Post your DIY aero pics
Old Oct 9, 2018 | 12:57 AM
  #1761
vintagerust's Avatar
I made front tire spats for my NB. I wanted to see if covering more of the front tire would reduce drag. I don't run a splitter.
I took a trip to Miami with them on, and took them off for the return trip home. Each drive began with a full tank. The drive with the spats on cost me 1.5mpg, and the front end tended to yaw more. Interestingly enough, I did notice a change in wind noise by the A pillar. It seemed quieter.
Being that spats are pretty much a flat wall for air to move around, they're not very efficient. If you're looking for downforce, it can be implemented well into a splitter to cause the air to stagnate and produce more pressure on the corners of your splitter, but I wouldn't use large ones.
Old Oct 9, 2018 | 03:20 AM
  #1762
rascal's Avatar
Total Cats: 41
I'd hardly call this a scientific test to base any conclusions on. You need to drive the exact same road to have any meaningful result (and the same highway in reverse doesn't count)
Old Oct 9, 2018 | 07:09 AM
  #1763
BEAVIS's Avatar
Total Cats: 68
Class rules likely don't permit a larger front splitter in Tims case.
The Australian (CAMS) regulations for a lot of sports car categories are painfully archaic and reward the cashed up engine builders more than any kind of home ingenuity/diy aero work.
Old Oct 9, 2018 | 08:56 AM
  #1764
Total Cats: 3,593
Vintage, I appreciate your efforts but there are too many variables unaccounted for in your test. Not the least of which would be direction and speed of prevailing winds on both trips. Being in Florida we commonly have a seven to ten mile an hour breeze and directions and intensities change as the afternoon seabreeze interacts with the prevailing winds.
Old Oct 9, 2018 | 02:39 PM
  #1765
Total Cats: 2,621
Default Vegas splitter for Super Lap
.33 SNR
Old Oct 9, 2018 | 02:55 PM
  #1766
Supe's Avatar
Total Cats: 81
How steep is the angle on the splitter tunnels?
Old Oct 9, 2018 | 03:33 PM
  #1767
Total Cats: 2,621
Probably 15-18*
.33 SNR
Old Oct 9, 2018 | 05:37 PM
  #1768
G3ML1NGZ's Avatar
Total Cats: 109
Since I in the middle of nowhere my material selection is kinda limited. I have found no honeycomb panels but I did find this aluminum/plastic/aluminum sandwich panel. it is RIGID and I suspect it will stand up to both the elements and track abuse. But how heavy are the plywood splitters so I have some kind of a reference point?
Old Oct 9, 2018 | 05:45 PM
  #1769
Blackbird's Avatar
Total Cats: 415
^ I would not use DiBond for a splitter.
Old Oct 9, 2018 | 05:48 PM
  #1770
G3ML1NGZ's Avatar
Total Cats: 109
just out of curiousity. why? a little reasoning helps get my mind off it
Old Oct 9, 2018 | 05:50 PM
  #1771
Total Cats: 2,621
Agreed. Weaker and far heavier than Alumalite. Probably about the same yield and modulus as birch but twice as heavy. I bought a small sheet of dibond to experiment with and... jeebus it's dense.
There are sign supply companies that will ship Alumalite. One option for folks not near major urban areas is to see if any other local racers want to share shipping costs for a few 4x8's of 10mm for splitters.
.33 SNR
Old Oct 9, 2018 | 05:52 PM
  #1772
ThePass's Avatar
Total Cats: 1,237
Yeah. Dibond us great for certain things, but not a splitter. It will deform. You want alumalite. Generally, the type of store that sells Dibond sells or can get you alumalite.
Ryan Passey
Old Oct 9, 2018 | 05:54 PM
  #1773
G3ML1NGZ's Avatar
Total Cats: 109
thanks for the explanation. I knew it was on the heavier side which is why I asked about the plywood splitters.
But I'm in Iceland so shipping for something like this will be ridiculous. I'll keep looking for suitable materials.
Old Oct 9, 2018 | 06:19 PM
  #1774
Blackbird's Avatar
Total Cats: 415
I assume plywood is not too hard to come by in Iceland, so why not use that?
Old Oct 9, 2018 | 06:29 PM
  #1775
G3ML1NGZ's Avatar
Total Cats: 109
It'll be a last resort. Very wet weathers here have me leaning on synthetic materials. But I'll go that route if I must
Old Oct 9, 2018 | 07:02 PM
  #1776
Total Cats: 2,621
Paint/seal it.
.33 SNR
Old Oct 12, 2018 | 12:01 PM
  #1777
rrjwilson's Avatar
I set out to try and build a compendium of such information a while back it has been viewed but only commented on by me. See here
It seems that Young Modulus is hard to come by for most materials so it is always worth asking. Emilio, Ryan and Moti have experimented so much you can almost guarantee they have tried it.
Old Oct 12, 2018 | 12:33 PM
  #1778
Total Cats: 2,621
I saw that post and moved it the aero sub forum a few weeks ago. Thanks for the contribution.
.33 SNR
Old Oct 14, 2018 | 05:39 PM
  #1779
G3ML1NGZ's Avatar
Total Cats: 109
RRJWilson that list is well appreciated. poscat
Old Oct 14, 2018 | 09:47 PM
  #1780
Blkbrd69's Avatar
Total Cats: 76
I'm thinking lot's of boats up there?
Boat plywood impregnated with epoxy resin is super tough, and resists weather very well.
