OGK
Old 12-21-2017, 08:57 AM
  #161
FatKao's Avatar
Total Cats: 32
Originally Posted by Leafy
No, I've been waiting for it for like half a decade.
Didn't know it's been around for so long. Is this using the MS to send outputs to some OEM ECU to control the throttle?
FatKao is offline
Old 12-21-2017, 09:04 AM
  #162
Total Cats: 104
Cars have been coming with electronic throttle bodies since the early 2000s.
Leafy is offline
Old 12-21-2017, 10:22 AM
  #163
It is currently set up to send commands to an unreleased piece of hardware, which will in turn control a DBW throttle body.
Old 02-02-2018, 01:59 PM
  #164
Total Cats: 2,378
Some carbon things arrived today
.31 SNR
emilio700 is offline
Old 02-02-2018, 02:00 PM
  #165
Total Cats: 1,681
Is that a carbon rotor?
shuiend is offline
Old 02-02-2018, 02:14 PM
  #166
flier129's Avatar
Total Cats: 319
flier129 is offline
Old 02-02-2018, 04:18 PM
  #167
Stealth97's Avatar
Total Cats: 66
3d printed
Stealth97 is offline
Old 02-02-2018, 07:06 PM
  #168
Total Cats: 104
God I wish that was legal in my class.
Leafy is offline
Old 02-03-2018, 11:50 AM
  #169
glade's Avatar
Total Cats: 17
PFCs?
Indy lights?
I too was looking into carbon rotors, curious what avenue you've used
glade is offline
Old 02-03-2018, 07:21 PM
  #170
Total Cats: 2,378
F1
.31 SNR
Old 02-20-2018, 01:41 PM
  #171
Total Cats: 2,378
Default Scan this
Pushed the tub across the street to get scanned by Joe at Scarbo Performance. We're also scanning the subframes, spindles and control arms. Current plan is the gen 2 Keisler drop spindles and our own tubular/spherical bearing control arms. If the arms turn out well, we'll probably put them into production for 2019. We would not bother with a bushing version. The performance envelope we are engineering for requires control arms that do not currently exist anywhere on the planet. The tub will get a major portion lopped off front and rear, as GTA Unlimited rules allow that. Firewall modified to move engine back um, a lot. The entire body will be carbon fiber hung on tubular subframes. Plans for aero require removing most of the OEM tub too. Much measuring, many CAD.
Seen in this pic: surface plate, Romer arm, 5 axis CNC mill, Sonny, hacked up Miata.
.31 SNR
Old 02-20-2018, 01:46 PM
  #172
HarryB's Avatar
Total Cats: 140
"Miata". I like where this is headed though. A lot!
HarryB is offline
Old 02-20-2018, 01:50 PM
  #173
Total Cats: 2,378
Yah. When it's done it'll retain the head casting, block casting, timing belt hardware and the center of the floor pan. Everything else will be fabbed bits. Might keep the tail light lenses.
.31 SNR
Old 02-20-2018, 01:54 PM
  #174
mx5-kiwi's Avatar
Total Cats: 57
Not sure your "really" pushing any boundaries here....
Looking forward to high end parts development for the rest of us!
mx5-kiwi is offline
Old 02-20-2018, 02:42 PM
  #175
dcamp2's Avatar
Total Cats: 69
do you have to run the miata block/heads per rules or just because that's what you know/sell?
dcamp2 is offline
Old 02-20-2018, 03:01 PM
  #176
Total Cats: 2,378
Compact, meets our power goals. Also comes with no small measure of satisfaction of being the fastest Miata evar.. and doing it with an actual Miata engine.
Rules are wide open. Rear mounted transverse Cummins, no problem. Side/Mid mounted 26B, no problem.
.31 SNR
Old 02-20-2018, 05:30 PM
  #177
flier129's Avatar
Total Cats: 319
This build is like my wet dream come true.
flier129 is offline
Old 02-20-2018, 05:58 PM
  #178
LukeG's Avatar
Total Cats: 166
What is that red car on the lift in the top right of the pic?
LukeG is offline
Old 02-20-2018, 06:06 PM
  #179
Arca_ex's Avatar
Total Cats: 428
Will need most of the front firewall to still be there as well to stay in Unlimited.
Can't wait to see this thing progress.
Arca_ex is offline
Old 02-20-2018, 06:21 PM
  #180
Total Cats: 2,201
355 Challenge i think?
concealer404 is offline
Quick Reply: OGK
