Couple of Locost 7 craigslist ads...
Old Sep 25, 2012 | 04:46 PM
Total Cats: 1,924
Thousand oaks is about 4hr 30min for me... Hummmmm
Old Sep 25, 2012 | 06:15 PM
njn63's Avatar
Total Cats: 15
The Gibbs version of the book is basically a newer version of the Champion book.
Old Sep 25, 2012 | 10:36 PM
I ordered the Gibbs one today. Some of the reviews on amazon said it was not as good as the original.
Old Sep 26, 2012 | 10:27 AM
skou's Avatar
Total Cats: 21
The frame in the Gibbs book is a bit larger in length (2"), width (2") and height (1") to accomodate more modern engines and more modern larger people. The frame in Ron Champion's book is closer in size to the original S3 Lotus 7's dimensions.
Old Sep 26, 2012 | 10:31 AM
golftdibrad's Avatar
Total Cats: 79
yes. most built a "442" frame, which IIRC is 4 inches longer, 4 inches wider, and 2 inches taller.
Old Sep 26, 2012 | 12:34 PM
rleete's Avatar
Total Cats: 1,344
Yes, the Gibbs frame is a compromise. Book frame isn't long or wide enough, so many went the 442 route. Only to find they wished they'd gone smaller. Makes it look a lot leaner the narrower you go, but you have to have the front frame width for modern intakes.
Old Sep 26, 2012 | 12:43 PM
I hate you all. I now really want to build a locost 7. I just need a garage that I can fit a car inside and a welder.
Old Sep 26, 2012 | 12:45 PM
rleete's Avatar
Total Cats: 1,344
I have both. Relocate to Rochester, and I'll provide the space.
Old Sep 26, 2012 | 12:54 PM
Total Cats: 79
They are sweet.
BUT. before you start.. realistically see how much time you can devote to it. Its probably 200-400 hours of work. there are 8760 hours a year, and 5840 of those are spent working and sleeping. There are kits that can give you a big head start. Some places even sell turn key cars for the price of a VW GTI, but you need cash up front. Its all about how much your time is worth to you, and how much you'd rather be driving vs. building.
Old Sep 26, 2012 | 01:10 PM
skou's Avatar
Total Cats: 21
Originally Posted by rleete
...but you have to have the front frame width for modern intakes.
And a turbo, of course.
Yeah, devoting time to a project like this is the challenge. It's been almost 2.5 years since I bought a donor and the Locost is still more dreaming than reality!
Old Sep 26, 2012 | 09:02 PM
jaf1901's Avatar
Wouldn't be a Miata Locost build if you didn't turbo it. I'm 4 years into my build and I can attest to the time/money/effort it takes to bring one of these cars to fruition. But if you enjoy the fabrication side of building cars it doesn't get any better than this.
LocostUSA.com • View topic - JAF's +221-Haynes/Custom-Miata
Old Sep 27, 2012 | 10:02 AM
Don't you get a lot of snow up there, and isn't it always cold? That does not sound like a good environment for having a 7.
Originally Posted by golftdibrad
They are sweet.
I am not in any hurry of getting started. I have wanted to do a Westfield 7 ever since FM has started selling them. Unfortunately I am not that keen on spending 18k or whatever they are up to now for the kit. So I have been looking heavily into the MOV Exocet because it is around 6k for the kit. I have the spare miata ready and waiting to be taken apart for use in whatever I decide to build.
Truthfully the lack of fabrication skills is the biggest hold back for building my own. Maybe in the future that will change. For now I will spend time enjoying the books, and if in the spring things change and that car up in NY is still for sale I might go for it.
Old Sep 27, 2012 | 12:16 PM
rleete's Avatar
Total Cats: 1,344
Yes, and the garage is unheated. You wanna build a man's car, you have to cowboy up and take a little discomfort.
Or you could just get a salamander type heater.
Old Sep 27, 2012 | 12:32 PM
Saml01's Avatar
Question.
The 442 Frame from Sevenesque like the Champion frame is setup for a live axle. The Gibbs book outlines a frame for IRS.
Has anyone combined the two?
Old Sep 27, 2012 | 01:48 PM
skou's Avatar
Total Cats: 21
The easiest route is to integrate the entire Miata rear subframe.
Others have designed their own rear control arms and modified the "Book" frame as necessary to locate the pick-up brackets and differential mounting points.
There are also plans for modifying the Haynes chassis for Miata uprights. http://www.ntsengineering.co.uk/asse...Guide-rev3.pdf
Old Sep 27, 2012 | 02:33 PM
I moved the thread to the Insert BS section since this has become more of a discussion.
I really want a 7 now.
Old Sep 27, 2012 | 02:57 PM
Joe Perez's Avatar
Boost Pope
Total Cats: 7,549
You know what I really want? A 356 or 550 style roadster that doesn't rely on a 60s vintage VW swingaxle rear suspension and torsion-bar front suspension.
[/threadjack]
Old Sep 27, 2012 | 03:04 PM
Total Cats: 3,591
[/threadjack]
Or aircooled VW powerplant...
I've wanted a Locost for years and have ridden in one on a large autocross course before. Do want.
Old Sep 27, 2012 | 03:27 PM
Joe Perez's Avatar
Boost Pope
Total Cats: 7,549
To be honest, the ACVW engine doesn't bother me. It's extremely compact, extremely lightweight, and can, if properly built and cared for, be made to produce respectable amounts of power (admittedly, at the cost of respectable amounts of money.) Even though the T4 (aka Porsche 914) engine is the choice of serious hot-rodders today, the T1 (Beetle / Ghia) engines are still quite capable and well-supported in the aftermarket- you can even buy brand new all-aluminum cases and mega-port heads for them, along with pre-fabbed turbo headers, injector-ready throttle bodies, dry-sump systems etc.
All in all, it's a good engine for a car like that. If Subaru could shave 150 lbs and about 12" of width off of an EJ20, and eliminate the need for a radiator, then it would be an excellent choice as well. Of course, it would also be a VW engine at that point.
It's the suspension that kills those cars. I remember once reading a review of either the Beck or Thunder Ranch 550, and one thing the said in particular stuck with me (emphasis is mine):
The car transitions very quickly, and is very sharp. This is in spite of the VW steering racks, which seem to have widely variable amounts of slop in them. Some owners say their steering is very tight; mine has 10* of slop constantly, so you start turning the wheel...waiting...then the car turns quick as a slap.
It's also a relatively ill-behaved car, and takes a lot of attention to drive. The steering is heavy and you've got to keep a white-knuckle grip the wheel in turns to keep the car going where you want. The wheel wants to kick back straight with every bump in the road. It's actually quite a bit of work in long sweepers, and it'll wear you out in a track day.
In short, the car drives probably a lot like the original cars, and nothing like the paragon of the cheap reliable track car; the Miata.
That kind of sucks, especially for something so beautiful and with such an awesome power:weight ratio.
Old Sep 27, 2012 | 03:42 PM
Total Cats: 79
It bothers me. And that thing is heavy, no way an ej20, full of water, and a radiator is heavier than that.
