New NC 1.8 build from Greece
Old 04-04-2016, 06:50 AM
gianic's Avatar
Total Cats: -14
Default New NC 1.8 build from Greece
After 5 NBfl's (the 3 were turbocharged) I decided to try my turbo luck on the NC building a custom kit from scratch using stock internals.
I am going to use a TB28 from Nissan GtiR equivalent to the gt2860rs and will try to stay to 0.6-0.7 bar.
For fueling I am using the ev14 550cc injectors working great with the OEM ecu like the stock ones. Perfect idle and afrs.
So far we are here.
I hope to see more Turbo NCs soon.
Attached Thumbnails New NC 1.8 build from Greece-12592530_1218945498118755_513895399086015823_n.jpg   New NC 1.8 build from Greece-12931234_1221148334565138_1926193628777665038_n.jpg   New NC 1.8 build from Greece-12963828_1221149154565056_7132088907162455726_n.jpg
gianic is offline
Old 04-04-2016, 12:40 PM
Chilicharger665's Avatar
Total Cats: 57
You need to get with Joe at Dynotronics for a 2.5 when you bust the 1.8
As far as I understand, the 1.8 is just a smaller-bored 2.0 block, so a 2.5 block is only a bit taller, so it would easily pass any visual inspection, if that is a problem where you are.
I will be getting a 2.5 swap from Joe soon. The Fab9 EFR turbo kit is coming out soon and then you will definitely start seeing more turbo NC's.
Chilicharger665 is offline
Old 04-04-2016, 02:48 PM
gianic's Avatar
Total Cats: -14
Well I am located in Greece and the 2.5 engines are extremely rare and expensive so I am not interesting in swapping.
We 'll see how it will handle the boost the poor 1.8
gianic is offline
Old 04-05-2016, 09:17 AM
gianic's Avatar
Total Cats: -14
And mounted:
Attached Thumbnails New NC 1.8 build from Greece-12718089_1221871637826141_1237282219820478513_n.jpg   New NC 1.8 build from Greece-12963900_1221871771159461_5995336452242382924_n.jpg
gianic is offline
Old 04-05-2016, 10:08 AM
Total Cats: 57
The manifold looks good! Are you going to shield the alternator at all?
Well, when the time comes, Joe has said that he can ship a built 2.5 to you for cheap, so you don't need to worry about 2.5's being rare and expensive where you are at.
Old 04-05-2016, 12:50 PM
gianic's Avatar
Total Cats: -14
Yes I may put some insulation on the 4th runner.
gianic is offline
Old 04-14-2016, 05:09 AM
gianic's Avatar
Total Cats: -14
And here it is fitted on a spare engine in the shop
Attached Thumbnails New NC 1.8 build from Greece-80-5acab2abf78fdbf1e0a7ca90d660dcc6_e819ff8cdbea2f2006ce25a5ae4fa183c4ec3756.jpg
gianic is offline
Old 05-24-2016, 07:56 PM
gianic's Avatar
Total Cats: -14
And there it begins.
Engine bay
Here is one first test with some basic tuning and very safe ignition timing @ 0.4bar
www.youtube.com/watch?v=hURqbGojKd0
And now MOAR boost @ 0.6bar but with still very safe afrs and ignition.
Attached Thumbnails New NC 1.8 build from Greece-80-39c050be8a41d020425072a657330e56_bd8436ed13d1165a8a0f643f603f7553db197cdb.jpg   New NC 1.8 build from Greece-80-39c050be8a41d020425072a657330e56_bd8436ed13d1165a8a0f643f603f7553db197cdb.jpg
gianic is offline
Old 06-03-2016, 01:05 PM
gianic's Avatar
Total Cats: -14
A small update:
So far the stock ecu seems to handle boost great. The load measurements via MAF are precise and the afrs are solid!
I even added the zeitronix map sensor to the original ecu with the proper calibration and now ecu can recognize boost succesfully!
This is a very friendly to boost car and I am wondering why so few people have tried boosting it... The engine is responding great and I think that it can handle more torque than the stock BP or B6.
Such a shame we have no feedback from other NC turbo owners.
Any comments on the setup are highly appreciated!
gianic is offline
Old 06-03-2016, 01:12 PM
Total Cats: 1,681
Because we are cheap and the majority of us don't want to spend the cash required to get a NC.
shuiend is offline
Old 06-03-2016, 01:15 PM
gianic's Avatar
Total Cats: -14
How much does a 06 NC costs in US ?
gianic is offline
Old 06-03-2016, 01:16 PM
Total Cats: 1,681
More then NA/NB's. I think they are starting to drop below 10k USD, but I honestly don't follow the NC market to much.
shuiend is offline
Old 06-03-2016, 01:24 PM
gianic's Avatar
Total Cats: -14
Here are dirty cheap. You can find for 5-6k€ the early ones.
Also the turbocharging is waaaay cheaper than the na/nb. There is no need for gauges wideband(stock NC sensor) and boost can be monitored via Torque app with a 7" tablet
No need for extra piggyback or standalone ecu and the stock exhaust has a decent size of 2.36" (not ideal but not too bad)
Also the stock FPump can handle 300hp so a walbro won't be necessary for anytime soon.
I am also suprised from the clutch. After on month it is still holding strong, but I don't think it will last for much long.
gianic is offline
Old 02-18-2017, 02:09 PM
gianic's Avatar
Total Cats: -14
Today I upgraded to 3" maf intake. Wow what a difference! No more check engines at WOT and runs lovely at 15psi . Before I was maxing out the MAF at 12psi throwing a CEL.
It took me about 3 reflashes to get it right and now it runs like before.
Also I managed to put some extra protection with richer afrs and safer timing in case of overboost and overheating , just in case.
I took it for a mountain spirited ride and it was a blast to drive. I am very excited of the potentials of the stock ECU it gives really no limits to the tuner.
gianic is offline
Old 02-18-2017, 02:20 PM
are you self tuning it? what with? ecutec?
Old 02-18-2017, 02:48 PM
gianic's Avatar
Total Cats: -14
Yes self tuning with Mazdaedit. I have tuned many other NCs here and a tonne of nb's and na's with standalones and piggybacks.
gianic is offline
jstck
ECUs and Tuning
25
05-09-2018 03:41 AM
Arca_ex
61
05-15-2017 09:57 AM
hockey930
Engine Performance
4
04-02-2016 11:31 AM
d3ck5
11
04-01-2016 10:01 PM
thirdgen
04-01-2016 01:32 PM
Quick Reply: New NC 1.8 build from Greece
