what the eff clutch, help!
Old Aug 2, 2012 | 08:48 PM
TheDriver's Avatar
Total Cats: -14
Default what the eff clutch, help!
The past few days my clutch pedal has been real sticky, hesitating to pop back out when compressed. Today I am slowly pulling out of the bank and I give the clutch one good kick and bam my clutch is no more. There is zero resistance and obviously no clutch engagement. The clutch is a 6 puck which felt like it had a lot of life left. Could it be the throw out bearing, clutch, clutch booster?
Old Aug 2, 2012 | 08:51 PM
flounder's Avatar
Total Cats: 31
You can have someone press the pedal and look at the slave cylinder to see if it's still doing it's thing.
Old Aug 2, 2012 | 08:58 PM
TheDriver's Avatar
Total Cats: -14
There's a big pool of fluid on the ground coming from the passenger side, probably clutch fluid. It looks like possibly a line broke, ill post pics when I get home
Old Aug 2, 2012 | 09:10 PM
rleete's Avatar
Total Cats: 1,342
Slave and/or master. Rebuild or replace both. Search for info. There's a step by step in the M.net garage section.
Passenger side indicates slave.
Old Aug 2, 2012 | 09:23 PM
TheDriver's Avatar
Total Cats: -14
I appreciate it, shouldn't be too bad to fix
Old Aug 2, 2012 | 09:27 PM
I have a perfect condition master cyl if you end up needing one
Old Aug 2, 2012 | 10:04 PM
TheDriver's Avatar
Total Cats: -14
here is the pic I managed to snap, thinking this is the slave?
Old Aug 2, 2012 | 10:35 PM
Clos561's Avatar
did u take the bolts off? I dont see any bolts holding it in place..
Old Aug 2, 2012 | 10:44 PM
Slowest Progress Ever
Total Cats: 305
FYI...I just bought a clutch slave from
949 racing today for 14.99. Looks like you'll need 1.
Old Aug 3, 2012 | 08:29 AM
TheDriver's Avatar
Total Cats: -14
the previous owner probably did, let's just say he didn't do the most pristine work.
Old Aug 3, 2012 | 09:08 AM
rleete's Avatar
Total Cats: 1,342
Replace it anyway. Then you rebuild that one, and keep it as a spare.
Old Aug 3, 2012 | 10:48 AM
Total Cats: 4,370
I rebuilt mine in the parking lot of work ($7), when it failed like that on the way to one morning.
I didn't even remove it, just loosened the two bolts IIRC.
I bought a replacement slave afterwards and it's been sitting in a box for three years now.
Old Aug 4, 2012 | 01:33 AM
AkaZero's Avatar
If it is missing bolts, then the piston just popped out. One bolt goes missing, slave pivots, pistone moves too much.
Overtorqued bolts could strip and slip out of the aluminum trans over time.
Might have to drill and retap the bolt holes if so.
Old Aug 4, 2012 | 03:39 AM
mr_hyde's Avatar
Total Cats: 24
There are two bolts that hold the slave on. Your top bolt is missing. It worked a bit for a few shifts and then the whole slave spun out of position on the lower bolt. Put the piston back in the cylinder and replace the missing bolt. Check for leaking or fatigued hydraulic lines that might have been bent or damaged.
Old Aug 4, 2012 | 08:28 AM
rleete's Avatar
Total Cats: 1,342
Yes, but the boot is torn. Imminent failure, even if you bolt it back in correctly.
Bad boot will let crap into the bore, where it can score the bore or seal and it will fail. Probably at the worst possible time. Best to rebuild or replace and have a spare.
Old Aug 4, 2012 | 08:49 AM
AkaZero's Avatar
I would still replace it, but he might need to re-thread the bolts if he doesn't want it to happen again.
From your picture it looks like the top bolt is gone.
how to here -> Miata Clutch Slave Cylinder Replacement
buy here -> Miata MX5 clutch slave cylinder
Or local if you need it asap.
Aluminum is super easy to strip. ( learned from experience )
But from the looks of that slave cylinder ( old ) it looks like the bolt could have just loosened over time, if so buy another bolt ( match to the one left ) and it should be fairly straight forward.
Old Aug 4, 2012 | 06:49 PM
Mobius's Avatar
Total Cats: 365
What an excellent opportunity to install a SS clutch line !
Old Aug 7, 2012 | 12:05 PM
TheDriver's Avatar
Total Cats: -14
Say I need to buy a new bolt. Does that mean that it is 1.5mm thread and the 2.3 would be length of the bolt?
you guys are so very helpful, I appreciate it
Old Aug 7, 2012 | 12:25 PM
rleete's Avatar
Total Cats: 1,342
No. Those are torque values.
A 1.5mm bolt size would be tiny.
Old Aug 7, 2012 | 12:29 PM
TheDriver's Avatar
Total Cats: -14
aren't the threads on NA miatas lug nuts 1.5mm?
