98 1.8 install
Old Jun 21, 2009 | 05:25 AM
CRAIGO's Avatar
Default 98 1.8 install
Hi,
After searching, Im coming up with not alot of info.
I need to find some MS-1 install instructions/ECU pin-out for a 1.8 1998.
I've got an LC-1 to install with it and the MS-1 is a DIY kit fully build and working on a stim.
Cheers,
Craig
Old Jun 22, 2009 | 12:59 PM
Matt Cramer's Avatar
The problem is that the Miata was never sold as a 1998 model year in the US. Is this one an NA or NB body style?
Matt Cramer
www.diyautotune.com
Old Jun 22, 2009 | 04:16 PM
richyvrlimited's Avatar
Total Cats: 42
it's an NB
Old Jun 22, 2009 | 06:44 PM
CRAIGO's Avatar
What Richy said!
It's an NB and timing is off the crank. I'm guessing here, but if the 98 NB was never sold in the US, should I be looking out for the 99 NB ECU pin-out and MS-1 install instructions?
I'll be wanting to install it parallel with the stock ECU as I believe the alternator is regulated off the crank angle sensor.
Thanks,
Craig
Old Jun 23, 2009 | 02:12 AM
Zaphod's Avatar
Total Cats: 106
Go MS-2, read
https://www.miataturbo.net/forum/t26882/
https://www.miataturbo.net/forum/t14847/
and especially the latest thread from Abe about his adapterboard.
Greets
Old Jun 25, 2009 | 06:15 AM
CRAIGO's Avatar
Im not too keen on going MS-2. My requirements wouldn't take me beyond an MS-1 parallel install. I just want decent fuelling/ timing control for an intercooled supercharger install with the ability to bang in some larger injectors etc.
I don't see an issue with letting the stock ECU control the alternator and other boring stuff.
I'm still struggling to fins a defined pin-out/install guide for my 1998 NB car :(
Old Jun 25, 2009 | 06:45 AM
Zaphod's Avatar
Total Cats: 106
That is how I did my parallel install as it was with the MS1.
MS1 install scheme 99-00
No guarantee though, it's just a little drawing I did for myself...
Old Jun 25, 2009 | 09:29 AM
With MS1, you will have to add an NA cam sensor (or a 36-1 crank trigger), as only MS2 can read the stock sensors.
Matt Cramer
www.diyautotune.com
Old Jul 12, 2009 | 03:39 PM
CRAIGO's Avatar
Thanks for the schematic Zaphoid.
I've got a mk1 CAS for the back of the exhaust cam so hopefully I'll soon be on my way.
stoves
Apr 21, 2016 03:00 PM
JxPhan
Meet and Greet
Oct 2, 2015 02:17 AM
lsc224
Oct 1, 2015 09:17 AM
JesseTheNoob
Sep 30, 2015 02:44 PM
