Coolant Reroute for Race car
Old Mar 24, 2015 | 01:59 PM
YeboGoGo's Avatar
Total Cats: -11
Default Coolant Reroute for Race car
Admittedly my miata is just a miata engine.
I have no heater core. Would not miss the throttle body getting bypassed (unless there is something I dont know?)
Going to add a megasquirt and blower soon but my real reason is I need the space on the front and hotside of my engine bay!
Does anyone have a diagram that eliminates the heater core and gets the engine bay cleaned up ?
I have no problem getting to the back of my motor.
Thanks
~J
Old Mar 24, 2015 | 02:34 PM
dcamp2's Avatar
Total Cats: 69
I'm no expert, but this should get you started:
You should be reading THIS STICKY:
https://www.miataturbo.net/race-prep...-thread-79930/
Old Mar 24, 2015 | 02:53 PM
YeboGoGo's Avatar
Total Cats: -11
I took a look at that.
Few things I didnt see:
1. no heater core option
2. no throttle body coolant delete.
Are there any issues with deleting #2?
Old Mar 24, 2015 | 03:00 PM
dcamp2's Avatar
Total Cats: 69
You didn't read very well.
POST #21 of STICKY THREAD ON COOLING:
Originally Posted by hornetball
No issues with deleting the coolant lines to the TB. Those lines are meant to heat the idle control valve to prevent ice formation under certain high-humidity conditions. Has no impact at all on engine cooling. I run without them on both cars and have never had an issue -- so the icing phenomena is rare.
Old Mar 24, 2015 | 03:03 PM
YeboGoGo's Avatar
Total Cats: -11
Yep.
Was just reading thru and noticed that. Was planning to come back after and edit that.. Busted
Didnt see heater core (yet..) and wondering about the oil filter part too.
Old Mar 24, 2015 | 03:04 PM
The answer to your heater core question is at the bottom of his diagram.
Old Mar 24, 2015 | 03:39 PM
Total Cats: 1,410
You'll wanna loop the Heater core lines, not cap them. So you have water flow until the thermostat opens.
Old Mar 24, 2015 | 04:22 PM
dcamp2's Avatar
Total Cats: 69
Doesn't the thermostat have a small flow opening even when it's closed? Maybe that could be drilled out a little to compensate for a lack of heater line passageway? (If the OP wanted to completely delete the heater lines)
Old Mar 24, 2015 | 04:25 PM
Would water flow through turbo lines be enough?
Old Mar 24, 2015 | 07:19 PM
Total Cats: 1,410
Yes to both, although if youre eliminating the heater core, you might as well just loop them. Otherwise the "proper" way would be to weld the mixing manifold and rear cover, both are kind of a pain
Old Mar 24, 2015 | 09:50 PM
YeboGoGo's Avatar
Total Cats: -11
Do you have a picture or reference of that? My main driver is getting rid of hoses and freeing up space under the hood
Old Mar 24, 2015 | 10:09 PM
brainzata's Avatar
Total Cats: 17
Man, just look at your heater hoses, disconnect the ends opposite of the heater/firewall.
-Then disconnect the ends attached to the heater tubes.
-Buy a 12" piece of 5/8" heater/coolant hose, connect one end to the connection at the rear of the head, the other end connects to the long metal tube that you disconnected from under the exhaust manifold.
-Cut hose to length and connect
-Now go remove your heater core and crap.
Old Mar 24, 2015 | 10:21 PM
YeboGoGo's Avatar
Total Cats: -11
Im a bit list on half the comments. Part of me thinks it's attitude and the other half thinks it's me doing a bad job of explaining. Here is my current setup
So what I need is less coolant hoses so I can get that supercharger to mount under the hood . Think the $16 reroute thread may be the ticket!!
Attached Thumbnails Coolant Reroute for Race car-img_20150324_221709_zps50ofaxyd.jpg
Old Mar 25, 2015 | 12:16 AM
Total Cats: 1,410
What's the long line over the header? If that's the old heater core return line, you'll wanna loop that to behind the head, which is looks like you already have? I can't tell.
Old Mar 25, 2015 | 06:09 AM
YeboGoGo's Avatar
Total Cats: -11
Correct. And that's that's primarily what needs to move
Old Mar 26, 2015 | 08:21 AM
YeboGoGo's Avatar
Total Cats: -11
Anyone know of an alternate to the lower coolant neck?
I am looking for one that goes the other direction
Thanks
~J
Old Mar 26, 2015 | 08:43 AM
Preluding's Avatar
plug the hole and flip if around if you aren't running AC i believe.
Old Mar 26, 2015 | 11:14 AM
Total Cats: 1,410
Yeah it's common to flip them. But it almost looks like it is in your pic. Can you light up the lower part of the engine and actually take a picture that shows us something? Take the stupidcharger out of the picture too.
Old Mar 26, 2015 | 11:25 AM
ThePass's Avatar
Total Cats: 1,236
Yep, I drilled mine out to 1/4", no alternate water pathways for recirculation before Tstat opens other than that small hole. Works great, On a street car I would probably even step down to 3/16".
-Ryan
Ryan Passey
Old Mar 26, 2015 | 06:28 PM
comradefks's Avatar
Total Cats: -2
I drilled a hole in my thermostat as well. Also ran my heater core inlet directly to the water pump inlet but put a reducer inline to simulate the pressure drop through the heater core. Don't know if the second part is really needed but was simple and seemed to work.
