Tarmac 88 "Button" GLTC/ST5/TT5
Old 09-19-2018, 10:21 PM
  #281
Total Cats: 2,378
Originally Posted by Efini~FC3S
Why is there a Lexus on display at "Mazda" Raceway Laguna Seca...
Mazda no longer corporate sponsor (boo). I call it Floormat Raceway.
I believe the official name is Weathertech Raceway Laguna Seca presented by Lexus or some such ****.
.31 SNR
emilio700 is offline
Old 09-20-2018, 08:54 AM
  #282
Efini~FC3S's Avatar
Total Cats: 98
Ahhh...for some reason I thought Mazda had it until the end of the year.
Efini~FC3S is offline
Old 09-20-2018, 10:04 AM
  #283
Midtenn's Avatar
Total Cats: 267
Found a better post to make a stupid comment
Midtenn is offline
Old 09-24-2018, 11:28 PM
  #284
doward's Avatar
Total Cats: 754
A failed valve cover gasket caused a big ol’ mess at Laguna Seca. So, a fresh OEM Mazda piece was installed tonight. I discovered a broken coil pack mounting bracket, so I had to swap in my last known-good spare.
If it brakes again, I’ll be forced into a TSE CoP upgrade, clearly. Totally.
Also on the list was to cut and fish out the hood catch loop. Grams yo. Racecar weight weenie-ing continues.
Also: Don’t Suck covering my worthless oem speedometer. (4.3/6spd)
doward is offline
Old 09-24-2018, 11:36 PM
  #285
mx5-kiwi's Avatar
Total Cats: 57
Not sure if this question is suitable in this thread..? (or even confidential).
Is the splitter length in the various photoss of 949 cars one decided upon by performance or one decided on via rules?
i.e. we run quite a bit longer (approx double what I see here, if not slightly more) and wonder if this is just more drag for little benefit....
mx5-kiwi is offline
Old 09-24-2018, 11:52 PM
  #286
doward's Avatar
Total Cats: 754
Most rule sets limit us to 4”. In US club level racing, aero is seen as dark art and really exspensive. Rulesets either simply don’t allow aero mods, or severely limit the allowed aero mods.
We set the Supermiata S1 class aero rule to match the “norm”, as it’s a common figure and helps class to class crossover.
The book “Competition Car Aerodynamics” references nascar/StockCars and 5” as the point of max efficiency in that application.
In practice, if I was allowed 5”, I’d probably end up needing two splitters, as my car is fastest currently with the wing at zero or negative AoA. One for slower tracks and a smaller one for faster tracks. More splitter requires more wing to balance, and more drag. My horsepower level doesn’t approve of any more drag.
More power means drag is less of a concern, generally.
949/Supermiata cars built to more open rulesets have used splitters as deep as 10” and wider than the track width.
doward is offline
Old 09-24-2018, 11:57 PM
  #287
mx5-kiwi's Avatar
Total Cats: 57
I read that book but didn't see the NAscar 5" info, will have to check again.
Thanks for the info.
Presumably 300 - 350 whp is what you have in mind for the running of more than 4-5" of splitter?
I tried a 3" at Pukekohe (high speed, 5-6th gear turn 1) and had a big, sudden front lose, so very quickly dropped that low downforce philosophy
May need to revisit.
mx5-kiwi is offline
Old 09-25-2018, 11:07 AM
  #288
Total Cats: 2,378
As Dan clarified, S1 aero was designed with a clean sheet of paper. Compatibility with other classes, a useful adjustment range plus or minus, and also relative toughness when the driver chucks it off track now and then. The other constraint was also a desire to remove any "secret sauce" from the build recipe. While it's sexy to have some highly functional flat bottom and diffuser, very few DIY Builders know how to put one together cheaply. The rear wing is clicking a button on Singular Motorsports website. The basic front we do is highly documented so even a noob builder can cheaply put one together with basic tools.
.31 SNR
Old 10-01-2018, 07:31 PM
  #289
doward's Avatar
Total Cats: 754
Sonoma was a blast. Bucket list track. Years of Forza/Gran Turismo paying off in real life.
Car was hampered with an oiled clutch from a failed valve cover gasket that shut down my 2nd day at Laguna. My attempts at R&R, cleaning and scuffing between events were unsuccessful in recovering the torque capacity. I was forced to tip toe around at about 80% throttle or it would slip in 4th or 5th gear. So I set pressures in the RC1s once on Saturday and never touched the car again. I took the ST5-spec Hoosier R7s, but never bolted them on. Spent my time on track harassing the SPM S2 guys and had several dicing sessions with Jeff Ringer and Erin Kennelly. I'll try to get that video chopped up on its own, as bumpdrafting is always fun.
Several 1:55's on predictive that bled away on the uphill dragstrip from T6 to T7 because of the clutch slippage.
Late on Sunday the RF hub called it quits.
A 10 hour tow probably makes Sonoma a once-every-couple-years destination, but I can't wait to go back. All in all, super fun HPDE on a super fun track.
To do:
RF hub replacement
Cylinder head swap
new clutch disc
Dyno appt
Continue dropping weight
doward is offline
Old 10-02-2018, 12:35 AM
  #290
2slow's Avatar
Total Cats: 54
Can you please explain for the slow folks (yea, see my handle)....How's leaking VC causing clutch to slip since anything leaking form top of the engine can't enter the bell housing.
2slow is offline
Old 10-02-2018, 03:14 PM
  #291
Total Cats: 1,681
Because the oil from the VC or CAS-O ring for NA cars can leak down the back of the head then between the bell housing and block.
shuiend is offline
Old 10-02-2018, 04:09 PM
  #292
2slow's Avatar
Total Cats: 54
Right, that's the part that I thought was impossible due to how tight the two are bolted together and because that oil is only driven by gravity and possibly air moving over it, so it's not like there is any pressure to really push it into the smallest of openings. I've taken transmission off only once and don't remember there any major openings except for the starter, but even that one appeared well protected.
2slow is offline
Old 10-02-2018, 04:41 PM
  #293
Total Cats: 2,378
Experience with one transmission R&R versus a race team that has done a few hundred.
Stuff that can ruin the transmission disc:
Valve cover gasket
CAS o-ring
VVT banjo crush washers
Rear main seal, engine
Front seal, transmission
.31 SNR
Old 10-02-2018, 06:58 PM
  #294
2slow's Avatar
Total Cats: 54
I appreciate the information and see that my assumption was incorrect. I completely trust what you are telling me because you guys do have so much experience. There is a lot I have yet to learn.
2slow is offline
Old 10-02-2018, 09:38 PM
  #295
Valve cover gasket
CAS o-ring
/me
crosses fingers
(may have waited a hot minute before I fixed that ish)
Old 10-09-2018, 05:19 PM
  #296
doward's Avatar
Total Cats: 754
I am scratching NASA Buttonwillow off my calendar. I could have done a quick cylinder head r&r and shipped it to the dyno, but I would rather take my time and do a few extras 'while I'm in here'.
My psuedo-Supermiata-whammy, Keegan Engineering built BP4W head has arrived.
I was greedy and asked Mike to give me the "80/20". I needed 80% of the gains, and wanted to spend 20% of the money. What he, emilio and I came up with was as such:
Non-CNC-Supermiata/Keegan Engineering ported BP4W
-Valves de-shrouded, blended
-Bowl work and plunge cuts blended out to the valve guides on the intake side.
-Exhaust ports fully hand ported from bowl to manifold
-Casting flash and core shift ridges knocked down, but not totally smoothed out, remember 80/20)
Supertech +1mm valves
Supertech Light Double Valve Springs
Stock BP4W lifters
Skunk2 throttle body
Mazda BP5A intake cam
Mazda EUDM/JDM squaretop intake manifold(I'll be porting this to match the S2 TB diameter)
165whp is the goal.
That will allow me to ballast up to the 2400lb (or 2450lb break-point depending on proposed rule change for 2019) and open up 225/45/15 Hoosier R7(257mm section width)
Currently, parts and gaskets I forgot to plan ahead for are in the mail.
My valve cover and intake manifold are at the powder coater.
I am taking this opportunity to install an oil cooler and Supermiata Crossflow radiator, as well as correct my ducting situation and add a mesh grill to my airdam.
doward is offline
Old 10-09-2018, 05:33 PM
  #297
Total Cats: 2,378
Depending on how good your rings still are, I think you should hit 170whp on E85.
.31 SNR
Old 10-09-2018, 05:36 PM
  #298
cabowabo's Avatar
Total Cats: 121
Dang, 165+whp sounds nice. Assuming I venture to ST5 (highest possibility of current options) I'd like to do something like that + maybe Mazda 10:5:1 pistons and some bottom end bullet proofing. 170 peak on e85 with 6 speed and aero would be a lot of fun. Mo' power is also the only way I'd ever expect to hang at CoTA (or in general) with S2k, FT86, Bimmers, etc. Can't wait to see this setup action.
cabowabo is offline
Old 10-09-2018, 06:11 PM
  #299
Total Cats: 2,378
Not much more power with bigger pistons and more compression. BP's are honey badgers WRT to compression. Don't need a lot regardless of what you are doing. Gains from bore are linearly related to bore increase, i.e, small.
Dan was smart to spend his modest budget on a good head build that will work for anything. With the demise of NASA PT, there is no reason to build a stock or "points" head anymore. He spent roughly 2.5x what an OEM head/(stock cam) rebuild would cost but it's future and over rev proofed.
If you are in the bottom end and have the budget, by all means, 85.5's and 11.0:1. Otherwise just focus on the head.
It would be cheaper to put big cams in it, make 185whp on a stock bottom end. Just gotta watch the revs on stock rods.
.31 SNR
Old 10-09-2018, 06:32 PM
  #300
doward's Avatar
Total Cats: 754
I had planned to do a bottom end as well, Keegan has my core torn down and cleaned for whenever I'm ready. The $/whp ratio doesn't work for me, and the headroom/insurance cost of rods, fresh bearings, labor, etc just to end up using OE pistons is a non-starter for an N/A motor in an average-power rated class. So I cancelled that half of the project. That $3-4000 bottom end build goes back into my budget as a whole season's worth of entry fees, or a used rotrex...
doward is offline
Quick Reply: Tarmac 88 "Button" GLTC/ST5/TT5
