1.8 EWG gt2560
Old 03-09-2017, 04:41 PM
  #81
Nudge.
https://www.miataturbo.net/miata-par...pistons-92445/
Probably not the compression you want.
Old 03-09-2017, 05:51 PM
  #82
LownSlow616's Avatar
Total Cats: -23
Id run em.
U pay for the machine work, a mitutoyo 3-4" micrometer, and a dial bore gauge? Ill buy the pistons!
LownSlow616 is offline
Old 03-09-2017, 09:48 PM
  #83
Can one survive on something lower on the food chain than ramen?
Old 03-25-2017, 08:52 AM
  #84
Total Cats: -23
made a new water pump inlet out of aluminum. Uses factory fasteners, gasket, and lower rad barb. vibrant -6 fitting for turbo water line. a lot cheaper than the hawley cnc version!
Old 03-25-2017, 10:37 AM
  #85
Total Cats: -23
can anyone explain what all this stuff is and if i need it?
Old 03-25-2017, 05:01 PM
  #86
Total Cats: -23
anyone know who makes the best automotive wiring "stuff?" crimp connectors, heat shrink, covers for harnesses, etc. Is there a "vibrant performance" of wiring supplies?
Old 03-25-2017, 05:10 PM
  #87
Its a lot more complicated than just picking one seller.
There is some good info starting here: https://www.miataturbo.net/engine-pe...4/#post1397951
But it really takes a lot of your own research.
Old 03-25-2017, 10:12 PM
  #88
mmmjesse's Avatar
Total Cats: 44
i have used wirecare.com and ballenger motorsports. ballenger has a section specifically for miata connectors. Ballenger Motorsports - High Performance Electronics
There is a thread on here called connector witchhunt that might be useful also.
mmmjesse is offline
Old 04-01-2017, 12:12 PM
  #89
Total Cats: -23
Gen2 gtx3071r with tial .82 vband in/out housing. 4" anti surge inlet, billet comp wheel, same old *** turbine wheel (i think)
Old 04-01-2017, 07:15 PM
  #90
patsmx5's Avatar
Total Cats: 493
That turbo looks sweet!
patsmx5 is offline
Old 04-02-2017, 10:02 AM
  #91
Total Cats: -23
thanks! I agree! Its going to look pretty big in the engine bay compared to my old gt2560
Old 06-27-2017, 02:35 PM
  #92
Total Cats: -23
Engine assembled. Full specs are:
-Manley Rods
-OEM 9.5:1 cast pistons
-Re-used 44k mile oem rings
-ACL main and rod bearings
-ARP main studs
-ARP head studs
-BE stage 2, 1 shim oil pump
-ATI damper
-Stock head
Old 06-27-2017, 02:37 PM
  #93
elior77's Avatar
Total Cats: -481
Super sexy
elior77 is offline
Old 06-27-2017, 02:38 PM
  #94
Total Cats: -23
Coolant re route setup:
Old 06-27-2017, 02:44 PM
  #95
Total Cats: -23
for the fuel system, I wanted to convert my '99 to a true return-style setup
-DW300 pump
-6AN line from pump to fuelab inline filter mounted where charcoal canister used to be
-6AN line from filter connects to stock feed hard line
-Feeds to FM fuel rail
-ID1000 injectors
-Return through fuelab mini fpr (manifold referenced)
-6AN return line from fpr to flex fuel sensor mounded in stock fuel filter location
-6AN line from flex fuel sensor to tank
MXL strada displaying ethanol content
Old 06-27-2017, 02:48 PM
  #96
Total Cats: -23
Crank case vent system:
-stock baffles
-hole enlarged between chambers
-10AN lines
-Chikara breather tank
Old 06-27-2017, 02:50 PM
  #97
Total Cats: -23
old gt2560 on for "break in" period
Old 06-27-2017, 03:02 PM
  #98
Total Cats: -23
I have about 300 miles on the new engine- running e85 and 10 psi on the gt2560. After that I compression tested each cylinder to make sure the used rings "re-sealed." Compression came out around 170 for each cylinder. So its time to make some real power. Currently in the process of installing the gtx3071:
Old 06-27-2017, 03:12 PM
  #99
yossi126's Avatar
Total Cats: -15
Awesome work Reed, looking forward for further updates.
yossi126 is offline
Old 06-27-2017, 03:14 PM
  #100
That looks really sexy
Quick Reply: 1.8 EWG gt2560
