m2k Build! From supercharged 1.6l to F20c
Old 10-05-2016, 01:11 PM
rollie's Avatar
Total Cats: 16
Default m2k Build! From supercharged 1.6l to F20c
Another season has ended which means its time to tear into the Miata again. Last winter I built up the m45 supercharger setup with a custom wiring harness, new pulleys (~11psi), custom belt setup, air to water intercooler, ID1000's, and lots of engine bay clean up. I was making ~170whp on e85 which is good power for a light Miata, but I was still wanting more. After looking into a K swap I didn't want to use a miata trans with the potential to go turbo and grenade the trans. I happened upon a full F20c dropout (motor, trans, diff, driveshaft, axles, header, accesories, mounts, and the harness) for cheap while I was looking for an s2000 trans. Once I realized how good of a deal it was I made the spontaneous decision to pick it up and swap it.
I've already pulled most everything in the engine bay out and listed it for sale in the classified section.
Currently the motor is at the machine shop getting sleeved and cleaned up after finding out the motor I picked up had a spun bearing (still worth it for the price though). I picked up a new block and thats what will end up in the car. The plan is to complete the swap NA for next season and then turbo to ~350whp the season after that. I'm going to attempt to use my custom harness for the f20c and MS3x. This will be used for daily driving in the summer, track days and autocrosses. Probably no more rallycross once this swap is done.
How the car used to look:
And how it sits now:
rollie is offline
Old 10-05-2016, 02:17 PM
G3ML1NGZ's Avatar
Total Cats: 102
Turbo f20c sounds fun. 2.0 or 2.2?
G3ML1NGZ is offline
Old 10-05-2016, 02:28 PM
psyber_0ptix's Avatar
I want the silver one
psyber_0ptix is offline
Old 10-05-2016, 02:31 PM
rollie's Avatar
Total Cats: 16
F20c is the 2.0l but yeah reliable turbo power (chuckles) would be stupid fun in this car. You can talk to acedeuce802 about the ls swapped 99. We've got a pretty crazy garage going on haha.
rollie is offline
Old 10-05-2016, 03:05 PM
Sell it to me
Old 10-05-2016, 03:06 PM
rollie's Avatar
Total Cats: 16
Yeah good luck with that. Diff mount should be complete tonight. I've cut the PPF and added a turn buckle and tabs to the rear subframe to support the OS Giken diff in the torsen LSD housing.
rollie is offline
Old 10-05-2016, 03:26 PM
acedeuce802's Avatar
Total Cats: 175
acedeuce802 is offline
Old 10-05-2016, 09:04 PM
rollie's Avatar
Total Cats: 16
Not the prettiest picture, but it's in and works. Ignore the over spray, it's under the car and my level of ***** when I got to painting was pretty low.
rollie is offline
Old 10-06-2016, 10:17 PM
rollie's Avatar
Total Cats: 16
All of the motor bits are back from the machine shop. Just waiting on the pistons to come back from being coated till I can assemble the block. The head still needs some work unfortunately.
rollie is offline
Old 10-20-2016, 06:51 PM
rollie's Avatar
Total Cats: 16
Tonight I got the fuel lines in. Braided stainless supply line with inline filter and a rubber return with the flex fuel sensor. Also got the trans mount bushing sorted out, turns out a Chevy Camaro bushing has the same bolt spacing as the s2000 mount. Ignore the kinked rubber hose, its a place holder at the moment. Also you can see the mounting for the filter and flex fuel sensor are on the opposite side as the OEM mounting because the exhaust will be on that side now.
rollie is offline
Old 10-22-2016, 06:06 PM
rollie's Avatar
Total Cats: 16
Got the vacuum pump on the s2k manifold welded up. Currently waiting on oem engine parts to show up to put the motor back together.
rollie is offline
Old 10-30-2016, 06:35 PM
rollie's Avatar
Total Cats: 16
I managed to get most of the motor back together this weekend. Just waiting to get the head back now and it'll be ready to mock up in the engine bay.
rollie is offline
Old 10-30-2016, 07:53 PM
dc2696's Avatar
Total Cats: 21
Details on the F20 build plans, low comp/stock compression? For <400whp I'd just use a supercharger, especially if you're going to do some track driving.
dc2696 is offline
Old 10-30-2016, 07:57 PM
rollie's Avatar
Total Cats: 16
I'm rebuilding it to stock specs even though I had to sleeve the block. Tuned on e85 on a stock rebuild should be somewhere above 210whp. A supercharger is definitely under consideration given my experience on 1.6l. I think a turbo would be a more interesting challenge, especially when trying to make it reliable on track.
rollie is offline
Old 10-30-2016, 08:10 PM
dc2696's Avatar
Total Cats: 21
Good to hear! I think most people would tell you about peakyness of the F20 + turbo makes for a less enjoyable drive than a supercharger. If I tracked my AP1 more I definitely look at switching from a turbo setup to a supercharger
dc2696 is offline
Old 10-30-2016, 08:13 PM
rollie's Avatar
Total Cats: 16
Yeah more low end torque would definitely be beneficial. Thanks for the first hand insight! That definitely helps make the decision.
rollie is offline
Old 11-04-2016, 12:45 PM
rollie's Avatar
Total Cats: 16
Got the cylinder head back from the 3 angle valve job and installed the valves and springs last night. I'm going to attempt to have the motor completely back together tonight
rollie is offline
Old 11-04-2016, 06:38 PM
turbofan's Avatar
Total Cats: 1,009
Looks like it will be a lot of fun.
Ed@949Racing/Supermiata
www.949racing.com
www.supermiata.com
turbofan is offline
Old 11-04-2016, 10:44 PM
rollie's Avatar
Total Cats: 16
I sure hope so! I got really motivated and got the motor fully assembled (minus small hoses and what not) tonight. LS coils are just chilling there but that's where I'm considering placing them assuming they clear the hood in the car.
rollie is offline
Old 11-08-2016, 08:56 AM
rollie's Avatar
Total Cats: 16
Got the subframe chopped up and motor very close to its final position. I had to create a lot of clearance for the exhaust on the passenger side so that half of the subframe is gonna require more playing to finish up. The motor sits extremely low so a skid plate will definitely be in the works.
rollie is offline
Quick Reply: m2k Build! From supercharged 1.6l to F20c
