking about mounting the voodoo box for fuel management & MSD prior to doing the SC. What's the consensus?
Old Jan 23, 2015 | 09:21 AM
Ted75zcar's Avatar
Tweaking Enginerd
Total Cats: 384
I would agree with the approach. You may even go one step further and do the fuel management first, timing second, SC third. That way you can hopefully isolate issues that pop up. I am not familiar with the voodoo, but if you are running tan tops at stock rail pressure on a 1.8, you will run over 80% duty cycle pretty quickly. You may want to run an aftermarket fuel pressure regulator and pressure gauge to boost your pressure. Definitely check the fuel pressure even with the stock regulator. You will certainly want wideband.
Does your SC kit have any boost upgrades?
Old Jan 23, 2015 | 10:44 AM
Total Cats: 4,370
you mispelled that.
voodoo box + MSD is spelled: DIYPNP
Old Jan 23, 2015 | 10:49 AM
Ted75zcar's Avatar
Tweaking Enginerd
Total Cats: 384
Ha Brain, baby steps man. He will come around as the aspirations mature. Full standalone is intimidating at first.
Old Jan 23, 2015 | 11:55 AM
Total Cats: 4,370
no it's not.
Old Jan 24, 2015 | 12:38 PM
DonPlatt's Avatar
Total Cats: -19
I'm running stock pulleys on the SC. I will start the work on voodoo first. Do you really think I'll need a fuel pressure setup. I will buy a boost gauge, but only after everything is up and running
Old Jan 24, 2015 | 12:54 PM
Ted75zcar's Avatar
Tweaking Enginerd
Total Cats: 384
Do you have a wideband? What altitude are you at?
Old Jan 24, 2015 | 02:50 PM
Ted75zcar's Avatar
Tweaking Enginerd
Total Cats: 384
And it is a fuel pressure gauge, not a boost gauge
An m45 on a 1.8 is not going to boost much more than about 4 psi. If you are at sea level you will need to supply ~30% more fuel than stock to run at 12.5 A/F. I have seen stock tan tops get wiggy after extended 90% + duty cycles, this was on a 1.6 @ ~ 7.5 psi, afr 12.1, 3 bar fuel pressure ( manifold referenced)
If you were in Denver (like me) it is only a <20% increase in duty cycle.
I would really recommend corky bell's book "supercharged" if you don't already have it. It will help you to understand the basics of fueling among other things. I have seen them used on Amazon for really cheap. It was the first book I bought when I got started, and I couldn't put it down.
Old Jan 25, 2015 | 07:12 PM
DonPlatt's Avatar
Total Cats: -19
I'm located in pennsylvania, close to sea level. So you're suggesting I replace the tan top?get a aftermarket fuel pressure regulator and fuel pressure/air mix gage?
