Wastegate solution for sr20 turbo
Old Jul 9, 2016 | 07:19 PM
ericsbestshot's Avatar
Total Cats: 9
Default Wastegate solution for sr20 turbo
So for a couple years i've been using a sr20 turbo. When I first turboed my car I couldn't find an effective way to mount the wastegate. I ended up being very ghetto and used JBweld. Surprisingly it has worked almost flawlessly for 2 years (it cracked once). Fast forward to present day, I've built my motor and wanted to mount my wastegate properly.
Here are the parts i used.
Rod extension kit for Internal wastegates : atpturbo.com
Wastegate Actuator with ROD END, 28RS style, 14 PSI : atpturbo.com
Garrett Adjustable Wastegate Bracket : atpturbo.com
I had to cut the bracket to make space for the oil feed and drill at tap the compressor housing. Now I have it mounted and it almost looks like it was always supposed to be there.
Just thought I'd post my solution, just in case others were having issues.
Attached Thumbnails Wastegate solution for sr20 turbo-20160709_164319.jpg   Wastegate solution for sr20 turbo-20160709_164342.jpg
Old Jul 10, 2016 | 01:26 AM
cordycord's Avatar
Total Cats: 560
I think this post deserves your first cat.
Old Feb 11, 2017 | 09:33 AM
kmo25's Avatar
Total Cats: 41
Saw this post and picked up the same bracket to redo my SR20 wastegate setup as well. Thanks for the heads up.
Old Feb 11, 2017 | 10:17 AM
MaineMiata91's Avatar
Total Cats: 9
https://flic.kr/p/FSUz3Yhttps://flic.kr/p/FSUz3Y by https://www.flickr.com/photos/132614217@N04/, on Flickr
looks very similar to the bracket we made for mine, been holding up well
Old Mar 3, 2018 | 03:22 PM
guacamole's Avatar
Total Cats: -1
how deep can you drill the compressor housing there before poking thru? assuming you don't hit the C clip? Can you just cut and weld or JB weld the oem wastegate rod?
Old Apr 20, 2018 | 01:20 PM
SGTZ28's Avatar
Anymore info on this? I feel I will be running into this issue here very soon and would love a lil help.
Old Apr 20, 2018 | 02:52 PM
guacamole's Avatar
Total Cats: -1
I found the bracket mentioned above does not match the sr20 t25 turbo compressor housing diameter. I wound up modifying the bracket that comes with the turbo and tapping the compressor housing to relocate it. Very hard to measure how deep u can drill before poking through the housing so be careful.
kiladonut
Apr 11, 2016 01:11 PM
Forrest95M
Mar 8, 2016 09:16 PM
drftem
Jul 29, 2006 07:51 PM
jayc72
Prefabbed Turbo Kits
14
Jun 26, 2006 10:18 PM
hustler
Jun 20, 2006 08:35 AM
