91 BRG 1.8BP MK turbo build
Old 12-14-2016, 10:00 AM
  #101
Total Cats: 1,149
If you don't loose any parts in the gear (I think that's what you mean by actuator), and take plenty of photos, taking it apart is very easy. That being said I've hardly ever seen one leak from the big o-rings. Or the little ones for that matter. But you can take the bolts out one at a time without any disassembly.
curly is offline
Old 12-14-2016, 10:47 AM
  #102
wackbards's Avatar
Total Cats: 266
Thanks for the feedback. What kind of torque value do you aim for on the four bolts with O-rings?
wackbards is offline
Old 12-17-2016, 02:09 PM
  #103
wackbards's Avatar
Total Cats: 266
I hand lapped all the valves last night. It's tedious but rewarding. All the seats look really good now. Next up, water checking how well they're sealing.
Old 12-20-2016, 05:02 PM
  #104
wackbards's Avatar
Total Cats: 266
Got the head decked, and all the valves/springs/keepers installed. The plastic bag trick for installing keepers is the jam. All valves passed leak test. I'm just waiting on a couple shims to finish putting it all back together.
Old 12-21-2016, 03:04 PM
  #105
wackbards's Avatar
Total Cats: 266
Christmas came early! I has churbo.
Old 12-21-2016, 04:06 PM
  #106
Total Cats: 1,681
WootWoot!
Your manifold and mid pipe are on the way. Your down pipe and axle back are sitting on my garage floor with 4 or 5 other setups waiting to go out as soon as I get boxes in.
shuiend is offline
Old 12-21-2016, 05:27 PM
  #107
wackbards's Avatar
Total Cats: 266
Originally Posted by shuiend
WootWoot!
Commmooonnnnn boxes....
Old 12-21-2016, 07:42 PM
  #108
wackbards's Avatar
Total Cats: 266
Freeze plugged the front coolant neck. I sealed it with aviation form-a-gasket. I think I'll repurpose my coolant neck block off plate here to hold the plug in place.
Old 12-22-2016, 07:50 AM
  #109
Total Cats: 1,681
They got done yesterday. Trying to find a truck to borrow so I can go pick them up today.
shuiend is offline
Old 12-23-2016, 04:56 PM
  #110
wackbards's Avatar
Total Cats: 266
Manifold & MP arrived today. Kitteh approves.
Old 12-23-2016, 05:04 PM
  #111
wackbards's Avatar
Total Cats: 266
I think Lars slipped some catnip in the box...
Old 12-28-2016, 05:24 PM
  #112
wackbards's Avatar
Total Cats: 266
Opened up the WG today. Here's the original port. The ID is 17.6mm, and the OD of the flapper is 29mm, although the flapper lip has a slight fillet to it. Other builds have had success with increasing the ID by 5mm. Here you can see my marks for the OD of the flapper and my target WG hole centered under the flapper (the existing WG hole is offset under the flapper). I used the aluminum bung that DIY sells with their IAT kit as my template for the WG hole I wanted to make. It has an OD of 23mm and a small chamfer, which made for a pretty ideal template for my target ID of 22.6mm.
Here's the finished product:
Here's how the flapper covers the new hole:
After taking measurements, I'm 7% undersized from my target area of 400 sq mm. I'm gonna try this out as is. If I still get creep, I'll remove more material. I'd rather be conservative about how much material there is to seal the flapper. It's a hell of a lot easier to remove metal than it is to put it back in...
Old 01-10-2017, 01:55 PM
  #113
wackbards's Avatar
Total Cats: 266
I managed to measure all my lifter shims before I lapped my valves in. I double checked my clearances last night, and they're all whack now. Thems was some dirty valve seats. Live and learn. Nothing like buying stuff twice.
Old 01-14-2017, 11:56 PM
  #114
Alberto Chipres's Avatar
F%@K! can't believe I missed out on this deal. If sale falls thorough. I'm interested.
Alberto Chipres is offline
Old 01-15-2017, 12:20 AM
  #115
wackbards's Avatar
Total Cats: 266
...potato.
Old 01-15-2017, 02:03 AM
  #116
Default Ms2
Old 01-15-2017, 02:05 AM
  #117
...potato.
Mobile is being weird. Posted in another thread and showed up here?
Old 01-15-2017, 07:51 AM
  #118
Total Cats: 1,681
I mean you can always send me an email and get in on a sweet MKTurbo setup. It just won't be as good as a deal since the group buy is over.
shuiend is offline
Old 01-17-2017, 07:51 PM
  #119
Default Ms2
Old 01-17-2017, 08:00 PM
  #120
wackbards's Avatar
Total Cats: 266
I saw your post about possibly selling an ms2. Can I get more info on that please?
... Still nope. But here's a picture for you.
Quick Reply: 91 BRG 1.8BP MK turbo build
