Ian's 99 build thread
Old Jun 29, 2015 | 05:46 PM
  #281
Total Cats: 1,924
I feel a sudden urge to drill a hole in my m-tuned rail and install a damper.
Old Jun 29, 2015 | 06:38 PM
  #282
patsmx5's Avatar
Total Cats: 559
Thought on everything you just posted:
NA miata's had no damper, but had regulator on fuel rail.
NB miatas' had regulator far from fuel rail, and had a damper close to fuel rail.
Doesn't a fuel pressure regulator act as a damper in some way? If so having it closer to the fuel rail would help.
Just some thoughts, I dunno I've never measured fuel pressure on my car.
One last point- in the same log you just posted, AFRs are rock solid. I wonder if the AFRs between cylinders are too?
Old Jun 29, 2015 | 06:44 PM
  #283
Total Cats: 1,870
<p>
</p><p>Dibs on it, when you inevitably&nbsp;screw it up and buy a new one? </p>
Old Jun 29, 2015 | 06:59 PM
  #284
Total Cats: 887
NBs have *two* dampers, one on the rail, one on the fender. The regulator has to sense the drop in pressure and mechanically adjust for it, the more volume there is after it, the larger the lag introduced before it can do that. Putting the regulator on the rail gives it very little lag, so it can respond to injector events more quickly.
AIUI, wideband O2 sensors don't have the response time of a lot of other sensors. The fuel pressure sensor I'm using will do 1KHz, widebands aren't anything like that. That's part of the reason it appears more solid, but yeah, I'm concerned about pressure drop for individual injectors making individual cylinders go lean.
Old Jun 29, 2015 | 07:01 PM
  #285
patsmx5's Avatar
Total Cats: 559
I will continue fuel discussion in your new thread: https://www.miataturbo.net/engine-pe...5/#post1244814
Old Jun 29, 2015 | 08:36 PM
  #286
Total Cats: 1,924
Originally Posted by aidandj
<p></p><p>Dibs on it, when you inevitably&nbsp;screw it up and buy a new one? </p>
First you need a BP
Old Jun 29, 2015 | 08:44 PM
  #287
Total Cats: 1,870
Something like this maybe?
<br />
<br />
Old Jun 29, 2015 | 10:21 PM
  #288
Total Cats: 1,924
We should stop flirting in Ian's thread, unlike the rest of us he's getting real data and solving real problems.
Old Jun 30, 2015 | 02:03 AM
  #289
Total Cats: 887
I pulled the trigger on the Radium unit, we'll see how it does.
Old Jul 3, 2015 | 12:53 AM
  #290
Total Cats: 887
Shiny (well, anodized) new parts showed up today!
Off work tomorrow, maybe I'll put it in then.
Attached Thumbnails Ian's 99 build thread-radium1.jpg   Ian's 99 build thread-radium2.jpg
Old Jul 3, 2015 | 01:28 AM
  #291
Total Cats: 1,870
<p>Isnt the selling point of the radium that it works with rising rate FPRs, which yours isnt?</p>
Old Jul 3, 2015 | 01:34 AM
  #292
patsmx5's Avatar
Total Cats: 559
shhhh!!!
Old Jul 3, 2015 | 02:46 AM
  #293
Total Cats: 887
Mine is.
Old Jul 3, 2015 | 02:47 AM
  #294
Total Cats: 1,870
I thought it wasn't vacuum referenced?
Old Jul 3, 2015 | 03:12 AM
  #295
Total Cats: 887
When I first installed it, I did not hook up the vacuum reference. Later, I did, as you can see in the photos in post #275.
I talked to FM about why they recommended not referencing it, they said that because it's a long run from the manifold to the regulator, the regulator will lag the boost rise and it can make lean tip-in worse. They also suggested that at 12-15 psi (standard FM2 levels of boost) the referencing isn't really necessary, because with a base pressure of 60 psi it's still getting 45 psi pushing the fuel through. I'm running a teensy bit more than 12-15 psi (currently set at 24, gonna see if it'll do 30 once I get it to the dyno). That means there would only 2 bars pushing fuel through the injectors, which is a bit low.
Thus, I ran the vacuum reference line.
Old Jul 3, 2015 | 03:33 AM
  #296
jimmyneutron's Avatar
Total Cats: -3
Haha a tinsy bit more 24.... Thats awesome hope you get your issues sorted out
Old Jul 19, 2015 | 03:12 AM
  #297
Total Cats: 887
So things on the Miata got stalled for a couple of weeks. We got the keys to our new house, and I spent a couple of weekends doing stuff related to that, rather than the Miata. A nice big, paved side yard perfect for trailer storage!
Today, however, I got back to looking at the fuel, and plumbed in the Radium pulse damper. I decided to mount it on the rubber mounts from the factory pulse damper, so first I needed a bracket. (This is actually the second bracket, the first one turned out to not be long enough). It's just 1/8" thick 2" aluminum angle with a few holes and a corner chopped off to make room for the 90-degree hose end.
Then the FPD mounts on the bracket with some loose hose ends to check for alignment.
The pressure sender remote-mount hose needed to be flipped around, so the 90 is now next to the sender.
Hoses made and fitted:
Feed lines:
So ideally I want the pulse damper mounted in the feed line to the rail, but right now it's actually mounted in the remote line for the pressure sensor, because I didn't have the right fittings to do it properly. I'll order those and reroute it later, but right now it works very well indeed. The pressure swings are maxing out at around +/- 2 psi, vs the 15 psi I was seeing before. Yes, the pressure sender probably isn't seeing everything that's happening at the rail due to the routing right now, but I did have the damper in the feed line briefly (just hacked up for testing) and it looked the same there. The weird ringing at idle is totally gone, and I'm VERY pleased with it.
So my takeaway from this is that FM's big fuel kit needs a pulse damper. I don't know if the stock damper would accomplish the same thing, or if it really needs to be the fancy vacuum-referenced radium one.
The car will now do a 270 kpa run to redline smoothly, without the major stumbling I was seeing before, although there is still a little blip in that datalog which may be a misfire. 270 kpa is probably asking a lot of the Toyota COPs.
Attached Thumbnails Ian's 99 build thread-salsbury.jpg   Ian's 99 build thread-radium10.jpg   Ian's 99 build thread-radium11.jpg   Ian's 99 build thread-radium12.jpg   Ian's 99 build thread-radium13.jpg
Old Jul 19, 2015 | 11:58 AM
  #298
Total Cats: 861
<p>Remind me why you didn't simply&nbsp;move the referenced FPR to just downstream of the fuel rail, as in at typical referenced, return style system.&nbsp;</p>
Old Jul 19, 2015 | 12:01 PM
  #299
Total Cats: 1,870
He has an NB so he would have to convert to return style fueling.
Old Jul 19, 2015 | 12:40 PM
  #300
Total Cats: 887
Making a -6 return style system would've required a lot of new hose and fittings that I don't have, several hundred dollars' worth. It would also preclude the use of the stock rail, requiring a lot more parts to be swapped out for California's biannual "regulatory" reasons.
