Hrmm...Let's discuss Spark Plugs+Gaps+wires?
Old Aug 25, 2008 | 10:37 AM
patsmx5's Avatar
Total Cats: 559
Gap new plugs to .020. Fixed. Then tell us how it didn't affect idle, cruise, mpg, or anything else.
Old Aug 26, 2008 | 01:51 AM
XxGoKoUxX's Avatar
lol... i guess i'll try the .020?...i hope you were joking about idle cruise mpg and everything else.... hahaha
Old Sep 7, 2008 | 10:46 PM
locomonkeyboricua's Avatar
Total Cats: -216
i had the same problem after i moved from GA to CA every time i would pull hard to 7k i would start to lose power and sputter around 6k till 7k so i checked my #7ngk plug and the cap was at 35 i changed it to 29 and that fixed the problem car runs great all the time. i thought about the COP option but the most i ever boost now is 15psi i think ill get a oil cooler first.
Old Sep 8, 2008 | 12:01 AM
TonyV's Avatar
I'm curious to hear back from the guy patsmx5 suggested to regap to .020..
I'm THINKING I;m experiencing blowout. Also no backfire, dont think I'm seeing misfire (at least cant notice) either.
What I AM experiencing is when I pull the car hard, I sometimes get a sudden loss of power/RPM. It doesn't happen everytime, and only when really getting on it.
Perfect example, get on the car up to 6k rpm, then all of a sudden RPM's drop to 5kRPM, and then car comes back to life.
Been wanting to check the gaps, just haven't gotten around to it...
Old Sep 8, 2008 | 12:19 AM
Joe Perez's Avatar
Boost Pope
Total Cats: 7,558
So you're seeing the tach drop suddenly from 6k to 5k and then come back, yes? Do you believe this to be reflective of reality? Seems to me it'd be difficult for the engine to actually do that in the period of time that I envision you describing.
When I was having trigger problems with my MS, I observed this behavior frequently while under heavy load- the tach would drop down suddenly, accompanied by a momentary loss of power, and then come right back. In my case, this was a pickup problem however, which was causing the ECU to not generate spark signals in the first place- misfire due to spark blowout should not actually produce the sort of tach dropout that I think you are describing.
Old Sep 8, 2008 | 09:49 AM
TonyV's Avatar
Yes I believe it to be happening, as I dont know anything else that could show my tach drop 1k rpm, even if my foot stays on the throttle...
Another thing is I can't duplicate the condition on command. Sometimes it happens, sometimes it doesn't. It's not WOT, but def 3/4 throttle...usually in 2nd or 3rd gear...right around 6k rpm.
I dont think I'm hitting any kind of fuel cut, and as I said a fuel cut would be very easy to duplicate.
I have to try and catch one of these in a DL
Old Sep 8, 2008 | 09:55 AM
Tony try to log the event. It's most likely spark blowout- I used to see the same before i went to cops with a .035" gap. Its also possible it's acceleration enrichments, under accel wizard your setup for TPSdot right?
Old Sep 8, 2008 | 10:07 AM
Joe Perez's Avatar
Boost Pope
Total Cats: 7,558
I don't see how spark blowout could cause a tach drop. Assuming he's using the stock tach driver of an early '95, the tach output of the igniter is not a closed-loop thing- it gets pulsed whenever the primary operates, regardless of what's happening on the secondary. If he's driving the tach directly from MS, or by diode-OR'ing the SparkA and SparkB triggers, then it's doubly impossible for a secondary-side fault to cause this problem. He's talking about an observable drop of 1k RPM on the tach that happens almost instantaneously, and the engine simply can't change speed that fast.
This really sounds like a CAS trigger problem to me. If you can log an event, I've got $0.01 that says it'll show as a very massive and rapid spike in RPM.
Old Sep 8, 2008 | 10:09 AM
patsmx5's Avatar
Total Cats: 559
Try new plugs gapped to .020 and see if it fixes it.
Old Sep 8, 2008 | 11:25 AM
TonyV's Avatar
I'm gonna try logging it, just keep the laptop in the car till I finally catch it I guess. Also obviously it won't hurt to check the gaps on the plugs.
I haven't messed with any enrichment stuff, not that far along yet, lol.
Just getting the hang of tuning, DLing, etc.
AND I really need to get on my EzTherm...my CLT temp values (and prob Intake Temps) are way off... On a good run my CLT shows CS140's-HIGH170's...
Old Sep 10, 2008 | 10:07 AM
TonyV's Avatar
Regapped plugs, I guess I had them on NA gaps? (.035-.040)
Bought them down to .020-.025
Also gonna do some logging and see if I can repeat the event, though hopefully it was the gaps...I just dont know if they'd be blowing out at only 5-6lbs of boost, even with stock gapping
leatherface24
Cars for sale/trade
15
Oct 16, 2015 11:35 AM
The Gleas
Oct 1, 2015 09:30 AM
FrankB
Sep 30, 2015 11:48 AM
E=MC^2
AEM
1
Sep 17, 2015 12:34 PM
D_Breezy
Meet and Greet
Sep 8, 2015 05:37 PM
