Camber Adjustable Front Upper Control Arms
Old May 13, 2015 | 10:36 AM
smurfmiata93's Avatar
Default Camber Adjustable Front Upper Control Arms
Paco Motorsports has developed Camber Adjustable Front Upper Control Arms and is getting ready to test them. These are the same people that make the adjustable rear upper control arms for Flyin'Miata.
Old May 13, 2015 | 12:18 PM
Thats cool. Too bad anyone running man sized tires already have clearance issues on the upper inside.
Old May 13, 2015 | 02:10 PM
guttedmiata's Avatar
That depends on wheel back spacing. So I wouldn't say "anyone".
Also depends partially on spring rate.
I'm probably running bigger tires than anyone else here.
Old May 13, 2015 | 02:30 PM
Mine
Old May 13, 2015 | 02:31 PM
Hmmm... I pad wouldn't let me attach 2 pics
Old May 13, 2015 | 02:47 PM
OGRacing's Avatar
Total Cats: 33
the v8 roadsters has adjustable lower... makes camber changes easy.
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Originally Posted by Mobius
Old May 13, 2015 | 05:27 PM
No, if they're not nearly hitting at full bump stop compression either your bump stops are too long or you're making the car wider than necessary. I dont care what your spring rates are, sure I rub less now that I went to 1000s in the front but still big bump on the outside wheel right as I start to come off braking and turn in will still make the rub. But even properly setup with 15x9 and 225 streets its an issue.
Old May 13, 2015 | 06:07 PM
TNTUBA's Avatar
Total Cats: 283
I run man sized tires on man sized wheels with offset UPPER bushings and I don't have anywhere near the rubbing issues you have. I still contend that your tub must have been hit hard at some time in it's past.
Old May 13, 2015 | 06:10 PM
It was and I've fixed it to the point where I rub no more than any other average tub. I just somehow create more suspension movement than you.
Old May 13, 2015 | 11:37 PM
I don't hit bumps off of braking, before braking, or any other time.
What are bump stops?
I'm sure I'm running less back spacing than you. My track is wider for sure just due to the wheel and tire width alone. So does that mean it's wider than necessary? How do you define what is necessary? To run the tires I'm running it's necessary. Sure, I could run tires smaller than the rest of my class, but that just seems silly now doesn't it?
Old May 13, 2015 | 11:54 PM
Until the arm fails.
Zaphod
47
Oct 26, 2018 11:00 PM
stoves
Apr 21, 2016 03:00 PM
russian
Oct 8, 2015 03:01 PM
