What Size Exhaust Tubing for how much boost? (1.8)
Old Dec 21, 2012 | 11:52 AM
hahajoey's Avatar
Total Cats: -1
Default What Size Exhaust Tubing for how much boost? (1.8)
I'm not sure if I can't find it our theres not sticky post?
Is there like a common knowledge for a certain amount of boost/hp for a certain size exhaust. Like Oh a slapon greddy kit is fine with 2.5".
A begi pushing doubled that HP needs 3".. etc..
Old Dec 21, 2012 | 11:54 AM
3" or greater
Old Dec 21, 2012 | 12:01 PM
Miater's Avatar
Total Cats: 27
3" with large free flow muffler- non turbo.
3" with large free flow muffler- low boost turbo/super charger 5-10lbs
3" with large free flow muffler- higher boost levels 12-xxlbs
These are rules to live by.
Old Dec 21, 2012 | 12:07 PM
baron340's Avatar
Total Cats: 13
With a turbo do not go less than 3" from the turbo straight to the back of the car if at all possible. Anything less is a compromise in spool and power.
Old Dec 21, 2012 | 12:13 PM
Just go 8"
Can't go wrong with 8"
Old Dec 21, 2012 | 12:16 PM
Total Cats: 1,924
https://www.miataturbo.net/dynos-tim...exhaust-64145/
Old Dec 21, 2012 | 12:20 PM
Miater, i had to fix your flawed post.
Old Dec 21, 2012 | 12:35 PM
lololol
Old Dec 21, 2012 | 12:41 PM
hornetball's Avatar
Total Cats: 697
Originally Posted by 18psi
Just go 8"
Does Fae really believe your 3" is 8"?
Old Dec 21, 2012 | 12:50 PM
bullshit.
my BEGI 2.25" to 2.5" DP, to 2.25" cat, to 2.25" borla exhaust
to the same Begi 2.25" to 2.5" DP, 3" cat, and 3" catback:
same dyno. same boost*.
*was getting creep, so i lifted.
Attached Thumbnails What Size Exhaust Tubing for how much boost? (1.8)-scott_beforeafter.jpg
Old Dec 21, 2012 | 12:51 PM
Oh now you've gone and done it: Brain will school you
Old Dec 21, 2012 | 12:53 PM
ah, to be fair he does say he's running less boost.
Old Dec 21, 2012 | 01:21 PM
comradefks's Avatar
Total Cats: -2
I know I'm in the minority here but does the exhaust size recommendation stay the same for supercharger applications as well or is there something different? Thanks.
Old Dec 21, 2012 | 01:26 PM
bigger is always better.
just sound like absolute **** on a SC.
Old Dec 21, 2012 | 01:46 PM
The only reason to not do a 3" exhaust on a turbo car is because you can't afford it AND you're too lazy to build one yourself.
N/A cars should get 2.25" straight-through systems.
Old Dec 21, 2012 | 02:03 PM
Total Cats: 1,924
bullshit.
Lol, don't hate at me bro! Its not my data and its the only comparison I could quickly find.
Your results are obviously better. I believe Curly has something similar going from his Frankenstein exhaust to a 3" ARTech? Couldn't find it quickly.
Ironically, I'm using Cordus old catted 2.5" FM turbo exhaust on my NB with the Rotrex and an BP6D exhaust manifold and factory downpipe. It's less than ideal, but it works for now. I will eventually be replacing manifold with a RB unit and the muffler with a 2.5" Magnaflow 5x11x22 because the ancient FM muffler has definitely seen better days. It's actually significantly quieter than expected, but it rasps on throttle stomps.
Old Dec 21, 2012 | 03:04 PM
hornetball's Avatar
Total Cats: 697
Turbo cars are much more sensitive to the exhaust size because the turbine acts as a backpressure multiplier.
The considerations for a SC car are different and more like doing the exhaust for an NA car (taking into consideration some additional flow). Things like sizing the pipe diameter and length to promote scavenging become important. Bottom line, on an SC car run a good header and an exhaust system matched to the header. That will likely be smaller than a 3".
Old Dec 21, 2012 | 03:15 PM
Total Cats: 1,924
^^ This. Everything I've read backs this up. The only person with an SC setup that I've seen that is running anything bigger is TrackDayHooky. At one point he was running one of the discontinued 949Racing 2.75" exhausts on a 400+HP C38 Rotrex build. No clue what that car has on it now.
Ok, back to the trubo stuff. Who has more apples to apples comparison data for exhaust upgrades?
Old Dec 21, 2012 | 03:23 PM
curly posted a dyno log thing not too long ago.
Old Dec 21, 2012 | 03:32 PM
Faeflora's Avatar
Total Cats: 130
For turbo exhaust you want a Choad
Short as possible and wide as possible.
My 4" isnt that loud. Very deep though. ***** deep
