Billet Water Pump Inlet Adapter - Pre-Order
Old Dec 29, 2016 | 07:12 PM
bahurd's Avatar
Total Cats: 316
Originally Posted by TheBandit
Give me a bit to research the thread geometry for these and I will see what I can do. Based on the responses here I think I will be pursuing this route over the NPT as initially conceptualized.
No problem.
SAE J514, Straight Thread O-Ring Boss (ORB)
Hose fittings seem to be available in either -12AN or -16AN for our hose sizes.
https://www.meziere.com/Products/Coo...B-to-Hose.aspx
Old Dec 29, 2016 | 10:44 PM
gpzmax's Avatar
Default Want
I need one for my engine build
Old Jan 1, 2017 | 06:02 AM
zossy1's Avatar
Total Cats: 22
Count me in either way, but id also prefer AN thread.
Old Jan 3, 2017 | 11:00 AM
TheBandit's Avatar
Total Cats: 57
Thanks for the response as always. I'm going to try to fit the larger ORB AN thread if I can make it fit. I'll check with our machinist and see if he sees any issues, but hopefully pricing and all can stay the same as before.
Old Jan 3, 2017 | 12:16 PM
skou's Avatar
Total Cats: 21
FYI, the current SAE specification for straight thread o-ring ports is SAE J1926-1. Detailed machining dimensions are available here:
http://www.goodyearrubberproducts.co...n1.page477.pdf
When you talk to your machinist, suggest using the tap drill size instead of the basic minor diameter of the thread form to machine the crest flats. That will make the ORB fitting easier to engage into the threads.
Old Jan 6, 2017 | 08:27 AM
TheBandit's Avatar
Total Cats: 57
Test fittings on order. More updates soon.
Old Jan 9, 2017 | 08:34 AM
pooch20's Avatar
Hmmmmmm I'm interested. Would it be best to run the rear port to the turbo and then tee the heater hose into the rad hose?
Old Jan 9, 2017 | 08:44 AM
TheBandit's Avatar
Total Cats: 57
This is how I'm routing things.
Old Jan 9, 2017 | 11:20 AM
Philly Miata's Avatar
Total Cats: 15
I'm a scrub but in your pictures is that the turbo that seems really low on the engine? I'm trying to figure out what I'm looking at, and what necessitates an adapter like this?
Old Jan 9, 2017 | 11:28 AM
Girz0r's Avatar
Total Cats: 323
Low mount EFR turbo seen in 2nd photo. Adapter needed for more room for low mount EFR turbo.
Old Jan 9, 2017 | 11:34 AM
TheBandit's Avatar
Total Cats: 57
Yep. See above picture.
That's actually my engine with the prototype attached. It gives more room for charge piping/compressor housings/intake tubing/etc.
Old Jan 12, 2017 | 01:33 PM
Total Cats: 1,924
Subb'd for glory. I'd also much rather see ORB & barb than NPT & barb, but then I have an intense hatred for everything NPT.
With that coolant routing above, are you getting enough flow through the heater core to make the heater or the defroster useful? IIRC the coolant fittings on the EFR are like M14, and that bore size is pretty much straight through to -6AN, or pretty close to it. Heater hoses are comparatively ginormous, pretty sure they are up in the -8AN or -10AN size range (I'm just using -AN sizes for comparison.)
Old Jan 12, 2017 | 03:10 PM
psyber_0ptix's Avatar
As I visualize it, the coolant will be sitting in the heater core longer if the turbo was a restriction, which isn't that big a deal for defrost or general heater use. That allows more heat energy to be transferred via forced convection through the heat exchanger and possibly even providing a slightly cooler fluid to the turbo.
heater core lines would be -10AN
Old Jan 12, 2017 | 03:59 PM
TurboTim's Avatar
Total Cats: 425
Many years ago, before my first turbo kit (before this forum), I had cooling issues. My first fix was to place a ~.250 restricter in the heater core line. Eventually I changed the radiator, but the restricter remained until I redid all the hoses with the V6. This car was my daily for many years and heater/defroster function was not affected.
Old Jan 12, 2017 | 04:45 PM
Was your car overheating?
Old Jan 12, 2017 | 06:55 PM
TurboTim's Avatar
Total Cats: 425
My issue at the time was overheating, yes.
Old Jan 12, 2017 | 07:29 PM
Curious if routing the return to the radiator inlet would have allowed more heat to be shed at the expense of a slightly longer warm up time. If the radiator wasn't a limitation that is.
Old Jan 13, 2017 | 10:09 AM
TurboTim's Avatar
Total Cats: 425
Corky?
Old Jan 13, 2017 | 11:59 AM
TheBandit's Avatar
Total Cats: 57
Fittings have arrived - prototype with ORB to follow. I'll keep everyone updated.
Continue the cooling discussion - More info is a good thing.
Old Jan 13, 2017 | 12:20 PM
bahurd's Avatar
Total Cats: 316
What size fittings are you going for?
