404whp/389wtq NA For Sale...Sadly :(
Total Cats: 10
So, I'm just at a point where I want to move onto something different, or maybe nothing at all. The car is retarded, and I've only tracked it a whopping total of five times, with four dyno sessions. Everything has been restored/replaced/rebuilt; it goes without saying, this was my dream Miata. I'm putting it up for sale while I'm at a school right now for a month, with little hope that this thing will actually sell as a whole car. Well, I'm giving it four weeks of being up for sale as a complete car before I part it out...which will be sometime in April. So, if you're interested in the car as a whole, make me an offer. If not, vultures, get ready to pounce in April when I get back into town.
If you want the car whole, it's pretty much as pictured here, with a few minor exceptions. The bumper needs to be replaced from some cone damage and I need to get some new e-fans, for which I'll pay for and fix only if I sell the car as a whole package. The paint also isn’t perfect from your normal track wear and tear. Also, every light works in this car, all of the locks work, and the hood pins are lockable. I built this to drive on the street here and there with the intentions to have working lights and be able to lock it up wherever I want. The car is currently located and registered in SOUTHERN CALIFORNIA.
The parts list is as complete as I can think, from what you'll see, it's a pretty wild car and A LOT of custom work from A LOT of great people went into making this thing actually work and produce the numbers that it does. Summed up, the car currently runs on an AEM EMS4, Garret GTX Turbo, E85 and a complete Turbo II RX-7 Drivetrain and produced 404whp and 389wtq on 25psi. This car was also featured in three Mazda commercials including the 20-year Miata anniversary release and the 2016 ND MX5 release commercial. For print, the car was featured in D-SPORT magazine in 2014.
I really don't know what to ask for this car because it's so weird, so how's about we use 25,000$ as a "jumping-off-point" and we can go from there with offers. Again, I'll probably end up parting this gal out because it's such a niche vehicle...and with that, the most fun I've ever had in a car this dumb.
Gauges here are now Defi, a few things have changed
Dyno Video:
Street Video:
Mazda ND Release Video:
Mazda Tumblr:
? MX-5 WORLDWIDE #3: JEFF FROM THE U.S. The Mazda...
D-SPORT Article (2014):
374WHP Miata Lightin? Fires, Smokin? Tires
Stuff:
90 Chassis
97 Block
99 Head
Engine Build - Greg at Millennium Motorsports in Temecula, CA
Tune - Sam at Road Race Engineering in Santa Fe Springs, CA
JE 9:1 Forged Pistons
Manley Forged H-Beam Rods
SuperTech 1mm Oversized Intake and Exhaust Valves
SuperTech Valve Springs Kit
SuperTech Shim Under Bucket Lifters
SuperTech Valve Seals
ACL H Series Main and Rod Bearings
Super Miata Blueprinted and Billet Oil Pump
ARP Hardware
Fidanza Adjustable Cam Gears
Gates Racing Timing Belt
Gates Racing Acc Belt
Gates Racing Water Pump
ATI Super Damper
Mazda Protégé Valve Cover
Garage Star Carbon Fiber Plug Cover
EUDM Intake Manifold
Apexi Intake Filter
Garrett GTX2860R .64 Turbo
Tial Vband Turbo Exhaust Housing
Tial MVS 38mm Vband Waste Gate
Tial 50mm BOV
ARTech Bottom Mount Vband Exhaust Manifold w/DP
Parts Shop Max Custom 3" SS Exhaust
1.6-1.8 Throttle Cable Bracket
Skunk2 64mm Throttle Body
Injector Dynamics 1000cc High Imp. Injectors
SuperMiata Billet Fuel Rail
Fuelab 51502-1 Adjustable FPR
DeatchWorks 300lph Fuel Pump
Setrab 640 Series 6 40 Row Oil Cooler 13" x 12" x 2" w/M22 Fittings
Mocal Oil Thermostat
Canton Oil Relocation
AEM EMS 4
Optical CAS with AEM SR20 Wheel
MAC Electronic Boost Controller
AEM Smart Coils
Custom Magnecor Race Wires
Innovate LC-2 Wideband
Mishimoto X-Line Radiator
Mishimoto Fan Shroud
BEGI Coolant Re-Route
Fab9 Stage 2 Vibrant Intercooler
Intercooler Piping
SuperMiata Motor Mounts
High Output 1.8 130W Alternator
Canton Oil Catch Can
Moroso Coolant Expansion Tank
Garage Star Water Pump Pulley
RX-7 Turbo II 5-Spd Transmission
Maverick Motorsports Transmission Adapter Plate
Mazdatrix Short Shifter
949 Racing Clutch Line
Clutch Net 6-Puck Sprung Clutch Custom Dual Diaphragm (500EHP)
Clutch Net Billet Flywheel
RX-7 Turbo II Differential Housing
RX-7 Turbo II Axles
Custom Aluminum Driveshaft
Maverick Motorsports Turbo II Hub Spacers
MiataRoadster Turbo II Axle Adapter Hubs
Kaaz 1.5-Way Differential
Parts Shop Max Billet Diff Mounts
Stance GR+ Coilovers (8/6)
Maverick Motorsports Steering Knuckles
Jackson Racing Sway Bars
SPL Parts RUCAS
SuperMiata Sway Bar End Links
Energy Suspension Bushings
949 Racing 6UL Nickel Wheels (6x 15x9, 2x 15x8)
SuperNow FC Outer Tie Rod Ends
MR2 Electric Power Steering w/High PSI AN Lines
Garage Star Steering Rack Riser Kit
Goodwin Racing Big Brake Kit
Wilwood Bias Valve
Wilwood Steel Lines
Parts Shop Max Hydraulic Hand Brake
Sparco Sprint Seats
Cage by Parts Shop Max
RJS 3” 5pt Driver Harness
Sabelt 3” 4pt Passenger Harness
Momo Mod 07 Steering Wheel
Momo Wheel Adapter
Sparco Quick Release
Longacre Rear View Mirror
Zilla Shift ****
Carbon Trix Center Console
KG Works Starter Panel
Defi Racer Boost Gauge
Defi Advance CR Gauges (Oil, Water)
Autmoeter Fuel Gauge
ARC Switch & Relay Panel
Jass Performance Headlights
Project G Rear G-Shield
Project G Corner Glass
Project G G-Fuser
APR Side Mirrors
Intake Turn Signals
Zeromotive Rear Canards
Hard Top
Aerocatch Hood Pins
KG Works Rear Spoiler
Dyno Video:
Street Video:
Mazda Tumblr:
Stuff:
90 Chassis
97 Block
99 Head
ARP Hardware
ATI Super Damper
Apexi Intake Filter
Tial 50mm BOV
AEM EMS 4
AEM Smart Coils
Intercooler Piping
RX-7 Turbo II Axles
SPL Parts RUCAS
Wilwood Bias Valve
Wilwood Steel Lines
Sparco Sprint Seats
Momo Wheel Adapter
Zilla Shift ****
Project G G-Fuser
APR Side Mirrors
Intake Turn Signals
Hard Top
Aerocatch Hood Pins
Good luck with sale, but I feel like you will regret selling this the rest of your life. It's too "you" and has too much cultural history. If it were me I'd consider selling it at a significant discount to a friend who agreed to let you buy it back for the same discount if it ever went up for sale.
But then, I'm reading my own sentimental notions onto it. I hope you get out of it what makes you happy.
Total Cats: 1,091
Stunning car, stunning price.
Great build though, good luck man.
Total Cats: 1,091
Dude. Read the post literally right above yours.
