View Poll Results: Should I dyno?
FUKKK YEASSS
63.27%
no because i want your motor to live
4.08%
Yes because its broke anyways so more broke not hurt more
16.33%
bannana?
16.33%
Voters: 49. You may not vote on this poll
Poll: Should I dyno with lots of blowby?
Old Feb 8, 2012 | 04:49 PM
Faeflora's Avatar
Total Cats: 130
Default Poll: Should I dyno with lots of blowby?
What it do?
Old Feb 8, 2012 | 04:52 PM
ianferrell's Avatar
yes of course.
not for tune, but for glory.
Old Feb 8, 2012 | 04:55 PM
Faeflora's Avatar
Total Cats: 130
Compression currently tests out at
138/145/150/150
I have a lot of oil coming out my valve cover breather over 20psi.
Old Feb 8, 2012 | 05:05 PM
Do it now just so you have some rough estimate of power numbers. Then pull the car apart. Its not like you have to worry about ------- more ---- up since you are pulling it apart afterwards anyways. I say dyno till you hit 40psi and see if anything else breaks. Then you know you need to fix those too when you rebuild.
Old Feb 8, 2012 | 05:18 PM
y8s's Avatar
y8s
DEI liberal femininity
Total Cats: 574
you misspelled banana
Old Feb 8, 2012 | 05:21 PM
Needs more "No Doubt". Every time I type that word, the song plays in my head.
Old Feb 8, 2012 | 06:55 PM
Slowest Progress Ever
Total Cats: 305
Dyno on 20psi. Report back with dyno sheet. The end.
Old Feb 8, 2012 | 07:06 PM
Faeflora's Avatar
Total Cats: 130
Originally Posted by thirdgen
Dyno on 20psi.
I'd rather kill myself than dyno on such low booest
Old Feb 8, 2012 | 07:20 PM
flounder's Avatar
Total Cats: 31
I did the same thing!
Old Feb 8, 2012 | 07:21 PM
THANK YOU!!!
Omg wtf kinda pu$$y sh*t is 20psi?
Here's what you do:
Dyno no matter what, run literally ALL OF IT, and go out in a blaze of glory while recording in high def of course.
Old Feb 8, 2012 | 07:27 PM
chpmnsws6's Avatar
Start at 20psi
Then 30psi
Finish the big bang theory with 40psi
Will your valvesprings hold the extra pressure or are we going to see some float on the dyno graph?
Old Feb 8, 2012 | 07:58 PM
Faeflora's Avatar
Total Cats: 130
Originally Posted by chpmnsws6
Start at 20psi
Then 30psi
Yes valvesprings are made from pure iron.
Old Feb 8, 2012 | 08:04 PM
JayL's Avatar
Time to put your old license plate back on...
Old Feb 8, 2012 | 08:08 PM
gearhead_318's Avatar
Total Cats: 21
Fix issues and then dyno, you've worked too hard to do something stupid and kill it.
If I had an NB I'd be telling you to go for it so it would die and I'd call dibs on some of your trash.
Old Feb 8, 2012 | 09:03 PM
soviet's Avatar
Total Cats: 269
Originally Posted by Gearhead_318
Fix issues.
I'll come to make a video of it, and in worst case, I have AAA Plus for free towing
Old Feb 8, 2012 | 09:09 PM
chpmnsws6's Avatar
Don't we build them to test them? No?
Old Feb 8, 2012 | 09:14 PM
he's gong to be ripping the motor apart anyway.
so why be a pus$y now and hold back?
is "ALL OF IT" worth a couple hundred bucks?
you tell us
Old Feb 8, 2012 | 09:18 PM
Total Cats: 21
Originally Posted by Faeflora
faeflora is a faeflora
Are you giving me neg props because you like me?
you tell us
Did not know that. In case run all the boost and set records.
Total Cats: 305
F*ck it. Go big or don't go at all. Run 40 psi, and like others said, video that shiz. I fully agree with the "go out in a blaze of glory".
Old Feb 9, 2012 | 09:29 PM
FRT_Fun's Avatar
I'm a terrible person
Total Cats: 180
Basically whatever you do, if there isn't a video, you are a piece of ----.
