Old 05-09-2017, 07:57 PM
  #521
Total Cats: 1,899
For various and sundry definitions of the word "need"
EO2K is offline
Old 05-11-2017, 02:59 AM
  #522
Total Cats: 553
So for the record I can't run more than 33% boost duty post spool now without exceeding 20psi all the way through 7000. The new can is working.
Lars, your can is almost done, I should be sending out either Friday or Monday.
sonofthehill is offline
Old 05-11-2017, 05:21 PM
  #523
My my, your cans sure do seem to get around.
Old 05-11-2017, 08:36 PM
  #524
Total Cats: 553
Lars' has slightly different construction, I used a valve stem section of an inner tube for the internal seal as well as the outer one(not pictured.). I also learned that mountain bike tubes work better than road bike tubes.
Next time I will incorporate another grommet and I may dispense with the piston altogether for 2 fender washers after seeing Aidan's pics.
I have a cool idea for a piston type can too.
As far as I can tell my cans are the only alternative to the $150 turbosmart dual port in existence, besides Bronson M's. I am no longer convinced that any of the other dual port internal wastegate cans are actually capable of holding the wastegate shut.
Old 05-12-2017, 01:13 AM
  #525
turbofan's Avatar
Total Cats: 1,009
This is pretty damn cool.
Ed@949Racing/Supermiata
www.949racing.com
www.supermiata.com
turbofan is offline
Old 05-12-2017, 02:32 AM
  #526
Total Cats: 553
Thanks Ed!
Old 05-12-2017, 03:11 AM
  #527
Total Cats: 553
I love this place! Wait, did I say that already?
Uh oh, too much alcohol tonight
Old 05-12-2017, 03:52 AM
  #528
Art
Art's Avatar
Total Cats: -251
Art is offline
Old 05-12-2017, 04:02 AM
  #529
Total Cats: 553
Yes, definitely​, silicone valve and faucet lube on both of the seals. Good stuff.
Old 05-12-2017, 09:38 PM
  #530
Total Cats: 553
I need to mark my calendar, my car is actually clean today. No I am not gonna do clay bar, paint correction, ect... It will be lucky if I put a coat of wax on.
I seem to have accumulated a few pounds of leaves at the bottom of the fenders. What is the best way to get them out, do I need to remove the bottom bolts?
Old 05-13-2017, 12:47 AM
  #531
remove the bottom 2-3 fender liner clips/screws.
flush out with water
done
Old 05-13-2017, 01:37 AM
  #532
Total Cats: 553
Great, thanks! That sounds way easier, I was trying to pull them out from the door jam. It wasn't happening.
Old 05-13-2017, 10:15 PM
  #533
Total Cats: 553
Got the leaves out, that might improve my 60' time
I decided I can't run my feed line any longer. It definitely started to seep a little oil, it's​ getting to the point where if I don't deal with it, could be dangerous.
I can't fault the MKTURBO oil lines for this and my drain is still dry as can be. I twisted the line a little last time I had it off, and was expecting something like this. It actually failed very gradually and I had to run it for a few more days to see that it was actually leaking. Luckily, with the nice fittings Lars used I just need a piece of hose. I am having Lars send me a new one but I will try rebuilding this one as well.
Old 05-15-2017, 10:28 PM
  #534
Total Cats: 553
Well the local hydraulic shop didn't have any of the nice aeroquip hose I wanted but he did make a hose that will work. Lars' hoses are a better deal and nicer, but he is 3000 miles away instead of 4.
This will at least allow me to run this Wednesday. I think I will order a 15' piece of the hose from jegs or something. I can make 4 replacements with one 15' piece. Should last many years.
Old 05-18-2017, 02:10 AM
  #535
Total Cats: 553
Random post.
Been wanting to post this for a while, but oh well. Bob Marley song edit;
"How many suckers do we have to pahass, B4 we can stahomp, on the ghaass?"
That's what I want to know.
Old 05-18-2017, 02:12 AM
  #536
Total Cats: 553
Yes, I have been drinking. Moylan's red ale, so ******* good
Old 05-18-2017, 01:13 PM
  #537
Drunk sonofthehill is the best sonofthehill
Old 05-29-2017, 12:55 PM
  #538
Total Cats: 553
What happened, blue sky and the sun is shining. I thought Brain was supposed to fly into town today, oh well, maybe only SF is socked in with fog. I do need to go to SF today if you are in town, I am happy to give you a ride in the MK-Foo Foo.
Old 05-31-2017, 02:28 AM
  #539
Total Cats: 553
Didn't hear from Brain but Lars came through again. This replacement feed line was a deal. It's much nicer and less expensive than the one I had made locally.
You didn't need to give me another can. I will pry this one open and make it work properly, in case my second one has any​ issues. You make me wish I included the linkage parts, but they need to come off to fit in the bracket so I left them off. Oh well.
Thanks again Lars!
Old 06-02-2017, 09:58 PM
  #540
Total Cats: 553
Another functional IWG can. This one uses 2 small grommets inside washers to seal the shaft and 2 smaller grommet to seal the bolts. It holds 40psi on the back side, no problem and I can barely move the shaft with 20psi on it. I will still add a valve stem section of an inner tube between the can and bracket, but this one doesn't seem to need it. Best can yet, I almost used the light spring in the picture but I decided anyone using this wouldn't mind 10psi base pressure.
