Old 07-14-2017, 01:11 PM
  #10181
Ok so putting this out for criticism. And to get some input. These are the requirements I am trying to meet.
Current oil drain is a 10AN welded fitting to the oil pan, and a 10AN flange fitting on the turbo.
45* AN fitting on the oil pan, straight fitting on the turbo.
The 45* AN fitting has an ID of .45", so tossing that out immediately. I haven't measured the straight fitting on the turbo, but I assume its the same.
I also need to measure the ID of both the turbo drain fitting, and the oil pan fitting. And possibly enlarge both of those with some sort of reamer. You can see in this picture that you can take out a good amount of ID and still get a surface to seal.
Here is my current oil drain.
So I don't trust my measurements in the car to make a full hardline tube, so instead I am going to have 2 10AN stubs of thin wall tubing flared for 10AN. One of them will be bent towards the turbo, and the other will be a short piece that will come off the turbo. I will then connect the 2 pieces with a piece of oil cooler hose and some clamps. This should give me a direct flow, with minimal restrictions.
New drain line will be:
10AN in the oil pan
10AN tube flared, with a sleeve and tube nut. This piece will have a radius bend to point towards the turbo.
Piece of high temp oil hose, clamped to the tube
10AN tube flared with a sleeve and tube nut, this piece will point straight down from the turbo, or possibly point towards the drain.
Both 10AN fittings will be drilled out to maximum size.
Fingers crossed that this stops the smoking.
Old 07-14-2017, 02:04 PM
  #10182
thumpetto007's Avatar
Total Cats: -117
Now all you need are inconel exhaust valves so you can run man boost on track!
thumpetto007 is offline
Old 07-14-2017, 02:15 PM
  #10183
psyber_0ptix's Avatar
I feel the need to pull my motor to fix my drain now too....
efff
psyber_0ptix is offline
Old 07-14-2017, 02:18 PM
  #10184
Originally Posted by thumpetto007
Now all you need are inconel exhaust valves E85 so you can run man boost on track!
fixed
Old 07-14-2017, 02:34 PM
  #10185
You buying?
efff
If it ain't broke don't fix it. Mine is broke.
And in reality this may not be my issue, but its a first step.
Originally Posted by 18psi
fixed
Not available around here. Bring me a barrel to MRLS.
Old 07-14-2017, 02:37 PM
  #10186
Better yet: stop by sacramento on your way to MRLS and gimme a ride
or
I might make it out to MRLS if I need to tune a car up there or something. hint hint, G
Old 07-14-2017, 02:39 PM
  #10187
Lol. I'll see what i can do.
Old 07-14-2017, 02:50 PM
  #10188
patsmx5's Avatar
Total Cats: 488
My current setup is 3/4" NPT tapped the pan, put a fitting in it with a 3/4" hose barb, and put a 3/4" hose on it and ran that to the turbo. No leaks, no smoke, and it's not expensive or complicated to do. If the turbo is so sensitive to having a good drain, I'd go 12AN or 3/4" hose. The 3/4" hose approach keeps the ID large everywhere. As you know AN fittings can get smaller in bends, etc vs bending a large hose with a smooth radius doesn't kink like the fittings often do.
patsmx5 is offline
Old 07-14-2017, 03:58 PM
  #10189
Total Cats: -117
https://www.flyinmiata.com/inconel-1...ust-valve.html
I'll buy you one, not joking. Get a group funding thread going, I'm sure you could get the other 7
Its good for the community, and it allows people to live vicariously through your boost.
Also, I'm tired of your excuses... ah its too hot for this, too much of that, blah blah blah :P
Old 07-14-2017, 04:14 PM
  #10190
Currently you are running a Journal bearing turbo too right? This mostly applies to ball bearing turbos.
Old 07-14-2017, 04:55 PM
  #10191
Total Cats: 856
It also appears to mostly apply to EFR turbos? Never had any problems with a -10AN drain on my Garretts. I use a 45-degree NPT-to-AN fitting though, rather than a 45 degree hose end.
--ian
codrus is offline
Old 07-14-2017, 04:58 PM
  #10192
Yeah. And other people have run EFR's without issues. You have a much longer drain line. Which allows the oil to return to liquid form, which can help keep it from backing up.
The general principle is simple.
Old 07-15-2017, 11:52 AM
  #10193
patsmx5's Avatar
Total Cats: 488
I don't know what you are reffering to by "this". Anyways you said you thought your oil drain isn't working well enough for your turbo, so I posted what I think would work better, and that's as far as my post was intended to go. I don't know what drain ever turbo needs, but I do think my turbo drain would flow better than what you have now.
patsmx5 is offline
Old 07-15-2017, 02:58 PM
  #10194
Total Cats: 553
​​​​​​This.
Your drain is awfully short, so do what Pat said and move on.
sonofthehill is offline
Old 07-15-2017, 08:29 PM
  #10195
Total Cats: 104
It must be luck of the draw on the EFRs all the MZR turbo kits, including the EFR ones have the turbo oil drain below the oil level in the pan. Which I do find annoying, but there's really no other way to do it, the resting oil level is above the oil pan gasket (mine dribbles where I forgot to torque one of the bolts when the rtv was wet). But on the other hand that motor also pulls a ton of oil out of the crankcase while its running.
Leafy is offline
Old 07-15-2017, 10:32 PM
  #10196
Total Cats: 3,019
Ryan_G had EFR drainage issues, check his build thread. Not sure why they are more sensitive but all manufacturers are different. Bigger than the listed minimums wouldn't hurt.
sixshooter is online now
Old 07-16-2017, 04:00 PM
  #10197
icantlearn's Avatar
Total Cats: 117
I might make it out to MRLS if I need to tune a car up there or something. hint hint, George
ftfy
icantlearn is offline
Old 07-16-2017, 09:46 PM
  #10198
farpolemiddle's Avatar
Total Cats: 95
farpolemiddle is offline
Old 07-17-2017, 12:03 AM
  #10199
Originally Posted by MiataMan00
ftfy
No problem
Gotta find some straight and uncrowded roads near there tho. It was a serious struggle with Geoffs car to do a proper pull/log last time
Old 07-17-2017, 12:12 AM
  #10200
No miataing this weekend. Instead we were gamblin.
