hustler's "driver shame" thread
Old Nov 25, 2008 | 11:44 AM
  #41
now the shifter doesn't fit. The new trans has 2 dowel pins, rather than the 1 in the shifter. Any thoughts? I might just cut it off with the dremel.
Old Nov 25, 2008 | 12:11 PM
  #42
y8s's Avatar
y8s
DEI liberal femininity
Total Cats: 574
big channel lock pliers and push it half way out. leave it there until you need it for a stock shifter.
  #43
spike's Avatar
You can remove one of the dowel pins with a pair of vise grips.
Old Nov 25, 2008 | 12:13 PM
edit: If you got the dowel out with just channel locks, you're a bad *** dude.
Old Nov 25, 2008 | 12:14 PM
  #45
spike's Avatar
its either machismo's or Wagz's.
That's good to hear....at least you know who the father might be.
You might have to go on the Maury Povich Show to do one of those paternity test though.
Old Nov 25, 2008 | 01:12 PM
  #46
apparently I broke the heater core at some point because my feet are scalded now. It idles though...now I have to figure out what's going on with the heater core...it may get bypassed for today.
Old Nov 25, 2008 | 01:27 PM
  #47
johndoe's Avatar
Originally Posted by johnwag
RB sway bar brace, as well?
no, no brace. The clearance is also very minimal.
Old Nov 25, 2008 | 03:08 PM
  #48
sbrian2's Avatar
Remove the brace and get these: Miata suspension parts by awr
You will thank me later. Stock Mazda sway bar mounts suck and break if you run R compounds.
Old Nov 25, 2008 | 03:42 PM
  #49
y8s's Avatar
y8s
Total Cats: 574
i use the 20" "bigAZZ" channel locks. perhaps that's the difference?
Old Nov 25, 2008 | 04:16 PM
  #50
I got it out with my pinkies.
Well I have random water-leaks now and must bleed the brakes and clutch before a proper, hard break in. So now I'm going to get **** drunk and bang a bunch of *****, then try to finish this up tomorrow.
I have 2 more days before I leave for Austin, and I'd really like to have the car ready to drop off at BEGi to have a few things re-engineered.
Old Nov 25, 2008 | 06:14 PM
  #51
thesnowboarder's Avatar
Good luck man, its been a long haul. May i ask how your routing the heater hoses for your heater core? Pictures would be awesome as well.
Old Nov 25, 2008 | 09:37 PM
  #52
everything is tucked...just how you like it.
Pics will come tomorrow.
Old Nov 25, 2008 | 10:08 PM
  #53
Machismo's Avatar
Hustler - I did notice that the barb ends for your water piping to the heater core and return were a little "how do you say" mangled. Did you use some wood dowel to shape them up. That would allow some leakage into your inner firewall and footwell. But does sound like a heater core, if your feet are getting the treatment.
Good luck and glad to see and hear the great progress you've had for this visit.
Old Nov 26, 2008 | 10:05 AM
  #54
i used a nut-driver to round the heater core ports again, and no more leakage. Now I just have to put the new brakes on the car, bleed them, bleed the clutch, and I can break-in the motor!!!
Old Nov 26, 2008 | 12:22 PM
  #55
help with wastegate actuator adjustment:
How should I adjust the wastegate actuator if I have a boost controller? I know "all the way in" helps with spool, but all the way out should make the least boost, right? i'd like to put it at the minimum now, but still have spool for road tuning.
Thanks.
Old Nov 26, 2008 | 01:07 PM
  #56
johndoe's Avatar
I'd start with the lowest boost setting on the wastegate arm. I had some serious overboosting on my gt2860rs with no preload on the actuator. So make sure you're making low boost first with just the wastegate and no ebc. Then tighten up the wastgate to a couple psi less then you want to run with ebc.
Just leave the heat shield off while you do a couple pulls to find out how much boost you're making with the wastegate. You don't want to be prying that bitch off while it's hot to change the boost.
Old Nov 26, 2008 | 01:15 PM
  #57
should I be worried about melting the master cylinder?
Old Nov 26, 2008 | 01:33 PM
  #58
cjernigan's Avatar
Total Cats: 7
I don't have a heatshield on my car, haven't melted the cylinder yet. Don't worry about it. You're just street tuning, not tracking it at WOT for 30 minutes.
Old Nov 26, 2008 | 02:42 PM
  #59
I can't get the fans to turn on. I was told the front water temp sensor was not used by ms, so i didn't make accomidations for it. I get readings in MS for water temp, but no fans. If i turn on the AC, they work. Any thoughts?
edit: how the hell am i going to make it 500-miles before ripping on this car? Holy ****, even 3psi at 4500rpm max is exciting now.
Old Nov 26, 2008 | 04:03 PM
  #60
I can take the front temp sensor lead to gnd and it turns the fan on. I'm worried I need this front sensor now, and I've royally fucked up. Has anyone else with mspnp/water reroute done this on a 1.6 car?
Thanks,
dad
